Fred-
Just to start off a new thread here...
Now that you have figured the best way to get the crate home and into your
garage or shop, have you spent some time thinking about how you will inventory
and store all the pieces / parts? When you open that crate, it will be full
of parts, large and small that you will need to inventory, safely store, and
then be able to locate and access when you need them.
For what it is worth, (and for others to comment on), I found it best to
separate the pieces by what they are for. All parts for the tail surfaces went
into one area, The wings are stored in a separate area, and the fuselage has
its own home. Hardware and small parts for each section are also grouped,
although one common area for hardware (nuts, bolts, rivets, etc) would be fine.
Equally important, each box or pallet is labeled with exactly what is on or
in it so I don't have to go digging through 20 boxes to find the fittings I
need. I even went so far with my fuselage kit to put my inventory list on excel
so I can read it. (You have never seen my handwriting!) A local builder
friend of mine took all the hardware for his kit and stapled each bag to a 4 x 8
sheet of plywood in his shop so he could see and find each item as needed.
Maybe some others will comment on their methods of storing and retrieving
parts. I simply discovered as I started building I could organize and spend time
building, or I could store the parts "wherever" and spend my time searching
for the parts instead of building with them.
Good luck on the Moose!
Norm Isler
Elite 702E
[rebel-builders] Organizing a moose at home in parts
Thank you Norm, I like the apporoach of having specificly labeled boxes
and grouping them accordinly.
How do you read the plans? Are they in big wide sheets? 8.5 x 11?
CD?
Fred
NormIsler@aol.com
Sent: Friday, March 31, 2006 8:59 AM
Subject: Re: [rebel-builders] Organizing a moose at home in parts
Fred-
your garage or shop, have you spent some time thinking about how you
will inventory and store all the pieces / parts? When you open that
crate, it will be full of parts, large and small that you will need to
inventory, safely store, and then be able to locate and access when you
need them.
surfaces went into one area, The wings are stored in a separate area,
and the fuselage has its own home. Hardware and small parts for each
section are also grouped, although one common area for hardware (nuts,
or in it so I don't have to go digging through 20 boxes to find the
fittings I need. I even went so far with my fuselage kit to put my
inventory list on excel so I can read it. (You have never seen my
handwriting!) A local builder friend of mine took all the hardware for
his kit and stapled each bag to a 4 x 8 sheet of plywood in his shop so
retrieving parts. I simply discovered as I started building I could
organize and spend time building, or I could store the parts "wherever"
and spend my time searching for the parts instead of building with
them.
Norm Isler
Elite 702E
List archives located at: https://www.dcsol.com/login username "rebel"
password "builder"
CD?
Fred
NormIsler@aol.com
Fred-
need them.
them.
Norm Isler
Elite 702E
password "builder"
Fred-
The "plans" for the project are organized in a thick loose leaf binder,
mostly 8 1/2 x 11 pages with some fold outs at 11 x 17. It is more of an
"assembly manual" then plans.
A copy is also available on CD for viewing on your computer. I actually have
the manual on my traveling laptop so I can contemplate future construction
time while I travel for business.
Norm
Norm
What I did was went to the grocery store and got some of those cardboard grocery boxes with the 2 handles. I put all the parts for each section, wing, fin, rudder, etc into it's own box. I then labeled with a Sharpe the pt. no.s on the front of each box. The boxes were then put on a shelving unit so I could read the ends. All the long and larger parts were just put on a shelf I added to the bottom of the MAM plans built work table. I would do it again this way, worked well. Took one day to inventory and organize with my wifes help. I think there is picture on my website showing this setup. www.mikeselite.com
Mike Betti
771E
Mike Betti
771E
Fred-
Norm
Fred
I'm working on a Rebel so can't imagine all the parts in a Moose
But. I made a spredsheet listing all the parts and which box (all large and
small boxes recieved a code)
The nice thing about a spreadsheet is that you can search by part # or
description and find which box it's in. Takes time in the beginning but sure
saves it when you are looking for a part and have no idea what it looks like.
Brad (R195)
On 3/31/2006 4:59 AM, normisler@aol.com wrote to rebel-builders:
-> Fred-
-> Just to start off a new thread here...
-> Now that you have figured the best way to get the crate home and into
your
-> garage or shop, have you spent some time thinking about how you will
inventory
-> and store all the pieces / parts? When you open that crate, it will be full
-> of parts, large and small that you will need to inventory, safely store,
-> then be able to locate and access when you need them.
-> For what it is worth, (and for others to comment on), I found it best to
-> separate the pieces by what they are for. All parts for the tail surfaces
went
-> into one area, The wings are stored in a separate area, and the fuselage
has
-> its own home. Hardware and small parts for each section are also
grouped,
-> although one common area for hardware (nuts, bolts, rivets, etc) would
be fine.
-> Equally important, each box or pallet is labeled with exactly what is on
or
-> in it so I don't have to go digging through 20 boxes to find the fittings I
-> need. I even went so far with my fuselage kit to put my inventory list on
excel
-> so I can read it. (You have never seen my handwriting!) A local builder
-> friend of mine took all the hardware for his kit and stapled each bag to a
4 x 8
-> sheet of plywood in his shop so he could see and find each item as
needed.
-> Maybe some others will comment on their methods of storing and
retrieving
-> parts. I simply discovered as I started building I could organize and
spend time
-> building, or I could store the parts "wherever" and spend my time
searching
-> for the parts instead of building with them.
-> Good luck on the Moose!
-> Norm Isler
-> Elite 702E
Brad (R195)
-> Fred-
your
inventory
went
has
grouped,
be fine.
or
excel
4 x 8
needed.
retrieving
spend time
searching
-> Norm Isler
-> Elite 702E
Mike,
Is your web site up? Can't access it.
Fred
mbetti@up.net
Sent: Friday, March 31, 2006 12:52 PM
my website showing this setup. www.mikeselite.com Mike Betti 771E
password "builder"
Fred
mbetti@up.net
Fred-
an "assembly manual" then plans.
have the manual on my traveling laptop so I can contemplate future
construction time while I travel for business.
Norm
password "builder"
Up and down... doing some work on it. Just keep checking back.
On 3/31/2006 9:08 AM, rebel-builders@dcsol.com wrote to MIKE DAVIS:
-> Mike,
-> Is your web site up? Can't access it.
-> Fred
-> Mike,
-> Fred
