a foot and a half at the top of the stick ... You won't need the same
angles with the Elite, though - totally different elevator -- larger,
and the whole tail is different.
Ideally, you want the stick positioned so that, in cruise, you
can rest your forearm on your leg comfortably. In flight, you will
never move the stick more than 1/2" fore-and-aft, normally, and maybe
an inch or two left & right... if you touch the stick at all ! ;-)
On Monday 02 January 2006 10:30 pm, Mike Betti wrote:
fromThat brings me to one of my questions, how much stick movement is there
thefore to aft on a Rebel? I think there is way too much stick movement on
toElite and I am curious how it differs from the Rebel. If I kept with the
stock stick and put in 27/20 degrees, my arm would not have enough throw
onmove it from one end to the other.
Sent: Monday, January 02, 2006 9:14 PM
Subject: Re: rudder pedals/stick
I'll second that ! Also could put more load on the horns -
spoils your whole day when they bend or tear off !! That is one
reason I don't like the idea of running a cable forward & around
a pully for up elevator - all the loads are on one horn, and
they alternate with movement - sounds like a recipe for metal
fatigue !!
On Monday 02 January 2006 05:36 pm, Wayne G. O'Shea wrote:givenIt will also make your elevator movement more sensitive..since for anysuremovement of the stick for/aft the elevator will have more movement. Nothow great a thing this will be on the Elite considering the reports
appear
it is pitch sensitive to start with.
Sent: Monday, January 02, 2006 5:32 PM
couldthe
ofaddmaketo
Iboltedon
offsetup.
reallymyRebels
somecan't
curious,
forwardmeasuringruddergeometry
ambitious !wraps.
cylindersE-controls.;-) cylindersI
tobeefbuildforearrangementinadvertantly.
mountthemount /
brakethe
in
Thisconsideringis
-----------------------------------------------------------------easierwould
