[rebel-builders] CYLINDER HEADS
Robert and Olga Johnson
Post by Robert and Olga Johnson » Sun Feb 19, 2012 10:47 am
Hi Mike: I hope you do not mind me jumping in here, but I had an O320 H2AD
160HP with the Sensinich metal prop on Rebel 652 and it ran very smooth. But
then I guess a 38 lb prop did help that situation. That was why I went with
that combo. Bob J
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Wednesday, May 10, 2006 9:38 AM
Subject: RE: [rebel-builders] CYLINDER HEADS
hey wayne
turns out old jugs are shot so have to get new ones, so getting lycoming
jugs
only question now is 150 or 160 hp, apparently fuel is not a problem so
was
thinking 160 hp & metal prop
any comments, vibration from 160 hp ?? etc
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 10:47 am
thnaks bob, jump in anytime
mike
Sent: Wednesday, May 10, 2006 10:12 AM
Subject: Re: [rebel-builders] CYLINDER HEADS
that combo. Bob J
hey wayne
jugs
was
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:47 am
I'd go 160 with a metal prop...150 with anything else (WD/Prince/etc) due to
the lack of "flywheel" effect on any of the light weight props.
hey wayne
jugs
was
thanks
mike#007
Sent: Tuesday, May 09, 2006 12:50 PM
" Leavens do a GREAT job on rebuilding - and are a class act for
warranty work !!! I have a Leavens overhauled O-320-E2D ... :-)"
................And it has first run overhauled cylinders on it....so Mike
don't blow the money on new as per Bob's previous message about the glider
club.
The average rec pilot flys an average of about 45 hours a year. Some make
it
to a 100 and most about 25. If you are lucky enough to be the 100 hour
fella
those cylinders should serve you well for the next 20 years.
Wide deck vs Narrow deck is right up there with the arguement for main
wheels toed in or toed out !! Both have advantages...both have
disadvantages
and should not detour you from your goal of an available engine. Wide
decks
actually have more cracking problems on the case than narrows...narrows
have
more cylinder base cracking than wides. I personally would rather fork out
for the cylinder...than a case and complete rebuild!
The engine in my own Rebel is an O-320-B2A that I, much to Leavens dismay,
had overhauled as a 150 HP engine...so it became a -C2A. My reasoning was
similar to yours Mike...I was afraid of finding fuel on the water if the
need arose to use marinas. The thing is now that most of them have premium
now for all the sea doos and there are lots of float bases out there that
have 100LL. Personally I do not even consider using auto fuel unless there
is no other choice. (It will also void your Leavens warrantee...so keep
that
in mind!). My other thought was low compression 150 HP on the heavy 160HP
crank/bearings would last me a life time without problems...and the -B 160
HP engines also have cylinder hold down plates to spread the load on the
cylinder bases where as 150HP -A models don't. So if you go 150 the plates
will still stay, heavier bottom end and a bullet proof engine.
Decissions, decissions, decissions.....If you are going to run a metal
prop....I'd go 160HP.... anything else 150.
I've got to get back to the shop....I should be off fishing already!
Post by Bob Patterson » Sun Feb 19, 2012 10:47 am
Hi Wayne !
I don't have any problem with FIRST run-out cylinders - all the
major problems started after the SECOND run-out -i.e. 4,000 hours plus.
And you're right - one good engine should last most flyers for toooo
many years - IF they cool it properly, and fly enough to keep corrosion
out. (Use Av-Blend or AV-Lube in the oil, especially for winters !)
I wouldn't use Lycoming cylinders if I could use the Superior jugs -
they'll last longer, run a bit cooler, and produce a bit more power ...
club.
it to a 100 and most about 25. If you are lucky enough to be the 100 hour
fella those cylinders should serve you well for the next 20 years.
disadvantages and should not detour you from your goal of an available
engine. Wide decks actually have more cracking problems on the case than
narrows...narrows have more cylinder base cracking than wides. I personally
would rather fork out for the cylinder...than a case and complete rebuild!
that in mind!). My other thought was low compression 150 HP on the heavy
160HP crank/bearings would last me a life time without problems...and the
-B 160 HP engines also have cylinder hold down plates to spread the load on
the cylinder bases where as 150HP -A models don't. So if you go 150 the
plates will still stay, heavier bottom end and a bullet proof engine.
Sent: Tuesday, May 09, 2006 11:58 AM
Hi Mike !
There are other concerns with 160 hp - I know some disagree,
but there is more vibration, and there is more load...
Wide & narrow decks can be had in dynafocal AND conical -
and you can change a conical into a dynafocal fairly easily.
Fuel IS a big concern, down the road - the new Kitplanes has an
article on fuel - hope to read it today ...
On Tuesday 09 May 2006 02:54 pm, Jones, Michael wrote:
hi bob
would go wide deck but already have mount & rubbers for, so would have
try to sell them, easier to just go with narrow deck, engine is from
leavens and is 0-320-b3b, has heavy bearings stock, also told 160 hp
stock,
and if i want leavens says can get 168 hp from it, what do you think,
my concern about 160 hp is getting fuel for it
mike
Sent: Tuesday, May 09, 2006 10:44 AM
Hi Mike !
FWIW, we've not had good results with anything ECI ....
Superior cylinders & engines seem much better. They have incorporated
many improvements, like more metal around the exhaust ports, reducing
cracking, and greatly improved airflow in the intakes. The Superior
XP engines are very popular homebuilding choices these days - can be
had balanced, polished, and ported - for a bit extra $$$ !! :-)
This makes a very smooth engine with no rpm restriction ranges,
unlike a stock Lyc. - in the O-360 variation.
You mentioned narrow deck - FAR better to get a wide deck engine
if you can - they are sturdier, and less likely to have bearing and
seal problems.
If the old jugs have lots of hours, scrap them. History has shown
that they WILL crack, definitely, after about 4,000 hours ... or
sooner
The gliding club stopped overhauling cylinders years ago - it is
actually
cheaper to replace them with new Superior cylinders, as the overhauled
ones didn't last very long, and the labour costs for replacement, and
down time, more than ate up the savings !
On Tuesday 09 May 2006 01:55 pm, Jones, Michael wrote: millennium
Jones, Michael
hi bob
whats wrong with brand new lyco jugs, i understood they are now similar in
design to eci and superior jugs, what makes you say superior is better ??
proof ??
mike#007
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Wednesday, May 10, 2006 12:59 PM
Hi Wayne !
club.
personally
on
Hi Mike !
hi bob
stock,
mike
Hi Mike !
seal problems.
sooner
actually
Hi Mike !
Subscribe to Aviation Consumer - they did an article last year on the
different cylinders, explaining the differences, with service history
reports from heavy users. This magazine is like Consumer Reports for
Aviation - NO advertising, and only straight evaluations ....
Unfortunately, my copy has disappeared ....
AFAIK, the new Lyco jugs still don't match the Superior ones - it
would cost them too much to re-certify them ... and we don't need
certified parts. :-) But I could be out of date .....
You know you can buy a brand new Superior XP-360 for just over
$20K USD - not bad with the loonie over 90 cents ! :-) I hear they
are working on an XP-320 for sale sooooon .....
http://superiorairparts.com
On Wednesday 10 May 2006 05:14 pm, Jones, Michael wrote:
hi bob
proof ??
mike#007
Patterson
Hi Wayne !
Mike don't blow the money on new as per Bob's previous message about the
glider club.
personally
rebuild!
dismay, had overhauled as a 150 HP engine...so it became a -C2A. My
reasoning was similar to yours Mike...I was afraid of finding fuel on the
water if the need arose to use marinas. The thing is now that most of
them have premium now for all the sea doos and there are lots of float
bases out there that have 100LL. Personally I do not even consider using
auto fuel unless there is no other choice. (It will also void your
Leavens warrantee...so keep that in mind!). My other thought was low
compression 150 HP on the heavy 160HP crank/bearings would last me a life
time without problems...and the -B 160 HP engines also have cylinder hold
on
Hi Mike !
stock,
actually
Jones, Michael
hi bob
will check them on web when get home tonight, thanks
for the info
mike
Patterson
Sent: Wednesday, May 10, 2006 10:29 AM
Hi Mike !
hi bob
proof ??
mike#007
Patterson
Hi Wayne !
glider club.
make
hour
personally
rebuild!
life
hold
on
Hi Mike !
stock,
think,
engine
actually
