Well said. Thought this was the place to help each other out, building airplanes :)
Jeff
Date: Tuesday, November 1, 2005 1:40 pm
Subject: Re: Yukon
Didn't mean to get a collection plate going...was just making a
statementoff the cuff, that if someone out there thinks they can
do a better
job...ante up to the plate. Been some slanderous postings in the
past little
while here on dcsol that had no business being laundered here and
I didn't
want MAM's decission to add to their product line to start another
one.
From: "Kevin Brennan" <kevinjbrennan@sbcglobal.net>
Sent: Tuesday, November 01, 2005 3:39 PM
Subject: Re: Yukon
see that
the wing is the basically the same as the SR2500,rudderetc.stab is the same design as Elite/Moose as are the elevator, fin,(you canNothing new here and I'm sure all the SB's will be incorporatedtabs haveeven see the elevator horn SB in the drawing). I even noted thethrough.Nobeen cut off the bottom fin doubler where the stinger comes outbetween> the Elite and the SR in length. I'm pretty sure darntabs..no cracks! The fuselage is obviously going to be somewhere
nearly every
bulkhead,models, withwing spar, rib, extrusion will be duplications of existing
verytooling..thinner> gauge alum.few new parts that if they are any different will be samea hugeThe other option is to pool all your money together, give Darrylyourself.> Everyone has a price...especially after 20 yrs ( atrelief and buy him out, and then you can make all the decisions
least I did!! ) )it arn'tWayne
To:
Sent: Tuesday, November 01, 2005 2:15 PM
Subject: Re: Yukon
If you take the SR2500 (non-Moose) and put a 180 HP engine on
youmanufacturing> perspective wouldn't it be easier to bring back theabout at the same place as this Yukon in performance? From a
SR2500 as a product.enforcement, tailWith any new design there are issues.. i.e. elevator re-Why go thruwheel, main gear, (look at the list of service bulletins) etc.have thethe learning curve AGAIN. If they brought back the SR2500 theylearning curve,learning curve behind them, the cost associated with the
thefix some ofcustomer acceptance, and the design is proven. If they want toturner onthe issues and give it a new name, fine, call it the SR2600!Rick Muller
SR70
down onfront.
thebuilders:> > >suggestions..I saidengine onwhy
ityears andand
checkput on thethe TCregistered @than theMoosewould stillSR/Moose.slightly> > > -> > > shrunk SR2500!want180Hp to
210Behalf Ofthe Yukon.interested ininteresteddfultz17086@earthlink.net> > > -> > > >---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
-----------------------------------------------------------------List archives located at: https://www.dcsol.com/login
