Spring Gear Thoughts
pequeajim
Post by pequeajim » Sat Feb 18, 2012 10:59 am
I searched back in the archives for information about using the spring gear
and it seems that most folks are not choosing this option for a couple of
reasons.
Failure issues with service out of rough fields.
Complexity when using floats (putting them on and off)
The airplane that I am looking at already has the spring gear installed.
I know there are some mods to reinforce the gear, but but does this solve the
problems that people are seeing? Is the main reason for not using the sp
because of the float issue?
I will primarly fly off of grass and a paved surface, not water for now.
I now that this has been talked about a lot, but I want to look at it from
the perspective of a buyer of an airplane that already has this installed.
What am I getting myself in to?
Jim!
Post by Drew Dalgleish » Sat Feb 18, 2012 10:59 am
reasons.
Jim!
Hi Jim I just have the regular gear with the die spring mod so don't put
too much weight on my opinions. The spring gear wasn't available when I
bought my kit #247 so you can see one of the reasons it's not popular is
because it wasn't available. There's quite a few mods to change over and
the only advantage is a slightly faster cruise so I think few builders if
any builders have flown the same plane on both gears. The main
disadvantages are incresed build time and reduced usefull load. Read
carefully about the spring gear failures you see in the archives I think
most of them are on moose' and maybe elites. I can't recall a rebel spring
gear failure. A grass strip is not a rough field. You said you were pumped
about this plane. I think the fact it has the spring gear should not be a
deal breaker or even a factor unless you want to use it as a bargaining ploy.
Scott Aldrich
Post by Scott Aldrich » Sat Feb 18, 2012 10:59 am
Jim, like Drew said if you see fussing about the spring gear on the Moose it
is completely different than the Rebel - at least what I can tell from the
pictures.
The Rebel looks to be a one piece unit with radius blocks. It should be a
much better set up than what we have on the Moose - depending on the beef of
the structure that the radius blocks mount into of course.
The Moose has two separate gear legs.
FWIW
Scott
Moose 174
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Drew
Dalgleish
Sent: Wednesday, September 07, 2005 8:33 PM
Subject: Re: Spring Gear Thoughts
reasons.
Jim!
ploy.
Bruce Georgen
Post by Bruce Georgen » Sat Feb 18, 2012 10:59 am
Jim,
Spring gear will not effect your floats. I had spring gear before adding the amphips with out a problem. Make sure your spring gear has the mod MAM put out several years ago. You can find it on their web site. It consist of two pieces of 2" aluminum angle that reinforces and caps the carry through the gear are attached to. It is and easy install if you doesn't have it, but they are a must.
I had no problem with the SG on a dirt strip where I fly out of but never took it in fields like I would my Kitfox. And I would not use by choice but the partially assembled kit I bought came with the SG. Wayne makes a better gear if you don't like the factory bungee.
Bruce
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
Post by Bob Patterson » Sat Feb 18, 2012 10:59 am
Sorry Scott - the Rebel spring gear is 2 separate legs, held on
by 3 bolts - it makes the Moose gear look positively sturdy and
massive !
it
pictures.
FWIW
Scott
Moose 174
Dalgleish
gear
reasons.
from
installed.
Jim!
ploy.
Scott Aldrich
Bummer, I couldn't tell from the picture, it looked like it went flat and
across.
The Grove main gear may be the way to go on the Moose someday, unless MAM
comes up with something better.
Scott
Patterson
Sent: Thursday, September 08, 2005 10:10 AM
massive !
it
pictures.
FWIW
Scott
Moose 174
Dalgleish
gear
reasons.
from
installed.
Jim!
ploy.
Post by Wayne G. O'Shea » Sat Feb 18, 2012 11:24 am
How many pictures do you want to see Drew???..and how many gear legs do you
think I've collected under my work bench to use as forks for my tractor
bucket?? Takes nothing more than a windrow of snow to remove them from the
plane.
:O)
Sent: Wednesday, September 07, 2005 10:32 PM
gear
reasons.
from
installed.
Jim!
ploy.
Mike Betti
Post by Mike Betti » Sat Feb 18, 2012 11:24 am
I haven't been following this the gear issue much and don't know much about
it. My Elite has the solid gear legs in the kit. Are these what I'm hearing
bad things about? Is there something else out there I can purchase that
would work better for the Elite?
Mike Betti
771E
Sent: Saturday, September 10, 2005 3:49 PM
you
plane.
:O)
gear
reasons.
solve
sp
from
installed.
Jim!
put
spring
pumped
ploy.
Guess you are kinda stuck on the Elite..unless of course you modify the
floor bulkheads for drag brace pic ups... to convert it to the cub style
gear of the Rebel. Other than that, solid block inserts for the saddle bolts
inside the 2" square tubes...attention to detail on floor layering and I
would be temped to use metal vs alum for that reinforcing angle in the MAM
'"fix" to negate pull thru.
Sent: Saturday, September 10, 2005 5:09 PM
about
hearing
Mike Betti
771E
you
plane.
:O)
gear
installed.
now.
from
installed.
put
is
if
think
spring
pumped
ploy.
Mike Betti
I'm not familiar enough to start engineering new gear so I will stick with
the MAM setup. Most runways I frequent are in good shape.
Mike Betti
771E
Sent: Saturday, September 10, 2005 5:18 PM
bolts
about
hearing
Mike Betti
771E
you
plane.
:O)
gear
installed.
now.
from installed.
is
if
think
ploy.
Post by Bob Patterson » Sat Feb 18, 2012 11:24 am
Hi again Mike !
It would be well worth your time to have a peek in the archives -
it won't take you long to machine up solid aluminum inserts to go
inside those square tubes ---- it's not just the smooth runways,
you have to worry about braking loadings too ! ;-)
Mike Betti
771E
bolts
MAM
about
hearing
Mike Betti
771E
do
tractor
from
installed.
now.
it
don't
when
popular
is
builders
if
think
Alan Hepburn
Post by Alan Hepburn » Sat Feb 18, 2012 11:24 am
The trike version of the Elite has a copy of the 2 x 2 carry through
structure mounted aft of the standard one. That would make a very solid
attachment for the rear of a standard Rebel gear. Parts are presumably all
available from Murphy. In fact, I even have all the parts, if anybody is
interested, except the 2 x 2s themselves which I used elsewhere. Dosen't
look as nice as the spring gear, but boy is it stronger.
Al
mbetti
Post by mbetti » Sat Feb 18, 2012 11:24 am
I already got those blocks installed.
On Mon, 12 Sep 2005 22:19:25 -0400, rebel-builders@dcsol.com said:
Hi again Mike !
Mike Betti
771E
bolts
MAM
about hearing
do
tractor
from
the installed. now.
it
don't
when
popular
is and
builders
if think a
Keith B. Oliver
Post by Keith B. Oliver » Sat Feb 18, 2012 11:24 am
What can you do after the fact besides MAM's upgrade ??
mbetti@up.net
Sent: Tuesday, September 13, 2005 7:53 AM
Hi again Mike !
with
Mike Betti
771E
style
bolts
MAM
about hearing
that
do
tractor
from
the installed.
this
for
now.
it
don't
when
popular
is
over
builders
if
Read
think
not
If you really wanted to change over to a strut braced cub style gear....bolt
the float attach fittings in place of the spring gear leg saddles (or make
up something similar yourself). Use them as the main gear leg attach pivots.
Then on one of the bulkheads in the floor reinforce it to take a similar
bracket for the drag brace. You can install the wishbone tubes fairly easily
by drilling the tubes from the pedal side with a 6" bit, or make a bolt on
bracket for same.....similar to the main gear attach (could even do a combo
bracket for main leg and wishbone tube) and bolt the wishbone tube to it
instead. Would take a bit of work...but nothing like fishing those 2" square
tubes out when the spring gear lets you down....not to mention the prop,
fuselage and wing damage.
Sent: Tuesday, September 13, 2005 5:18 PM
Subject: RE: Spring Gear Thoughts
mbetti@up.net
Hi again Mike !
with
Mike Betti
771E
style
saddle
MAM
much
that
legs
do
tractor
from
this
using
for
at
it
don't
when
popular
over
builders
Read
rebel
were
not
