Can you give more details of that bushing? Wall thickness, material, flanged
or not? I was thinking of doing the same thing.
Thanks.
Subject: Re: Rebel: What next?
Date: Mon, 30 Jan 2006 08:05:00 -0500
And then the wheels so it can be moved?
Perhaps one bushing at the lower rudder pivot is sufficient? There
wasn't a lot of meat on that bracket so since I have access to a lathe I
lightly pressed a smaller diameter bushing in instead of an AIL-26.
Outer rib reinforcements on elevator only not the rudder.
I timed the fabric and paint for the Fall when the temperature was
reasonable and bugs were low, but pick up the chemicals if you drive by
anywhere (OSK, Sun'n fun, etc,?) that has them.
Bob Patterson wrote:
parts.Hi Jim !
Just off the top - looks like finishing up the tail would be a good
place to start. That's a good place to get experience, with smallerailerons.That's where the manual likes to start new builders... then theyouCheck archives for the outer rib & skin reinforcements, and possibly
adding AIL-26 (?) bushings now, rather than later ... don't forget the
POGs (large nylon washers), too !
.......bobp
On Sunday 29 January 2006 11:00 pm, pequeajim@dcsol.com wrote:
Well, I have my Rebel setup in my garage and some tools together. Ifstudyingall recall, this was supposed to be a 90% complete model, but inwaswhat has been done, I believe that estimate to be very optimistic.
I went through the manual and this is what I can best figure out whatthisdone up to this point.
Chapter Title Completed
1. Helpful Hints ---
2. Aileron Assembly X
3. Fabric Covering NS
4. Rudder Assembly X
5. Elevator Assembly 80%
6. Elev-Trim Assembly 80%
7. Elev-Rudder Tip Assembly NS
8. Stabilizer Assembly 90%
9. Fin Assembly 90%
10. Wing Assembly X
11. Wet Tank Assembly X
12. Wing Tip NS
13. Fuselage Assembly X
14. 0320 Fuselage Modifications X
15. Float Hard Point Installation X
16. Spring Gear Assembly X
17. Landing Gear N/A
18. Landing Gear Covering N/A
19. Tailskid X
20. Stabilizer Installation X
21. Wing Struts X
22. Wing Strut Fairings NS
23. ontrol Installation NS
24. Stabilizer Faring Installation NS
25. Seat Assembly 60%
26. Seatbelt Installation NS
27. Door Assembly 70%
28. Door Lock Assembly 40%
29. Wing Fairing Installation NS
30. Windshield Installation N/A
31. Skylight Installation NS
32. Pre-Molded Windshield Installation 25%
33. 912 Cowling N/A
34. 912 Engine Installation N/A
35. O-320 Lycoming Engine Installation 60%
36. O-320 Speed Cowling Installation 60%
37. Ultralight Rudder N/A
38. Ultralight Elevator N/A
Instrument Panel Assembly 35%
The work that is completed thus far is supurb, but there are some
modifications that I will be doing like some of the OMs, and the
instrument panel changes to suite my taste.
It looks like he skipped around quite a bit. I'm sure ther were reasons
for that. I am wondering what I should work on next? In looking atlist, does it give you guys enough of a clue to offer some suggestions?
Also, I can work in my garage on the aircraft, and by March will have a
pole barn shop completed large enough that I can assemble the complete
aircraft inside and then pull the wings back off before transporting to
the airport.
I guess I'm saying that so that you all know that space in not a
limitation once March rolls around.
thanks
Jim!
Rebel #572
