More help needed.I have a 160 HP with crossover exhaust & two mufflers with heat shrouds.Plan on using both for cabin heat.Going to use a shroud on the crossover pipe for carb heat.My question is should i take the intake air for the mufflers from the back off my engine baffels or cut a intake in the nose bowl.Also the heat boxes i have for cabin heat just lets the heat from the system dump out under cowling when heat in not on.Should i have heat boxes with no dumping off hot air when heat is not on.If all this air is passing over engine & not going down through cylinders just passing straight out the two 2 " holes in rear baffels will this loss off air affect cooling off enging.Little confusing i know but would like to do this correct the first time.
Regards: Alvin
Rebel. 776
Cabin Heat Syatem.
Cabin Heat Syatem.
You must have air flow thru the shrouds either using it for heat or dumping
it....or you will overheat the shrouded in section of the mufflers. I prefer
to take the inlet off the front baffle plate between the front cylinder(s)
and the cowl nose bowl. Taking from the rear baffle steals some + pressure
off the baffles..and why I also don't like rear baffle mounted coolers
either.
From: "Alvin and Glenys Adams" <gander.electrical@nf.sympatico.ca>
To: "rebel" <rebel-builders-d@dcsol.com>
Sent: Wednesday, February 01, 2006 11:01 PM
Subject: Cabin Heat Syatem.
first time.
either.
with heat shrouds.Plan on using both for cabin heat.Going to use a shroud onMore help needed.I have a 160 HP with crossover exhaust & two mufflers
first time.
Regards: Alvin
Rebel. 776
Cabin Heat Syatem.
Alvin,
I've uploaded some pics to (210 - R-Engines). I used this type of system on our Lyc 160 hp 0320. Heater worked fine. Air intake from the front of engine baffle system (FRESH AIR), and no compromise to +pressure in the cowl for engine cooling.
Jeff
From: Alvin and Glenys Adams <gander.electrical@nf.sympatico.ca>
Date: Wednesday, February 1, 2006 8:01 pm
Jeff
Regards: Alvin
Rebel. 776
Cabin Heat Syatem.
Wayne:
You may well be right about ventilation of the carb heat shrout being a
"must", but I don't have it, and have 30+ hours on the airplane without any
evident problems so far, so I'd like to be sure before changing anything.
How do you know the shrouded area overheats? How hot is too hot? It seems
to me that on many tightly cowled airplanes they insulate the exhaust to
prevent heat loss to surrounding structure. The carb air shroud is quite a
ways from anything up the front of an O320/360 in the Murphy installation,
and it's not going to get any hotter than the exhaust pipe itself otherwise
would, so I don't think that's a problem. So the problem would have to be
with the shrouded portion of the exhaust itself, which would have to get hot
enough to deform, presumably. How hot does/can that get?
Al
Al
Cabin Heat Syatem.
At 07:56 AM 2/2/2006 -0500, you wrote:
it will be suseptable to cracking from being overheated. Also the shroud
itself probably won't last very long without some airflow to cool it.
Hi Al I don't think your exhaust will get hot enough to melt or deform butWayne:
Al
Cabin Heat Syatem.
with heat shrouds.Plan on using both for cabin heat.Going to use a shroudMore help needed.I have a 160 HP with crossover exhaust & two mufflers
Hi Alvin OT to the subject but what are you using for mufflers?
Regards: Alvin
Rebel. 776
Cabin Heat Syatem.
As Drew has pointed out you lose the normal heat dissipation that an open
pipe would have by closing it with a complete shroud. Makes it different
temp wise than what's directly around it that's all....and could lead to
premature cracking due to the temp differential. Generally the cabin heat
flappers dump the hot air cowl side if they are not open.... so there is a
continuous air flow thru the shrouds. Also most carb air boxes do this so
when carb heat is not selected the hot air is dumped out the bottom of the
air box to avoid heated air being drawn/forced through the clearances of the
air box even though you don't want carb heat. Speaking of that.....that's
another reason you DON'T want an air inlet hose to the carb heat shroud...ie
no scat hose off the plenum/nose bowl. Just let the engine suck the air from
the shroud with a screened over intake hole. If you have it that way there
would also be less chance of drawing hot air when you don't want it...so if
you are set up that way Al you may be alright on the Carb heat.
Sent: Thursday, February 02, 2006 10:21 AM
Subject: Re: Cabin Heat Syatem.
anyAt 07:56 AM 2/2/2006 -0500, you wrote:Wayne:
seemsevident problems so far, so I'd like to be sure before changing anything.
ato me that on many tightly cowled airplanes they insulate the exhaust to
installation,ways from anything up the front of an O320/360 in the Murphy
otherwiseand it's not going to get any hotter than the exhaust pipe itself
bewould, so I don't think that's a problem. So the problem would have to
hotwith the shrouded portion of the exhaust itself, which would have to get
butHi Al I don't think your exhaust will get hot enough to melt or deformenough to deform, presumably. How hot does/can that get?
Al
