negative. If you can get 10 negative that is great for when you are light. I
have two notches on my flaps handle with ~ 7 and 14 degrees negative. I also
have neutral 7, 14 and 22 down. 22 is pushing your luck and for nothing but
SLOW flight only. I'd be VERY cautious of 25 down with MAM's max suggestion
being 18 degrees.A bit of playing with the push pulls between the mixer and
torque tube and the wing to flaperon push pulls could probably change what
you have to 21 or 22 max down and 12 or 13 negative and you'll be extremely
happy with her. That is if you can't move the flap unit easily
instead...either way PLEASE no more than 22 degrees down. It's a real rudder
pedal airplane at that and rudder defection is the only way to turn the
airplane with full flaps down. Stick movement is useless at that setting so
I sure wouldn't go any more flap, and structurally not a good plan either.
I can't remember degree of travel for the flaperons. There's a measurement
somewhere and I think in the neutral flaperon position it's somewhere around
3 3/8 to 3 5/8" inches up/down from neutral position measured using the gap
filler box at the flaperon trailing edge as a reference. If I remember
tomorrow I'll throw a tape on mine and Howard's when I go back out to tackle
day 5 on the CLAMAR amphib install to the Elite. Tooooo pooped to head back
out now and I have to tackle the families 5 tax returns tonight before that
Bast....d, the Receiver General, is bangin on my door.
Sent: Thursday, April 27, 2006 3:52 PM
Subject: [rebel-builders] Rebel Flaperon Travel
fromHi All
Hoping I can get some help with this. Wayne, would appreciate a reply
canu if your not busy. Working at the inner controls with wings on etc. I
neutralget 25* of down flaperon travel and 10* of reflex with stick in the
Iposition. Is this too much? Nowhere in the manuel are the degree of the
flaperons mentioned. I have the electric flap setup and this is the travel
edgeget with the internal limiter switches. I don't want to have to put a
second set on if I don't have to. The 10* really lets the lower leading
andof the flaperon protrude. I could adjust it to get 30* of down flaperon
5* of reflex. Also how much travel (degrees) up and down for the
aileron/stick travel.
Steve W 637R
