Lycoming O-540, 250 hp, showed a high of about 18 US gph on climbout, so
the standard lines should be more than adequate ....
....bobp
---------------------------------orig.----------------------------------------
At 09:06 PM 3/8/00 -0500, you wrote:
fuel line! If you are running a Lycoming, acceptable minimum size should beHello Frank,
Got your mail off the archives with reference to your gascolator to carb
3/8"(you will find 1/2" on a Cessna). A 912 Rotax would work find with the
1/4" one you have! The next thing you should buy is a builders manual from
the RAAC Headquarters (1-800-387-1028) or find someone that will lend you
one! (Sorry but I lend nothing anymore, as it appears I may have been taken
for an engine mount I lent someone to use to make a jig! I hope not, but 3+
years is a long time!) This reference manual will tell you everything you
need to do to pass your final inspection, placards etc. Note that you also
need "firesleeve" over your fuel line and some inspectors want it over your
oil cooler lines also! The main thing with the fuel line is that you
ACTUALLY do a fuel flow test, with minimum fuel in the tanks and the
aircraft in a nose high attitude! You remove the line at the carb and must
keep it at the same height as the inlet. Also, the inlet screen (from the
carb inlet) should be on the end of the fuel line. You must get a minimum of
150% of the full power consumption requirement for the engine, flowing out
of your fuel line (on a gravity feed system). Anyone on the list do a fuel
flow on their SR2500 with 3/8 factory lines, finger strainers, etc???(same
size as supplied for rebel) Will it supply your 360HP M14P???? My 340HP
Supercharged Lycomings on the UTVA's burn 52 U.S. Gallons per hour at full
power!!!(per lyco's engine manual) This would require a full flow test
result of 78 G.P.H. if gravity feed, but with a pump you only need (I
believe)125%(or 115%) of consumption, so would need 65 G.P.H. On the last
Rebel with both tanks turned on I got 42 U.S G.P.H. I guess with a pump you
could suck some more out of the tanks. Someone let me know your experience
with the SR fuel flow before my Buddy's is to far along!! We may want to
change the fuel outlets on the wing tanks to take a larger finger screen.
the list was lost into cyberspace. Go to the website and resubscribe!Don't forget the Rebel Builders meeting at Brampton Sunday March 12th - 1PM!
Frank you may be one of the few that didn't get restored to the list, when
(Sorry butBlue skies,
<!DOCTYPE HTML PUBLIC "-//W3C//DTD W3 HTML//EN">
<HTML>
<HEAD>
<META content=text/html;charset=iso-8859-1 http-equiv=Content-Type>
<META content='"MSHTML 4.72.3612.1706"' name=GENERATOR>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT color=#000000><FONT size=3>Hello Frank,</FONT></FONT><FONT
size=3></FONT></DIV>
<DIV><FONT color=#000000><FONT size=3></FONT></FONT><FONT
size=3></FONT> </DIV>
<DIV><FONT color=#000000 face="" size=3>Got your mail off the archives with
reference to your gascolator to carb fuel line! If you are running a
Lycoming, acceptable minimum size should be 3/8"(you will find
1/2" on a Cessna). A 912 Rotax would work find with the 1/4" one you
have! The next thing you should buy is a builders manual from the RAAC
Headquarters (1-800-387-1028) or find someone that will lend you one!
mountI lend nothing anymore, as it appears I may have been taken for an engine
finalI lent someone to use to make a jig! I hope not, but 3+ years is a long time!)
This reference manual will tell you everything you need to do to pass your
Theinspection, placards etc. Note that you also need "firesleeve" over
your fuel line and some inspectors want it over your oil cooler lines also!
Also, themain thing with the fuel line is that you ACTUALLY do a fuel flow test, with
minimum fuel in the tanks and the aircraft in a nose high attitude! You remove
the line at the carb and must keep it at the same height as the inlet.
<STRONG>Anyoneinlet screen (from the carb inlet) should be on the end of the fuel line. You
must get a minimum of 150% of the full power consumption requirement for the
engine, flowing out of your fuel line (on a gravity feed system).
peron the list do a fuel flow on their SR2500 with 3/8 factory lines, finger
strainers, etc???(same size as supplied for rebel) Will it supply your 360HP
M14P???? My 340HP Supercharged Lycomings on the UTVA's burn 52 U.S. Gallons
<STRONG>Someone lethour at full power!!!(per lyco's engine manual)</STRONG> This would require a
full flow test result of 78 G.P.H. if gravity feed, but with a pump you only
need (I believe)125%(or 115%) of consumption, so would need 65 G.P.H. On the
last Rebel with <STRONG>both </STRONG>tanks turned on I got 42 U.S G.P.H. I
guess with a pump you could suck some more out of the tanks.
whenme know your experience with the SR fuel flow before my Buddy's is to far
along!! We may want to change the fuel outlets on the wing tanks to take a
larger finger screen.</FONT></STRONG></DIV>
<DIV><FONT color=#000000 face="" size=3></FONT> </DIV>
<DIV><STRONG>Don't forget the Rebel Builders meeting at Brampton Sunday March
12th - 1PM!</STRONG></DIV>
<DIV> </DIV>
<DIV>Frank you may be one of the few that didn't get restored to the list,
*----------------------------------------------------*the list was lost into cyberspace. Go to the website and resubscribe!</DIV>
<DIV> </DIV>
<DIV>Blue skies,</DIV>
<DIV>Wayne G. O'Shea</DIV>
<DIV><A href="http://www.irishfield.on.ca">www.irishfield.on.ca</A></DIV>
<DIV> </DIV></BODY></HTML>
