I am trying to put together an order list for extra fuselage parts for
strengthening mods. I don't need much because Wayne already included lots
extra stuff (thanks Wayne). The first question is the recurring FUS-10 vs
FUS-70 dilemma. Wayne swapped me one pair of Fus 10s for a pair of FUS-70s
so I have 4 for use on lower forward and upper rear corners. I am
considering getting another set of FUS-70s for the lower rear corners. That
would give me a spare set of 10s. I could then use doubled 10s on the lower
forward and move those 70s to the upper forward. Is that necessary, or
should I stay with what I have (4 of each)? I am planning to go off-road (3
wheel drive?) and floats.
Next question is the FUS-30 doubler. Is it possible to make a decent looking
one myself, or should I order one?
Thanks.
Rebel corner wraps
Rebel corner wraps
My 2 cents is you should be fine with FUS-70's top rear and bottom
front..and FUS-10's the other two spots. Definitely no need for anything
heavier top front..rear bottom can be increased for less chance of
"boarding" damage..but other than that it really doesn't take much
structural load on wheels or floats...especially since you already have the
.032 door sill pieces I bent up for you.
Much easier to fit another FUS-30 piece....but can definitely be done with
flat sheet from scratch. Make a pattern from poster board first...only bend
one side up first...attach to one side with a few holes/clecos.... pull it
around hard and then form the second bend. Leave extra material for final
trimming at the tail post for final fitting.
Sent: Sunday, January 22, 2006 5:19 PM
Subject: Rebel corner wraps
ThatI am trying to put together an order list for extra fuselage parts for
lowerwould give me a spare set of 10s. I could then use doubled 10s on the
(3forward and move those 70s to the upper forward. Is that necessary, or
lookingwheel drive?) and floats.
Thanks.
Rebel corner wraps
Thanks Wayne,
I'll stick with what I've got for now then, and start building again. I was
getting pretty sick of wings. It's good to be looking at something new.
Subject: Re: Rebel corner wraps
Date: Sun, 22 Jan 2006 17:29:46 -0500
lotsI am trying to put together an order list for extra fuselage parts for
strengthening mods. I don't need much because Wayne already includedvsextra stuff (thanks Wayne). The first question is the recurring FUS-10FUS-70sFUS-70 dilemma. Wayne swapped me one pair of Fus 10s for a pair ofThatso I have 4 for use on lower forward and upper rear corners. I am
considering getting another set of FUS-70s for the lower rear corners.lowerwould give me a spare set of 10s. I could then use doubled 10s on the(3forward and move those 70s to the upper forward. Is that necessary, or
should I stay with what I have (4 of each)? I am planning to go off-roadlookingwheel drive?) and floats.
Next question is the FUS-30 doubler. Is it possible to make a decentone myself, or should I order one?
Thanks.
Rebel corner wraps
Fus hull will go quick. Should be about 90% of your wing build time to get
to here...
http://www.irishfield.on.ca/gallery/rebelfuselage.jpg
Sent: Sunday, January 22, 2006 8:20 PM
to here...
wasThanks Wayne,
thegetting pretty sick of wings. It's good to be looking at something new.
with.032 door sill pieces I bent up for you.
bendflat sheet from scratch. Make a pattern from poster board first...only
itone side up first...attach to one side with a few holes/clecos.... pull
off-roadaround hard and then form the second bend. Leave extra material for final
considering getting another set of FUS-70s for the lower rear corners.lowerwould give me a spare set of 10s. I could then use doubled 10s on theforward and move those 70s to the upper forward. Is that necessary, or
(3lookingwheel drive?) and floats.
Thanks.
