Mike,
I believe that the heavier leading edge was primarily to allow
countersinking of rivets, if desired, to reduce ground-handling damage,
and to add some strength. I think there are other wing mods that contribute
to the higher gross, as well as gear mods. ....
The original Rebel gross weight increased by 100 lb. when the
bungee gear legs were strengthened ! You're right, it's not always
just the wing that changes.
....bobp
-----------------------------orig.-----------------------------------------
At 08:59 PM 5/18/00 -0800, you wrote:
<html>
I just wanted to pass on this information I found on the Murphy web
site... it seems to me that just upgrading the wing on your rebel isn't
going to give you that 1800lb gross. Yes your wing will definitely
be stronger, but are you really going to gain any other benefits?
Or have you built an Elite tail section also, I think I recall you saying
that you already had your tail done.<br>
<br>
Mike<br>
<br>
The increase to 1800 lb. gross comes from a number of modifications,
including a <b>stronger wing</b> (.032" leading edge) and a
<b>stronger and larger tail surface</b>. The wing modification
(.032" leading edge) is a simple change, but adds 12 lb. to the
aircraft. Unfortunately, the tail section modification is a major
undertaking will not be pursued as a Rebel upgrade. <br>
<br>
At 11:16 PM 5/18/00 -0400, you wrote:<br>
<br>
<blockquote type=cite cite>
Chuck, I think you are especially blessed, because you can<br>
build an airplane with the best of BOTH, and it sounds like you are<br>
building it RIGHT and LIGHT !! I look forward to flying with you
ALL<br>
on a Ramble one day !!<br>
<br>
Keep on rivetting, guys - it
REALLY <is> worth it !!<br>
<br>
&nb
sp; &
nbsp;
.....bobp</blockquote></html>
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
