[rebel-builders] primer lines
Post by Ken » Sun Feb 19, 2012 11:16 am
That hardware store solder with a few percent silver is still low
temperature solder that typically melts at well under 500*F.
Fahrenheit not Celsius. Totally unsuitable. I have not done any primer
lines and I usually bronze braze things that need high temperature so I
don't have any silver solder. I have seen it in welding suppliers,
refrigeration suppliers, and it appears on E-bay. Usually you need a
compatible flux to makes solders work as well.
Jones, Michael wrote:
hi all
has anyone out there done the soldering of primer lines, i understand i
should use silver solder on the ends of the primer lines because of its
higher melting point, which makes sense, the only solder i have found so far
at stores near me is lead free solder with some silver content, with melting
point of approx 500 deg c, would this be okay to use, or does anyone in
canada know a local supplier of better silver solder
thank
mike#007
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 11:16 am
hey ken
trying to get some out of leavens, but they claim they dont use silver
solder on copper as the two have similar melting points, hey claim they use
regular solder on primer lines, so what is right
mike#007
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Ken
Sent: Tuesday, October 17, 2006 10:52 AM
Subject: Re: [rebel-builders] primer lines
hi all
far
melting
thank
mike#007
I guess I can't help you any further Mike.
I'd defer to Leavens I think. Standard solder won't take cylinder head
temps but I suppose your fittings will be cooler than max cht. Common
solders do vary at least 50F in melting temp depending on their
composition with 50/50 tin/lead being about the lowest I think. Don't
know about leadfree offhand. When I braze copper it does glow red but I
don't recall any melting problems. Bingelis says primer lines are
usually aluminum but that most homebuilders actualy use copper lines and
compression fittings??
hey ken
mike#007
hi all
far
melting
thank
mike#007
Jones, Michael
thanks ken
am using all copper and compression fittings, except at cylinder where there
is a special nozzle fitting and it requires a brass fitting to be soldered
to copper line then nut on it, to bad its not all compression but as usual
the certified world screws us home builders
mike
Sent: Tuesday, October 17, 2006 11:47 AM
hey ken
mike#007
hi all
far
melting
thank
mike#007
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:16 am
Mike...put the nut on first LOL.
You can take the spray nozzles out and just replace with an 1/2NPT
compression nipple. The engine will start the same!
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Tuesday, October 17, 2006 11:51 AM
Subject: RE: [rebel-builders] primer lines
thanks ken
there
mike
hey ken
use
mike#007
hi all
far
melting
thank
mike#007
That should say 1/8th NPT !
Sent: Tuesday, October 17, 2006 11:56 AM
thanks ken
there
soldered
usual
mike
hey ken
use
mike#007
far
melting
Jones, Michael
, so can use just regular nipple,
guess some fuel would vaporize & get sucked into cylinder,
have already bought all this stuff and was not cheap, would like to use it
since get charged for returning it to leavens,
do you know anything about soldering this nozzle Wayne ??
thank
mike#007
thanks ken
there
mike
hey ken
use
mike#007
hi all
far
melting
thank
mike#007
Nope...never bothered even though I have thousands of the "bulb" ends for
the tube to fit the spray nozzle fitting here. I can't see normal solder
melting from cylinder heat. They aren't that close to the exhaust. But like
Ken suggest...silver solder from an AC tech might be good insurance.
Sent: Tuesday, October 17, 2006 12:03 PM
thank
mike#007
thanks ken
there
soldered
usual
mike
hey ken
use
mike#007
far
melting
Schmucker, Del
Post by Schmucker, Del » Sun Feb 19, 2012 11:16 am
Mike:
On my Subaru with the Airflow Performance Fuel injection I used
stainless steel 1/8 inch lines and use the silver solder from local
welding supply store. It has Cadmium in it so be careful from the
fumes. You have to use the flux as well and I believe it would work
with copper lines as well. I just used a propane torch it was actually
easy to do.
Thank you,
Del Schmucker
Information Systems Manager
Keewatin-Patricia District School Board
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
Jones, Michael
Sent: Tuesday, October 17, 2006 6:16 AM
To: Rebel-Builders (E-mail)
Subject: [rebel-builders] primer lines
hi all
far
melting
thank
mike#007
