Rebel Wing Tips/nutplates
Jesse Jenks
Post by Jesse Jenks » Sat Feb 18, 2012 2:30 pm
Ken,
I agree that it's better to install nutplates after the holes are drilled
through both parts to be joined, but I have had good luck installing the
nutplates first and then drilling the screw hole in the second part later
on. There are a couple reasons for doing it that way. First, I like to use
3/32" solid rivets with a hand squeezer to secure the nutplates. With those
restrictions there are places where you have to install the nutplates to the
rib flange (or whatever) before the skin is riveted down, because you can't
get the squeezer there with the skin on, for example the left wing's tip rib
and the right wing's root rib. If I borrowed a rivet gun and bucking bar I
could do the tip rib, or use the cherry 3/32 blind rivets, but I don't like
them too much, and they're pricey. The second reason is to be able to
replace existing rivet locations with the nutplates because it can be hard
to fit them between rivets.
The technique I have used to locate the screw holes for pre-installed
nutplates is to position the part, in this case it would be the wing tip,
and mark a line around the perimeter of it on to the wing skin. Next remove
the tip and draw lines perpendicular to one you just made that intersect it
and the center of the nutplate, and extend out onto the skin 6" or so. Then
measure as carefully as possible from the perimeter line to the center of
the nutplate and mark the measurement right on the skin. Now put the tip
back on and align it with the perimeter line on the skin again, then using a
ruler, extend the perpendicular lines back onto the tip. Finally, measure
and mark the distance you marked down earlier and you have the screw
locations. It's not perfect, but If you drill the screw holes a bit oversize
it works well. I did the tail tips this way, and then used countersunk
machine screws and those thin countersunk stainless washers. I think it
makes a good installation in fiberglass because it gives a much bigger
bearing surface and it looks slick too.
Subject: Re: Rebel Wing Tips
Date: Wed, 07 Dec 2005 21:02:10 -0500
Off topic, but if you install those nutplates now, do you have someway
of aligning and drilling the holes in the tips later? Usually you want
the tips on first, then drill, then nutplates.
Jesse Jenks wrote:
Thanks Jeff,
It looks like quite a bit of work. It looks like you put some inspection
holes out there. Are those just for accessing the flaperon hinge bolts
attach bolts? Do you have wing strobes, and if so do you have the power
pack
out there? I was just getting ready to install nutplates for attaching
wing tips, whichever ones I use, but I see from your pictures that the
droop
tip becomes a semi-permanent part of the wing, so nutplates along the rib
flange won't do any good. Maybe I'll just go with a single fuselage
mounted
strobe and forget about it.
Post by Ken » Sat Feb 18, 2012 2:30 pm
I see where you are coming from now. FWIW the cheap 3/32 commercial
aluminum countersunk rivets seem to also work fine on nutplates that
have dimpled rivet holes. They are a 120 degree cs. but still seem fine.
Rather than those countersunk stainless washers I've just be putting a
nylon washer under a truss head screw but what you are doing probably
does look better.
The aeroflash power supply base is 5.5" x 3.6".
Jesse Jenks wrote:
Ken,
use
those
to the
can't
tip rib
bar I
like
hard
remove
intersect it
Then
using a
oversize
Bob Andrews
Post by Bob Andrews » Sat Feb 18, 2012 2:30 pm
Think the amount of time and effort to install nut plates is unwarrented on
the wing tips. For inspection purposes, an inspection plate should answer
the mail. On the rare occasion that one might need to take the tip ... get
the punch and #30 drill bit out. Mine are getting riveted on.
Bob 612e
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Ken
Sent: Friday, December 09, 2005 7:29 PM
Subject: Re: Rebel Wing Tips/nutplates
does look better.
Jesse Jenks wrote:
Ken,
use
those
to the
can't
tip rib
bar I
like
hard
remove
intersect it
Then
using a
oversize
Post by Walter Klatt » Sat Feb 18, 2012 2:30 pm
FWIW, I have my tips riveted, and only had to remove one once
when I damaged a tip. And I would do the same if I was building
again.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Andrews
Sent: Saturday, December 10, 2005 5:06 AM
Subject: RE: Rebel Wing Tips/nutplates
plate should answer
Bob 612e
3/32 commercial
nutplates that
just be putting a
doing probably
does look better.
Jesse Jenks wrote:
Ken,
luck installing the
use
the nutplates. With
those
to the
down, because you
can't
the left wing's
tip rib
gun and bucking
bar I
rivets, but I don't
like
is to be able to
because it can be
hard
for pre-installed
wing skin. Next
remove
made that
intersect it
the skin 6" or so.
Then
skin again, then
using a
you have the screw
screw holes a bit
oversize
washers. I think it
gives a much bigger
The clipnuts were fairly quick to use.
The wings are a bit easier to paint and transport without the tips on.
If they are removed, screws might look better than unpainted rivets. I
suppose with screws the inspector might want the darn tips removed for
the final inspection though ;(
again.
Andrews
plate should answer
Bob 612e
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:32 pm
He shouldn't want them off Ken. There are no controls or attachment bolts to
view that weren't seen at preclose. If he wants them off hand him the screw
driver and go get yourself a beer! : O )
Sent: Saturday, December 10, 2005 10:14 AM
again.
Andrews
plate should answer
Bob 612e
Post by Ken » Sat Feb 18, 2012 2:32 pm
LOL :)
Post by Walter Klatt » Sat Feb 18, 2012 2:32 pm
The other consideration is weight. If you apply this thinking
throughout your entire plane, it's going to weigh quite a bit
more, and will not perform as well.
Sent: Saturday, December 10, 2005 7:14 AM
unpainted rivets. I
tips removed for
was building
again.
Andrews
plate should answer
riveted on.
Bob 612e
Jesse Jenks
Post by Jesse Jenks » Sat Feb 18, 2012 2:32 pm
I've got something going for me in this area. I way 135 pounds, and thats
soaking wet after falling off the float. I figure I can throw on some
nutplates and not notice it.
Date: Sat, 10 Dec 2005 12:17:01 -0800
unpainted rivets. I
tips removed for
was building
again.
riveted on.
Dale Fultz
Post by Dale Fultz » Sat Feb 18, 2012 2:32 pm
Glad I'm not the only small one on here. Dale
Sent: Saturday, December 10, 2005 9:12 PM
Jesse Jenks
Thanks to all who replied, and thanks Ken and Roger for the Aeroflash
dimensions.
I am now satisfied that I can put off the whole wing tip/nutplate/power
supply dilemma and just finish the wings and move on to the fuselage.
Sometimes the best thing to do is nothing...for a while.
Date: Fri, 09 Dec 2005 22:29:29 -0500
does look better.
Jesse Jenks wrote:
Ken,
drilled
later
use
those
to the
can't
tip rib
bar I
like
hard
tip,
remove
intersect it
Then
using a
measure
oversize
Jesse Jenks
Ken,
I meant to ask where you found aluminum 3/32 CS rivets? I could never find
any and tried some of the Cherry steele ones but was not happy with them.
does look better.
Jesse Jenks wrote:
Ken,
drilled
later
use
those
to the
can't
tip rib
bar I
like
hard
tip,
remove
intersect it
Then
using a
measure
oversize
Directly from Textron is the cheapest. Spaenaur also stocks them so I'd
bet MSC would have them as well.
Jesse Jenks wrote:
Ken,
Post by Drew Dalgleish » Sat Feb 18, 2012 2:33 pm
I bought a big bag of them at the oshkosh flymarket a few years ago. Mostly
though I used solid 3/32 cs rivets in countersunk holes. I know that .020
is to thin to countersink but I'm not worried about the nutplates pulling
out the back of the hole. 3/32 rivets are small enough that you can squeeze
them with a pair of vice grips.
At 06:36 PM 12/10/2005 -0800, you wrote:
Ken,
