Doors
Mike Davis
Doors
Post by Mike Davis » Fri Feb 17, 2012 4:52 pm
Received: from server-george (j25.jrc4.jaring.my [161.142.112.39])
by relay16.jaring.my (8.8.8/8.8.8) with ESMTP id SAA26628
for <murphy-rebel@dcsol.com>; Wed, 2 Dec 1998 18:07:58 +0800 (MYT)
Received: from 200.1.1.104 by server-george ([200.1.1.100] running VPOP3)
with ESMTP for <murphy-rebel@dcsol.com>; Wed, 2 Dec 1998 18:01:11 +0800
Message-ID: <36651065.AAEFCE02@airplan.com>
Date: Wed, 02 Dec 1998 18:03:17 +0800
Organization: AirPlan Aviation Technical Services
X-Mailer: Mozilla 4.5 [en] (WinNT; I)
X-Accept-Language: en
MIME-Version: 1.0
To: Rebel List <murphy-rebel@dcsol.com>
Subject: Doors
Content-Type: text/plain; charset=x-user-defined
X-Server: VPOP3 V1.3.0 - Registered to: AirPlan Aviation
Alister,
I saw the photo of your Rebel on the Murphy site, it looks great!
I noticed that the doors on your Rebel are Lexan (?) and I was
wondering about how noisy the cabin is. Some time ago I recall
Bob P mentioning that the Lexan doors on C-FPES (Factory Demo)
cause the cabin to be noisy. I was wondering what your
experience has been and whether you are able to determine if the
primary source of increased noise is due to the rattling of the
lexan against the fuselage or the noise attenuation through the
lexan? Of course, one could always use a good headset and enjoy
the view.
Philip
Rebel 518
Philip Craig
Aviation Planner
Halcrow AirPlan
philip@airplan.com
www.airplan.com
Mike Davis
Doors
Received: from RebelAir@aol.com
by imo19.mx.aol.com (IMOv18.1) id RUXNa15048
for <murphy-rebel@dcsol.com>; Fri, 4 Dec 1998 22:27:58 +1900 (EST)
Message-ID: <fafd13bf.3668a83e@aol.com>
Date: Fri, 4 Dec 1998 22:27:58 EST
Mime-Version: 1.0
Subject: Re: Doors
X-Mailer: Windows AOL sub 19
Hi Philip
Did you get my email on the deburring tool?
Regards
Brian
Mike Davis
Doors
Received: from server-george (j16.jrc24.jaring.my [161.142.110.90])
by relay16.jaring.my (8.8.8/8.8.8) with ESMTP id PAA28040
for <murphy-rebel@dcsol.com>; Tue, 8 Dec 1998 15:34:09 +0800 (MYT)
with ESMTP for <murphy-rebel@dcsol.com>; Tue, 8 Dec 1998 15:35:13 +0800
Message-ID: <366CD712.2CC4D5A0@airplan.com>
Date: Tue, 08 Dec 1998 15:36:50 +0800
MIME-Version: 1.0
Subject: Re: Doors
References: <fafd13bf.3668a83e@aol.com>
Brian,
No, I haven't. Could you please send it again.
Philip
RebelAir@aol.com wrote:
Hi Philip
Regards
Brian
Philip Craig
Aviation Planner
Halcrow AirPlan
philip@airplan.com
www.airplan.com
Jones, Mike
doors
Post by Jones, Mike » Fri Feb 17, 2012 9:21 pm
hi all
has any one tried to make flush doors instead of the overlapping kind in the
manual
mike#007
Mike Betti
Doors
Post by Mike Betti » Sat Feb 18, 2012 2:07 pm
Hi all again,
I'm building doors and plan on hingeing the window at the top. Is there enough room above the door frame and below the wing to attach the hinge flat to the fuselage? Or do I want to attach the hinge to the inside surface of the door opening and the outside surface of the window?
Mike Betti
771E
Doors
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:18 pm
Inside surface of the fus door frame and use the hinge as your doubler on
top of the Lexan to the window frame. Looks nice and clean that way.
Sent: Friday, November 04, 2005 10:55 PM
Subject: Doors
Hi all again,
Mike Betti
771E
Mike Betti
Doors
Post by Mike Betti » Sat Feb 18, 2012 2:18 pm
Thanks Wayne, that's just what I needed.
Sent: Friday, November 04, 2005 11:23 PM
Subject: Re: Doors
Subject: Doors
Hi all again,
flat
Mike Betti
771E
Mike Betti
Doors
Is the riveting through the lexan done just as with sheet aluminum? Std size
holes and pull rivets tight?
Also, is it std practice to seal down the door skin to the frame work?
Mike Betti
771E
Subject: Re: Doors
Subject: Doors
Hi all again,
flat
Mike Betti
771E
Doors
I always open the lexan holes from the #30 of the rivet size to 5/32 so no
stress is put on it when the rivets are pulled.
If you're concerned with water leakage...consider the door and window are
under the wing. Pretty much a non-issue. If you are refering to the alum
skin to the alum frame of the lower section of the door. Epoxy just like all
the other bulkhead to skin joints you've made.
Sent: Saturday, November 05, 2005 8:01 PM
Subject: Re: Doors
size
Mike Betti
771E
Subject: Re: Doors
on
Subject: Doors
Hi all again,
flat
Mike Betti
771E
Doors
Post by Ken » Sat Feb 18, 2012 2:18 pm
FWIW in addition to Wayne's comments I used aluminum "pop" rivets with
aluminum mandrels so that the rivets didn't expand radially so much and
so that they didn't pull as tight as avex. Probably overkill but it's a
thought.
Mike Betti
771E
Mike Betti
Doors
Thanks Wayne,
No, the reason I ask about the sealant is due to a comment you made recently
that maybe I don't understand.
You wrote:
Proseal does a good job. Rivet it together and leave clamped with spring
clamps around the perimeter till it cures. Clean the edge with a knife
afterwards. U are referring to the door jam overlap on the door skins where
you reinforce with .032 or similar?
What do you mean here?
Mike Betti
771E
Sent: Saturday, November 05, 2005 7:11 PM
Subject: Re: Doors
all
Subject: Re: Doors
size
Mike Betti
771E
Subject: Re: Doors
on
Subject: Doors
flat
Mike Betti
Doors
I guess I never gave the seats so much thought. But I did see a brief
goverment movie clip today showing a 4 engine airplane of some sort climb
out at about 75 degrees and then about 5 seconds later hit the ground at
about a 90 degree angle!!
Sent: Saturday, November 05, 2005 9:13 PM
Subject: Re: Doors
thought.
size
Mike Betti
771E
Doors
He was referring to the SR and I >THINK< it has skin doublers like I did on
Howard's Rebel doors. Maybe I'm just referring to the doors I did!
The Rebel had you cut the door skins to fit the frames and then add .032
doublers to rivet between the skin and frame to be the door gap filler. We
took it a step further and left the door skin oversize and put the .032
behind it, bonded the two together with Proseal to reinforce. Makes for a
much cleaner looking assembly with a seam free door skin instead of strips
of .032 with cut lines showing on the corners.
Sent: Saturday, November 05, 2005 10:43 PM
Subject: Re: Doors
Thanks Wayne,
recently
where
Mike Betti
771E
Subject: Re: Doors
no
are
all
Subject: Re: Doors
size
Mike Betti
771E
Subject: Re: Doors
doubler
on
hinge
surface
Mike Betti
Doors
The Elite is the same way.
Sent: Saturday, November 05, 2005 9:54 PM
Subject: Re: Doors
on
Subject: Re: Doors
Thanks Wayne,
recently
where
Mike Betti
771E
Subject: Re: Doors
no
are
alum
like
all
Subject: Re: Doors
size
doubler
on
hinge
surface
Mike Betti
Doors
Does one put some sort of seal on the gap filler?
Mike Betti
Subject: Re: Doors
on
Subject: Re: Doors
Thanks Wayne,
recently
where
Mike Betti
771E
Subject: Re: Doors
no
are
alum
like
all
Subject: Re: Doors
size
doubler
on
hinge
surface
