I forgot to mention that I have the Ameri-King AK-950 DC line filter on the
alternator output wire and the Amer-King AK-950-FTR1 alternator filter
(capacitor to ground from the alternator as suggested) and I later added the
"Eliminator" power line filter to the NAV/COM power input. The Eliminator
did help noticeably but there is still too much noise.
I'm quite interested in automotive engine conversions with respect to the
spark plug wires, coils, and distributer. Just using stock stuff or doing
something to shield RF. My avionics guy started talking about building a
box around the distributer and shielding the spark plug wires and stuff and
I thought, oh no, really?! I don't remember anything like that being
necessary on other conversions I've seen.
Oh yeah, just for thoroughness, I am using Taylor 409 spiral wrap spark plug
wires. One of the features of these wires as advertised by Taylor is low RF
interference. Of course, they are talking about car stereos, not aircraft
NAV/COMs.
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of
Richard Wampach
Sent: Thursday, October 19, 2006 9:41 AM
To:
rebel-builders@dcsol.com
Subject: RE: [rebel-builders] Radio noise
How about trying the capacitor across the alternator A+ output lug to
ground as Cessna does. This was a must on an airplane with an ADF, but
helps reduce most other radio noise as well. It's over $30 from Cessna,
you can try Spruce or one of the other suppliers, or maybe an automotive
parts store.
Dick Wampach SR-108
Sent: Thursday, October 19, 2006 9:18 AM
To:
Subject: Re: [rebel-builders] Radio noise
Yes that will confirm if the noise is from the alternator.
I could be wrong of course but FWIW, certainly a linear regulator is
theoretically quieter but every vehicle I've ever owned has had a
switching regulator and that has never been a problem. The battery
should be quite sufficient for smoothing out the system when properly
wired unless there is something else going on. That said, I have no
doubt that the B and C linear regulator is an extremely reliable premium
product but I guess I don't believe that it will do anything that can't
be accomplished with decent electrical system design 99 times out of
100. Alternator fields often draw less current than the ignition coil
which generally implies less switching noise althought the frequencies
are likely different. Most airplanes are flying with switching
regulators.
I guess I can imagine some remotely possible situations where a linear
regulator is the cure. Color me doubtful but always willing to learn...
N.Smith wrote:
Hi Mike
If you disconnect the alternator (I mean disconnect all wires and
insulate
from the alternator) and run the engine and the noise is still there
then it
is likely ignition based. If it's not there then its likely noise
generated
in the rectifier/regulator on the alternator. Switcher regulators can
be
very noisy, and a linear regulator can reduce that noise to almost
zero. See
Aeroelectric connection book for stuff on that problem area.
Nig
745E
mike.davis@dcsol.com]On Behalf Of
Sent: 19 October 2006 02:42
To: Rebel Builder's List
Subject: [rebel-builders] Radio noise
This is for you guys using automotive engine conversions. I've got a
fair
amount of radio noise that increases in pitch as engine RPM is
increased.
This generally means the source is somewhere in the ignition system. I
have
shielded the distributer pickup wires and the wires to the coils. I
also
shielded the wires from the alternator to the main bus. All shielding
is
grounded at one end. All headset jacks have isolators. I have spiral
wrap
spark plug wires that are supposed to be good for RF suppression but
they
are not shielded. For some reason the radio noise is much worse on the
nav
side. My transmissions are loud and clear. Do any of you automotive
conversion folks have radio noise problems? What have you done to
reduce
List archives located at:
https://www.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
