putting lid on tank tomorrow
Any last words of advice before I cap off my first fuel tank? I'm pretty
sure I goobered up all the holes pretty good. I made some .032 shims to put
in where the main skin will slide under tank skin at stringer and rib
locations. I did a trial fit of the tank skin after installing the tank
bulkheads with proseal and found that the hole alignment along the top of
the bulkheads had shifted a bit due to the proseal now between the bulkheads
and ribs. I just ran the drill through again. There will be plenty of goop
to take up the slack. Any estimates on how much proseal to mix for sticking
the top on? I have 4 bays, I mixed 66 cc total (base and hardener) for the
bottom and had barely enough. I was using the squishout on the inside from
each rivet to coat subsequent rivets, but obviously I won't be able to do
that this time. That brings up another question: you get a long slug of
proseal hanging off each rivet on the inside, and when installing the tank
top these will remain. They come off rather easily because the rivets have
not been cleaned, so do they end up floating around in your tank clogging
things up? I suppose one could clean/scotchbright each rivet, but that seems
kind of ridiculous.
kind of ridiculous.
Hi Jesse !
Of course, you'll be turning the wing over as soon as you finish
all the rivets - this should help the ProSeal to settle back onto
the top, and prevent sagging at the ribs.
The seal around the stringers is most critical - it's best
to leave space around the J cutouts, so ProSeal can squeeze out
all around them - it's the PS that gives the seal, and more gives
more flex later. Many use J-cut plates on both sides of the
bulkhead, filled with PS, like an oreo cookie - again, lots of
PS, so it squeezes out all around.
Some builders have put ProSeal on the ribs & bulkheads to build
up a fillet, putting on a layer of Saran Wrap, then installing the top
with clecoes, and inverting the wing. When the ProSeal sets, remove
the top & Saran Wrap, trim the fillets, rough them up with scotchbrite,
and put the top on with more PS - the idea is that the pre-formed
fillets give a better seal because of larger surface area, and you
get to see what the inside would have looked like if you didn't
do this step ! :-)
do this step ! :-)
putAny last words of advice before I cap off my first fuel tank? I'm pretty
bulkheadsin where the main skin will slide under tank skin at stringer and rib
stickingand ribs. I just ran the drill through again. There will be plenty of goop
seemsthe top on? I have 4 bays, I mixed 66 cc total (base and hardener) for the
kind of ridiculous.
Did you drill a hole through the bottom stringers at the wing root so
fuel doesn't get trapped ahead of each stringer? Or maybe that is in the
manual now??
manual now??
Thanks Bob and Ken,
I just finished the top install. It took me and a friend most of the day,
but I'm happy with it. We'll see how happy I am after the pressure test.
Ken, the manual does have you cut the one bottom stringer short at the root.
Bob, thanks for the wing flip tip. I had actually not thought of that. It
probably mentions that in the manual, but I haven't read the manual since I
began working on the skins, as it is so useless. Anyhow the flip does seem
to get most of the proseal plugs to flop over and stick to the top, as
witnessed on the outboard tank rib flange that is outside the tank. It sure
takes me forever to clean up around all the rivets. Is there a better way
than just scrubbing and scrubbing with acetone and paper shop towels? Maybe
using cloth rags would be better. The heavy duty blue paper towels shred
pretty quick on the rivet heads. It took me about 2 hours just for cleanup
Be careful with that clean up! I only clean the smears on the skin and leave
the rivets alone. Once the proseal has tacked up for a couple days I use my
finger nail and remove the "o-ring" around each rivet head. Once things have
hardened for a few weeks then I'd scrub with scotchbrite for a final
cleaning before paint. My fear has always been that acetone is going to get
under the heads of the rivets and be detrimental to the proseal.
Sent: Wednesday, September 14, 2005 9:57 PM
Subject: Re: putting lid on tank tomorrow
root.Thanks Bob and Ken,
IBob, thanks for the wing flip tip. I had actually not thought of that. It
surebegan working on the skins, as it is so useless. Anyhow the flip does seem
Maybetakes me forever to clean up around all the rivets. Is there a better way
Hi Jesse
Go to your local industrial supplier and get some 3M Wypall X60 wipes, they come
in a box of 180 for somewhere around $20 and are great for the job. We
discovered them before doing our first tanks and the roll of blue towels quickly
got moved to the garage for when I'm tinkering with cars.
Congrats on sealing up that tank, a big milestone!
Jesse Jenks wrote:
David A. Ricker
Fall River, Nova Scotia
Canada
Jesse Jenks wrote:
--Thanks Bob and Ken,
David A. Ricker
Canada
Take the cutout from the wing skin, cut some holes in it so you can get
your hand inside, wax it so it doesn't stick, then Proseal and cleco it in
place. Use your finger to form a nice flange on all areas inside. Then
remove the wing skin after a couple of days any scuff up the Proseal surface
with Scotchbrite. Then Proseal the tank skin proper in place. Can't
remember how much I used. I just mixed what seemed like enough. Try to
keep the ambient temperature cool so you have more working time. Don't
start at 9 o'clock at night!
Al
Al
Too late now. I'll remember that for the next wing. I am not planning on
painting, so I'm always thinking "clean".
Date: Wed, 14 Sep 2005 21:59:17 -0400
leave
have
day,Thanks Bob and Ken,
I just finished the top install. It took me and a friend most of theroot.but I'm happy with it. We'll see how happy I am after the pressure test.
Ken, the manual does have you cut the one bottom stringer short at theItBob, thanks for the wing flip tip. I had actually not thought of that.sinceprobably mentions that in the manual, but I haven't read the manual
Iseembegan working on the skins, as it is so useless. Anyhow the flip doessureto get most of the proseal plugs to flop over and stick to the top, as
witnessed on the outboard tank rib flange that is outside the tank. Itwaytakes me forever to clean up around all the rivets. Is there a betterMaybethan just scrubbing and scrubbing with acetone and paper shop towels?cleanupusing cloth rags would be better. The heavy duty blue paper towels shred
pretty quick on the rivet heads. It took me about 2 hours just forJesse
