Hello Rebel Builders/Flyers:
I am in the process of installing an "under-floor" fuel system and
selector valve on Rebel 662. I took the Cessna approach with the layout,
and have been working on this for some time now.
The left and right lines will exit each tank going aft through (or
around?) the aft wing attach double bulkheads, then a 90 degree down
just aft of the door opening (bulkhead "F") through the angled ledge
channel, with a 90 degree forward through the door vertical bulkhead
then down through a "racetrack" slot in the sill (located just below the
door angled sill) forward through the double bulkhead to a 90 degree
inboard to the selector valve. Both left and right fuel lines will meet
here. A single line from the selector will go forward through both
square carrythroughs. The line will then run on the left side of the 5/8
square stiffener tube toward the firewall then to the gascolator which
will be mounted somewhere left of the aircraft centerline.
To date, the selector valve is mounted in the floor, between the seats ,
just right of centerline. Some of the lines on the right lower side have
been run. (See photos).
Last evening I took another long look at the installation and had some
questions in my pointed little head concerning my line routing. I have
never done this type of installation before so I am being cautious
(maybe too cautious). Unsure whether I am going at it in a sound and
correct manner, I thought it would be great to get some further opinions
and/or suggestions from others. To give you an idea of where I am at, I
have uploaded some installation photos to the archives for review.
Initially, I purchased some 3/8 tubing from my local hardware store for
mockup. This soft tubing seemed to make bending in place relatively
easy. Not realizing that the 3/8 fuel tubing received in my kit from MAM
was a LOT more rigid and made for some tough bending in place. I have
heard that some builders make runs all the way from the tanks to the
firewall with very few fittings! How the heck is that accomplished? Am I
doing something wrong here?
Note 1: As you can see from the photos, there is an access cover on the
outside of the bottom floor for selector access/maintenance (an access
cover on the inside was not an option as there is a lot going on the
inside in that area with float pump stuff, fuel valve mount, water
rudder mechanism, elevator cable pulleys, etc.). A hole will be drilled
in this access cover so the single, low point Saf-Air valve will
protrude making it accessible for pre flight. The cover plate will have
a watertight seal and there may be a streamlined "half" faring over the
drain valve for protection and make it water resistant from float spray.
Note 2: Wherever there is an "AN" fitting, there will be an access cover
for maintenance. (i.e. corner wraps).
Note 3: The selector valve handle will have a fiberglass safety cover
around it to prevent the possibility of accidentally moving it from its
intended position in flight.
A. Has anyone taken this approach to a fuel line installation?
B. Am I headed in the right direction with this installation?
C. If so, is it possible to accomplish this installation with less AN
fittings (longer tube runs)? How?
D. Is it acceptable to run the aluminum fuel lines through the "F"
double bulkheads, just below the wing fittings with grommets or should
the lines be routed around the wing fitting double bulkheads?
Suggestions, comments or criticism would be highly appreciated.
Thanks in advance.
Terry Dazey
Rebel 662
Rebel Fuel Line Install
Terry, can't see exactly from the photos, but would be concerned
about the grommets if they are the same ones that I got from MAM.
I would prefer something more heavy duty that can't rub through
with vibration, and maybe even bulkhead AN connectors.
Terry Dazey
Sent: Wednesday, November 30, 2005 9:52 AM
To: Murphy Group
Subject: Rebel Fuel Line Install
fuel system and
through (or
90 degree down
the angled ledge
vertical bulkhead
to a 90 degree
through both
gascolator which
between the seats ,
routing. I have
being cautious
in a sound and
where I am at, I
for review.
hardware store for
place relatively
in my kit from MAM
in place. I have
the tanks to the
accomplished? Am I
access cover on the
lot going on the
mount, water
valve will
from float spray.
be an access cover
moving it from its
through the "F"
grommets or should
Thanks in advance.
Terry Dazey
Rebel 662
Hello Walter:
Those grommets are not MAM supplied. They are approximately 7/8 inch Outside
diameter and fit in a 5/8 inch hole (inside diameter is 3/8 inch for the
tube).
There isn't room for bulkhead AN's at either end, so I elected to use the
90* at those locations. (If I put a bulkhead fitting at the double bulkhead,
there wouldn't be room to make the nut connection. a bulkhead connector at
the door vertical channel would put the tube that would run up the aft side
of the door would be too close and would not be able to make a perpendicular
shot through the diagonal channel. Is that what you were talking about?
Clear as mud?
I will go out this weekend and take another look at bulkhead fittings and
see if I was missing something there. Sometimes I get focused on a project
and "can't see the forest through the trees".
Thanks for the advice!
Terry Dazey
Rebel 662
Bonney Lake, Washington USA
tube).
Clear as mud?
Terry Dazey
Rebel 662
Date: Wed, 30 Nov 2005 19:05:56 -0800
Subject: RE: Rebel Fuel Line Install
Terry Dazey
To: Murphy Group
fuel system and
through (or
90 degree down
the angled ledge
vertical bulkhead
to a 90 degree
through both
gascolator which
between the seats ,
routing. I have
being cautious
in a sound and
where I am at, I
for review.
hardware store for
place relatively
in my kit from MAM
in place. I have
the tanks to the
accomplished? Am I
access cover on the
lot going on the
mount, water
valve will
from float spray.
be an access cover
moving it from its
through the "F"
grommets or should
Thanks in advance.
Terry Dazey
Rebel 662
Not saying you have to have bulkhead fittings, as long as you
have good grommets and support for those lines so they can't flex
or vibrate. But I have seen where the cheap ones are easily cut
by the sharp aluminum. I have also seen where short pieces of
hydraulic hose with the metal fuel line inside were used instead.
Not sure if this is best practise, but it seemed pretty strong.
Terry Dazey
Sent: Wednesday, November 30, 2005 9:16 PM
Subject: Re: Rebel Fuel Line Install
Hello Walter:
is 3/8 inch for the
tube).
elected to use the
were talking about?
Clear as mud?
Terry Dazey
Rebel 662
be concernedFrom: Walter Klatt <Walter.Klatt@shaw.ca>
Terry, can't see exactly from the photos, but wouldgot from MAM.about the grommets if they are the same ones that Irub throughI would prefer something more heavy duty that can'tinstallation?with vibration, and maybe even bulkhead AN connectors.
Terry Dazey
To: Murphy Group
fuel system and
through (or
90 degree down
the angled ledge
vertical bulkhead
to a 90 degree
through both
gascolator which
between the seats ,
routing. I have
being cautious
in a sound and
where I am at, I
for review.
hardware store for
place relatively
in my kit from MAM
in place. I have
the tanks to the
accomplished? Am I
access cover on the
lot going on the
mount, water
valve will
from float spray.
be an access cover
moving it from its
A. Has anyone taken this approach to a fuel lineinstallation?B. Am I headed in the right direction with thisbulkheads?C. If so, is it possible to accomplish this
through the "F"
grommets or should
the lines be routed around the wing fitting doubleappreciated.Suggestions, comments or criticism would be highly-------------------------------------------------------Thanks in advance.
Terry Dazey
Rebel 662
-----------------------------------------------------------------List archives located at: https://www.dcsol.com/login
Another option is the hard plastic snap bushings and a bit of proseal
for buried lines that can't be inspected easily. Spruce PN 04-05753
only needs a 1/2" hole for 3/8" tubing.
Walter Klatt wrote:
snipNot saying you have to have bulkhead fittings, as long as you
Hi Terry
I would be careful about the 45* turn under the sil before the 90* fitting.
With the fus on its tail, it might create a low spot for water to collect.
FWIW, I ran my lines from your 90* fitting continuing under the sil to the
corner of the square cage and opened up the alignment hole to allow a chafe
tube around the 3/8 line and on to the firewall. Had a drain at both rear
corners for water.
Steve W
Rebel #637
corners for water.
Steve W
Rebel #637
