Fuel Lines
steve whitenect
Fuel lines
Me too Jean
Don't plan to cross vent the tanks either. I used alum lines all the way
and even went to 1/2" lines after the square cabin tubes.
Steve W. #637
Steve W. #637
Fuel lines
No...because there isn't enough flow...it's pretty much 99.9% static
pressure. Ideally a inverted J shaped tube is the way to go so the water
won't climb the slope...but haven't seen it as an issue even with straight
(L) tubes.
Sent: Monday, February 13, 2006 12:22 PM
Subject: Re: Fuel lines
(L) tubes.
whenJust to ask a "fuelish" question...
Wouldn't a forward facing "ram" vent also admit water to the fuel tank
flying in rain?
Am I missing something obvious?
Norm Isler
Elite 702E
Fuel lines
Hi Mike !
Most builders do run aluminum lines from the tanks to the gascolator.
It takes a bit of effort with bending, but there's nothing wrong with
fuel hose rubber piping & clamps to join sections, and connect up the
tanks to the cabin - AS LONG AS YOU CAN GET AT IT EASILY to replace it !!
Depending on your routing, you might want drains on the fuselage bottom,
about the door posts, as this can be a low point in the system.
I WOULD run a cross vent line between tanks - prefer clear plastic
for this one, as there can be some flex across there. 99 % of the time,
there's only AIR in the line anyway.... I WOULD put "J"
tube vents (or at least ONE) IN THE wing root FAIRINGS, in this vent
line. I would NOT put the "J" tube over the cockpit area - just dumb !
I have "L" tubes on my fuel caps - this is a PAIN, and dangerous !
Just a matter of time until some gas jockey snaps them off or puts
the cap on backwards & you lose all your fuel ! And Jean - don't
WELD them on - they'll crack even sooner !! If you must have them,
use a coupling with nuts, washers, and a lot of Pro-Seal ....
then they'll at least have some flex. This is a good way to mount
the J tunes on the wing root fairing strip too ...
As for the sight guages - use clear plastic fuel line ! You
definitely do NOT want anything rigid that can crack or shatter !!
DO add a small fuel valve 1/4" or smaller (like used on the Renegade),
at the bottom of the sight guage - that way, you can turn it off if
there's ever a leak, OR you want to replace the sight guage tube
(about every 2 or 3 years .... bad gas discolours it !)
Just MHO ;-) Hope it helps ! :-)
.......bobp
.......bobp
Hi builders,
Looking at the fuel system. I don't care for the use of plastic type
lines and fittings the manual calls for. Has anyone used all aluminum
tubing and fittings to accomplish this? How about a better site glass,
like maybe real glass mounted in some sort of aluminum frame? Has anyone
used a bottom sump, where the two tanks drain to the sump and the engine
takes it's fuel from it? Thanks,
Mike Betti
771E
Alan Hepburn
Fuel lines
I use 3/8" aluminum throughout, except for about 3" rubber to connect the
tanks to the fus. Also have Wicks valves, which mount nicely to a plate
above the door. Also couldn't find a real good location for their
gascolator bracket, so scrapped that and replace it with ACS' circular
flange. Have a low point drain behind the cabin. Vents are brake line
welded into the caps. Replaced the site glasses with Princeton capacitive
probes. Have a fuel flow sensor down near the pilot's left foot (be sure to
get the one for gravity feed). Other than that, it's pretty well stock!
Pics available if interested.
Al Hepburn
Al Hepburn
Fuel lines
The only rubber line on my Rebel is the Stratoflex from the Gascolator to
the carb. Everything else is 3/8 alum right from both the tanks, down the
rear door posts, dual quick drains in the low spot three point in the belly,
dual valves in the floor and a single line from there thru the carrythru up
the middle to the gascolator. Float senders in the tanks with no issues for
11 years. I dip tanks before all flights and know how many hours fuel I
have, and I'm always on the side of caution. Howard's is identical, except
his senders are capacitance. I did learn while flying FOKM though that the
site gauges are really nice for quick fuel checks before flight and when you
are concerned of overload and can quickly fill while someone watches the
gauge.
Sent: Monday, February 13, 2006 7:49 PM
gauge.
toI use 3/8" aluminum throughout, except for about 3" rubber to connect the
Al Hepburn
Mike Betti
Fuel lines
Wayne,
Where are your 2 fuel valves located in the floor? Do you have a quick drain
on both sides before the valves?
Thanks to all for the input on this subject.
Mike Betti
771E
Sent: Monday, February 13, 2006 6:59 PM
Mike Betti
771E
belly,
up
for
you
gauge.
capacitive
probes. Have a fuel flow sensor down near the pilot's left foot (be sureget the one for gravity feed). Other than that, it's pretty well stock!
Al Hepburn
Fuel lines
Yes Mike...right where I wrote "dual quick drains in the low spot three
point in the belly."
Valves are between the seats..maybe a foot back from the carrythru.
Sent: Monday, February 13, 2006 8:19 PM
drainWayne,
toon both sides before the valves?
Mike Betti
771E
thethe carb. Everything else is 3/8 alum right from both the tanks, down
exceptrear door posts, dual quick drains in the low spot three point in the
belly,
up
for
thehis senders are capacitance. I did learn while flying FOKM though that
thesite gauges are really nice for quick fuel checks before flight and when
you
gauge.
platetanks to the fus. Also have Wicks valves, which mount nicely to a
sureabove the door. Also couldn't find a real good location for their
capacitive
stock!toget the one for gravity feed). Other than that, it's pretty well
Al Hepburn
Jesse Jenks
Fuel lines
Check out MSC and McMaster Carr. They sell industrial sight gauges. I saw
some used in a Bearhawk that looked nice. Kind of pricey and probably heavy
though.
though.
Subject: RE: Fuel lines
Date: Mon, 13 Feb 2006 17:11:35 +0000
Hi All,
If you find some reasonable sight tube gauges, let me know too.
Jack, SR193
ventHi Mike,
I agree ... don't like the plastic tubes used inside the fuselage tofindthe two wing tanks. I plan to hard line the cross vent plumbing, andindicators.some rigid transparent sight tubes to use for the two fuel qtyorBob, 612e
mbetti@up.net
Sent: Monday, February 13, 2006 6:28 AM
Thanks Drew,
Do you have any pics of your vent fitting arrangement or a descriptionlinesfittings used? I'll look in wag areo tonight. Hydraulic tanks is where I
guess I got the idea.
On Sun, 12 Feb 2006 22:06:02 -0500, rebel-builders@dcsol.com said:At 06:13 PM 2/12/2006 -0600, you wrote:andand fittings the manual calls for. Has anyone used all aluminum tubingrealfittings to accomplish this? How about a better site glass, like maybefuelglass mounted in some sort of aluminum frame? Has anyone used a bottom
sump, where the two tanks drain to the sump and the engine takes it'sfittingsfrom it? Hi Mike I've changed most of my cross-vent system and fuel guagehaving ato aluminum. If I were to do it again I'd use all aluminum for the fuel
feed as well. I don't really like having a rubber hose buried under a
corner wrap where I can't get at it. I don't see any advantage tobunchbottom sump. In a gravity feed system you'd just end up with a wholeguagemore unusable fuel wouldn't you? I think Wag Areo sells a glass sightMylike you describe. We have lots of them on hydraulic tanks at my work.veryexperience is that the glass gets discoloured over time and it getsuphard to read the guage. It's not hard to change the plastic sight guage
every year or so. Just fly to low fuel then with the valves open jackfuelone side of the plane. Go have a coffee and when you get back all thewill have drained into the low wing. change that line jack up the other
side and repeat.
Mike Betti
Fuel lines
Ok thanks Wayne.
Thanks for the sight gauge lead Jesse.
Mike Betti
Sent: Monday, February 13, 2006 7:26 PM
Mike Betti
drainWayne,
Where are your 2 fuel valves located in the floor? Do you have a quicktoon both sides before the valves?
Mike Betti
771E
The only rubber line on my Rebel is the Stratoflex from the Gascolatorthethe carb. Everything else is 3/8 alum right from both the tanks, downexceptrear door posts, dual quick drains in the low spot three point in the
belly,
carrythru
up
for
have, and I'm always on the side of caution. Howard's is identical,thehis senders are capacitance. I did learn while flying FOKM though thatthesite gauges are really nice for quick fuel checks before flight and
when
you
gauge.
platesurestock!to
Fuel lines
At 11:46 AM 2/13/2006 -0500, you wrote:
should work on a rebel. You'll have 2 separate vents so if one gets plugged
the other will still work plus it would be easy to check for blockages by
blowing through the tube while fueling up.
It seems that lots of planes are using that method successfully so itMy two cents....
I have see and I plan to weld a bent tube on the gas caps to vent and
"pressurise" the gas tanks. Your pro/con about that way of venting?
Jean
Rebel 747R
Fuel lines
I used 3/8" od. teflon tubing (clear FEP I believe) for the sight
guages. Not as flexible as urethane but it won't degrade or shatter and
it is easy to cut to any desired length. Probably wasn't worth the
trouble although I did learn a bit about teflon ;)
I found the fuel plumbing to be seriously constrained by fitting choice.
Don't commit to a routing or material until you have fittings that will
do the job. For example it is difficult to come straight in from the
wing to the fuselage with a 90 degree turn to a fuel valve with
aluminum. You can't put a flare on a really short piece of aluminum
tubing as you must assemble the fittings before you make the second
flare. Bending short pieces can be interesting and similar constraints
come up - do you have enough length to slip on the end fittings and
still bend it and/or clamp it in a flaring tool? Waynes's idea of
routing the fuel aft of the rear wing attachments before coming into the
fuselage may be worth considering. I don't believe there is anything
wrong with judicious use of "rubber" hose in exposed locations or for
couplings. Properly installed it can allow for a fair bit of bent
airframe before it ruptures in an accident. It is slightly heavier but
easy to install, cheap, and readilly available as an SAE 30R7 automotive
product (Use 30R9 for EFI). I did not investigate the use of 100LL with
that hose as I plan to avoid 100LL. It is quite easy to make a beading
tool for 3/8 aluminum tubing.
Jesse Jenks wrote:
snipCheck out MSC and McMaster Carr. They sell industrial sight gauges. I saw
though.
Mike Betti
Fuel lines
Hi all,
I recently read a comment by Wayne about cheating and running the fuel lines above the door and down the forward door post. This is what I did and I really like the way it came out. Has any one had any experience with this not working out well in a gravity system?
Mike Betti
771E
Mike Betti
771E
fuel lines
Our Elite has the 8:00 tires and the Moose tailwheel. Fuel line not yet run but it will go to rear and down behind the door, then forward just below door sill to front. We looked at avoiding a low point sump at the rear of the door and could not see how it can be done without a sump. We will put a sump in every low point. May not be necessary but I will not take the chance.We get too much condensation here in South Carolina. An additional concern is the oncoming possibility of alchohol in the mogas and the potential water problems that brings.
Rallph Baker
Rallph Baker
David L. Tuck
Fuel Lines
Does it matter if I use what is called versatube? for fuel line in the rebel? or do I use the 5052 3/8's ridged?
Dave T
Hotmail
Dave T
Hotmail
