Rebel Rudder
Rebel Rudder
So, I very very carefully read through the section of the manual on the Rebel tail feathers as that is where the build was to start.
Then, I very very carefully measured and drilled the rudder parts as per the manual and took great care to get the parts all lined up and fitting right.
So far so good
Next came the rudder assembly as per the manual. Thus, the rudder horn was neatly and properly riveted to the spar cap in a way that would make the workmanship of those who built the steel riveted side plates of the Titanic look like the work of infants building a Meccano set--you know where this is going right?
Again all went well.
Next came my attempt to rivet the horn and spar cap assembly to the rudder spar.
Thats when I discovered that a couple of the rivets used to attach the the cap to the spar could not be inserted in place, and pulled, because of interference from a couple of rivets used to attach the horn to the cap and about which the manual offered no caution; indeed it was as silent as a tomb on the subject.
Thats when I nearly had a ##!!0&%##@/!!!!!! bird
Has this happened to anyone else? if it has I would sure appreciate any fix that was dreamed up. But somehow I just know in my bones that it's into the hip pocket and out with the wallet to buy a new spar and cap to redo the whole 30 hour effort.
Right?
I thought so!
Sympathy, and expressions of shock grief and horror, may be sent to the undersigned.
Brian Breathnach
779R
So far so good
Right?
I thought so!
Brian Breathnach
779R
Rebel Rudder
brian
can you remove the rivets that are in the way and put back after the others
are installed, or
sometimes if you pull the rivet slowly with low air pressure and push really
hard on the rivet gun you can get the offending rivet in place the give it
one last hard pull with more air pressure to finish it off
mike#007
Brian Breathnach
Sent: Monday, October 31, 2005 2:09 AM
Subject: Rebel Rudder
So far so good
going right?
spar.
on the subject.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
are installed, or
mike#007
Brian Breathnach
So far so good
going right?
spar.
on the subject.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
rebel rudder
What I have done when absolutely backed into a corner on this issue is to carefully knock out the mandrel in a new rivet, shorten the rivet slightly, reinsert the mandrel and pul the shortened rivet. The caution of course, is that there must be adequate rivet barrel to head up properly and only minimal shortening is possible.
Another help would be to knock out the offending (set) rivet mandrel and gain a small amount of reach for the new rivet. If you were concerned about shear a section of mandrel could be reinserted with epoxy to fix it. I believe Darryl does not count on the mandrel when designing.
I don't really like to do either of the above but this does occur ocassionally and my sense is that disassembly creates more risk of strength compromise than the above. I would however consider carefully in high stress locations. As always, the risk of the decision is yours.
Rebel Rudder
Brian,
I ran into the same problem, and was equally as pi$$ed off about the manual.
It is the first bit of education you receive that the manual is a piece of
junk. You will learn that pretty quick.
I hadn't pulled any rivets before I realized the interference problem. What
I did was to counter bore slightly the inside of the holes for the 2
offending rivets that go through horn and end plug, and used the shorter SS
rivets in those 2 locations. When pulled, the shop head is almost flush to
the inner surface of the plug and the opposing rivets from the side will
clear them. As I remember, this problem is caused by the the hole location
of the two side rivets that are located by the rudder (or elevator) skin.
With the remaining radialy spaced rivets you can locate them far enough away
from the end of the plug that there is no clearance problem. On the rest of
the control surfaces I changed those hole locations slightly. If you counter
bore the inside of those 2 holes, use a drill press and secure the end plug
well. The drill bit will grab and want to go all the way through. If you
have an actual counter bore bit, even better.
Date: Sun, 30 Oct 2005 23:08:55 -0800
right.
So far so good
spar.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
rebel rudder
I was told by MAM that the airplane is designed with 10% extra rivets. So I would think it's alright to rig one once in the while like Ralph mentions.
Mike Betti
771E
Mike Betti
771E
Rebel Rudder
I know it's not exactly pretty, but it's not that visible on the bottom of
the rudder... drill out the offending rivets and install them backwards,
from the inside out.
195SR
Sent: Sunday, October 30, 2005 10:08 PM
195SR
right.
So far so good
spar.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Rebel Rudder
Not an option Mike. Needs to be smooth as it rotates above the hinge
bracket. In backwards would leave the "shop" heads working like a baseball
card in your spokes!
Sent: Tuesday, November 01, 2005 5:15 PM
Subject: Re: Rebel Rudder
wasI know it's not exactly pretty, but it's not that visible on the bottom of
195SR
right.
So far so good
rudderneatly and properly riveted to the spar cap in a way that would make the
thespar.
ascap to the spar could not be inserted in place, and pulled, because of
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Rebel Rudder
OK, I was picturing it like the Moose rudder horn... wouldn't interfere with
the hinging on a Moose.
Sent: Tuesday, November 01, 2005 1:28 PM
195SR
per
fitting
right.
So far so good
Next came the rudder assembly as per the manual. Thus, the rudder hornrudderneatly and properly riveted to the spar cap in a way that would make
Next came my attempt to rivet the horn and spar cap assembly to thethespar.
Thats when I discovered that a couple of the rivets used to attach theascap to the spar could not be inserted in place, and pulled, because of
and about which the manual offered no caution; indeed it was as silenta tomb on the subject.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
__________ NOD32 1.1270 (20051101) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
Rebel Rudder
Rebel rudder horn goes right on the bottom similar to the Moose tailwheel
steering arm. This sits right on top of the rudder pivot. Only clearance
available is for one of my nylon pog to keep even the smooth rivet heads
from wearing into the pivot bracket.
Sent: Tuesday, November 01, 2005 9:21 PM
withOK, I was picturing it like the Moose rudder horn... wouldn't interfere
baseballthe hinging on a Moose.
backwards,card in your spokes!
thefrom the inside out.
195SR
horn
knowwas
therudder
ofthe
cap
silent
anyas
it's
http://www.eset.com
Rebel Rudder
Hi Mike,
Thank you for the prompt response.
Have established that the absence of a mandril in a rivet does not affect
the safety of the kit so the intent is to remove the mandril and that will
allow me to insert and pull the appropriate rivets. Being new to the build
experience I was/am intrigued by the low air pressure and hard push
technique you describe below. Will keep that in mind for sure.
thanx again Mike
Brian
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Tuesday, November 01, 2005 4:31 AM
Subject: RE: Rebel Rudder
thanx again Mike
Brian
othersbrian
reallyare installed, or
thehard on the rivet gun you can get the offending rivet in place the give it
mike#007
Brian Breathnach
right.manual and took great care to get the parts all lined up and fitting
wasSo far so good
Titanicneatly and properly riveted to the spar cap in a way that would make the
islook like the work of infants building a Meccano set--you know where this
andgoing right?
spar.
tombabout which the manual offered no caution; indeed it was as silent as a
fixon the subject.
thethat was dreamed up. But somehow I just know in my bones that it's into
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Rebel Rudder
Most of the mandrels "ping" right out of the stainless rivets when the
mandrel breaks anyhow.
Another trick is the old plastic mallet on the air riveter head as you
slowly pull the rivet...to drive the rivet into place as the shop head
forms.
Sent: Monday, October 31, 2005 11:29 PM
forms.
itHi Mike,
thanx again Mike
Brian
othersbrian
can you remove the rivets that are in the way and put back after thereallyare installed, or
sometimes if you pull the rivet slowly with low air pressure and pushhard on the rivet gun you can get the offending rivet in place the give
thistheone last hard pull with more air pressure to finish it off
mike#007
Brian Breathnach
Then, I very very carefully measured and drilled the rudder parts as perright.manual and took great care to get the parts all lined up and fittingwasSo far so good
Next came the rudder assembly as per the manual. Thus, the rudder hornTitanicneatly and properly riveted to the spar cap in a way that would make the
workmanship of those who built the steel riveted side plates of thelook like the work of infants building a Meccano set--you know where
rudderisgoing right?
thespar.
theandcap to the spar could not be inserted in place, and pulled, because of
interference from a couple of rivets used to attach the horn to the captombabout which the manual offered no caution; indeed it was as silent as afixon the subject.
Has this happened to anyone else? if it has I would sure appreciate anythethat was dreamed up. But somehow I just know in my bones that it's intohip pocket and out with the wallet to buy a new spar and cap to redo
Right?
I thought so!
undersigned.
Brian Breathnach
779R
rebel rudder
Hi Ralph,
Your prompt response is much appreciated.
Have confirmed your thought on the absence of a rivet mandrel (para two
below) and I will likely go that way.
Thank you for the feedback
Brian
Sent: Tuesday, November 01, 2005 5:27 AM
Subject: rebel rudder
Brian
carefully knock out the mandrel in a new rivet, shorten the rivet slightly,What I have done when absolutely backed into a corner on this issue is to
gain a small amount of reach for the new rivet. If you were concerned aboutAnother help would be to knock out the offending (set) rivet mandrel and
ocassionally and my sense is that disassembly creates more risk of strengthI don't really like to do either of the above but this does occur
Rebel Rudder
Hi Jesse,
Thanks for the feedback.
Im new to this building game so that will explain my curiosity about a
"counter bore." If you wouldnt mind Jesse could you provide a little more
explanation on the concept as a means of keeping me out of trouble when
building the elevators/fin.
Many thanks
Brian
Sent: Tuesday, November 01, 2005 9:33 AM
Many thanks
Brian
manual.Brian,
WhatIt is the first bit of education you receive that the manual is a piece of
SSI did was to counter bore slightly the inside of the holes for the 2
awayrivets in those 2 locations. When pulled, the shop head is almost flush to
offrom the end of the plug that there is no clearance problem. On the rest
counterthe control surfaces I changed those hole locations slightly. If you
plugbore the inside of those 2 holes, use a drill press and secure the end
rudderwell. The drill bit will grab and want to go all the way through. If you
right.
So far so good
thespar.
fixabout which the manual offered no caution; indeed it was as silent as a
Right?
I thought so!
undersigned.
Brian Breathnach
779R
rebel rudder
Thanks Mike--looks like that will be the route I will go
Brian
Sent: Tuesday, November 01, 2005 10:54 AM
Subject: Re: rebel rudder
Brian
I would think it's alright to rig one once in the while like Ralph mentions.I was told by MAM that the airplane is designed with 10% extra rivets. So
carefully knock out the mandrel in a new rivet, shorten the rivet slightly,Mike Betti
771E
On Tue, 1 Nov 2005 08:27:39 -0500, rebel-builders@dcsol.com said:What I have done when absolutely backed into a corner on this issue is to
Rebel Rudder
Hi Wayne,
Thanx for the info.
Im new to building so that explains this question. Does "ping" mean that the
mandrel removes itself from the rivet leaving a hole right tru the body of
the rivet? Also if you could elaborate on the use of the "plastic mallet on
the air riveter head..." that would be great. Is the idea to actually whack
the riveter head during the process of pulling the rivet?
Thank you
Brian
Sent: Tuesday, November 01, 2005 8:39 PM
Thanx for the info.
Thank you
Brian
affectMost of the mandrels "ping" right out of the stainless rivets when the
forms.
Hi Mike,
willthe safety of the kit so the intent is to remove the mandril and that
buildallow me to insert and pull the appropriate rivets. Being new to the
giveexperience I was/am intrigued by the low air pressure and hard push
thanx again Mike
Brian
othersbrian
theitone last hard pull with more air pressure to finish it off
mike#007
Brian Breathnach
perRebel tail feathers as that is where the build was to start.
horntheright.manual and took great care to get the parts all lined up and fittingSo far so good
thewasneatly and properly riveted to the spar cap in a way that would make
capthisTitanicworkmanship of those who built the steel riveted side plates of thelook like the work of infants building a Meccano set--you know whererudderisgoing right?
Thats when I discovered that a couple of the rivets used to attach thecap to the spar could not be inserted in place, and pulled, because of
aandabout which the manual offered no caution; indeed it was as silent as
anytombon the subject.
intofixthat was dreamed up. But somehow I just know in my bones that it's
thethethehip pocket and out with the wallet to buy a new spar and cap to redowhole 30 hour effort.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
