Float pump out cups on 1800's
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:28 am
Hi guys! The real reason I came in from the shop....anybody found a pump
that actually fits these undersize pump out cups Murphy made for the
1800's??? You'd think if you were going to make 'em you'd make them to fit
the standard Beckson pump and not some oddball size that fits nothing on the
market like plugs. and the nice new auto plugs with the check ball built in.
The MAM cups are even smaller than the CAP cups that you use the neck down
adapter on the Beckson pump. I talked with Robin about this a year or so ago
and he told me they neck the pump down with a piece of rad hose. I'm not in
to this adaption stuff and looking to see if anyone has found a pump that
fit in the cups and actually works. Not into making those cup plugs either
with a plastic cap from a chair leg and a piece of bungee....but is someone
knows a pump available will save me a days work and $200 worth of EDO cups
to get me in the water. Some days I wish MAM would just buy off the shelf
items and not make stuff themselves. Can't see a labour/materials savings
when cups and lake-n-air plugs are less than $5 each in quantity.
I will post a list up later tonight or tomorrow of the things I've found,
over the last ~ 32 hours (2 days) of shop time, in need of doing on the
prebuilts for anyone else in the same boat. All in all really happy with
what I've seen in these last few out of the good prebuild factory. About two
FULL days now going over these things. Probably another full one yet before
I can start making spreaders and mounting struts....gotta get the axles
drilled for zerts next...already slotted the torque plates to ease wheel
removal/installation.
Post by Ken » Sat Feb 18, 2012 10:28 am
Hi Wayne
Can't help you but might be able to ease the pain....
If you end up replacing them and you can get a better price on pump out
cups in quantity, I for one still need a set!
Or I might even consider purchasing the MAM cups but your recommendation
for them doesn't sound promising ;)
to fit
on the
built in.
down
so ago
not in
someone
About two
before
Hi Ken! I just spent ~60 hours doing "probono" work on my f-n-laws 701
amphib and one (of the many) thing to get it into tip top shape was to put
some proper pump out cups in the floats and I already bought enough to do my
floats as well...so I have what I need here. They cost $9 cdn each from
Orillia Aviation if you get them to bead the hose attach area which makes it
nice for retention. Pop the hose on and just safety wire. No need to spend
the money, or hassle, on a ss hose clamp. I believe they are $6.25 without
the beading done. The nice formed rubber Lake-n-Air plugs are $5.85 each.
You can get them cheaper from elsewhere and especially in high volume, but I
needed them pronto and just flew over to Lake St. John in the J3 and picked
them up.
I am leaving the cups and a step area access hatch 'till last. Want to get
them on and rigged up and see how much time I have left....or if the field
is even dry enough to get out of here by then. Was doing nicely until this
week+ of rain and we almost sunk a customers Pegastol on amphibs to the
keels, getting it from the runway to the hanger, when he flew it in at 7:45
tonight.
If I do pull the cups, they will be available as I can't see myself reusing
them if nobody can line up a pump that actually fits them. Hopefully someone
will speak up BEFORE I pull them out.... if they know of a source. So far
all the no name, CTC, Beckson, etc that I have measured or tried are all to
large.
Sent: Friday, April 29, 2005 6:16 PM
Subject: Re: Float pump out cups on 1800's
Hi Wayne
to fit
on the
built in.
down
so ago
not in
that
either
someone
cups
shelf
savings
found,
About two
before
Post by Walter Klatt » Sat Feb 18, 2012 10:28 am
Wayne, I have a nice little cheap plastic pump that I got from a
marine shop here, that works great for me. I did have to put a 3
inch piece of vinyl clear hose piece over the end to make it seal
nicely into the pump out hole, but works perfectly for me. It's
also impervious to fuel and oil. Can't remember the brand, but
will check next time out to the hangar, if I don't forget.
Also, I still use the MAM supplied chair leg type caps, with the
attached strings, and believe it or not, have yet to lose a
single one. So no complaints from me on those.
With the suspension pucks, I have mentioned before on the list
that I use the big blue ones, from the Elite nose gear. They are
pretty solid compared to the original small yellow ones, but not
sure how they compare to the new thicker yellow ones.
Sent: Friday, April 29, 2005 10:45 PM
my f-n-laws 701
$9 cdn each from
them up.
on amphibs to the
tonight.
of a source. So far
large.
Hi Wayne
your recommendation
Murphy made for the
'em you'd make them
to fit
on the
with the check ball
built in.
down
so ago
not in
that
either
bungee....but is
someone
cups
just buy off the
shelf
labour/materials
savings
each in quantity.
the things I've
found,
prebuild factory.
About two
before
Thanks Walter! MAM supplied the chair leg caps and a length of 3/8" bungee
for the pull cord that made no sense. I can see drilling a small hole in the
cap for a cord loop similar to the Lake-n-Air plugs though. Maybe I'll do
that if I can pick up some cord and find the pump you are talking about.
I'm going to give these thick yellow rubbers a go and see how the perform.
Suspect they will just ouze out of place like the smaller ones since the
washers are flat and have no cup shape to them to help retain like my
Belleville washer set up.
Sent: Saturday, April 30, 2005 8:55 AM
Subject: RE: Float pump out cups on 1800's
my f-n-laws 701
$9 cdn each from
them up.
on amphibs to the
tonight.
of a source. So far
large.
Hi Wayne
your recommendation
Murphy made for the
'em you'd make them
to fit
on the
with the check ball
built in.
down
so ago
not in
that
either
bungee....but is
someone
cups
just buy off the
shelf
labour/materials
savings
each in quantity.
the things I've
found,
prebuild factory.
About two
before
Del Schmucker
Post by Del Schmucker » Sat Feb 18, 2012 10:28 am
Wayne:
I made an adapter just by getting a ABS reducer/adapter(local hardware) and
making some "Adjustments" to it. It fits very nicely into the bottom of the
pump and reduces to the size of the Murphy pump outs. It may not be as
elegant as some but works well. If I get a chance I will take a picture and
upload it.
Thank you,
Del Schmucker
Information Systems Manager
Keewatin-Patricia District School Board
G. O'Shea
Sent: Friday, April 29, 2005 12:08 PM
Cc: DENNIS FINLEY
Subject: Float pump out cups on 1800's
Bob Fisher
Post by Bob Fisher » Sat Feb 18, 2012 10:28 am
hi walter what dia and thickness are the blue ones? how many did you
use? they need to be tougher than the thick yellow ones those ones
settle in too quickly and one split and fell out thanks fish
my f-n-laws 701
$9 cdn each from
them up.
on amphibs to the
tonight.
of a source. So far
large.
Hi Wayne
your recommendation
Murphy made for the
'em you'd make them
to fit
on the
with the check ball
built in.
down
so ago
not in
that
either
bungee....but is
someone
cups
just buy off the
shelf
labour/materials
savings
each in quantity.
the things I've
found,
prebuild factory.
About two
before
The small diameter bungee cord was supplied to spring load the
water rudders. They should have supplied another thin rope/thread
for the caps. I just did a loop with a knot, and they've been
good the whole time for me. Like I said, I still have yet to lose
a single one. I'll be down to my hangar tomorrow, so hopefully
will remember to check my pump brand.
Sent: Saturday, April 30, 2005 8:19 AM
are talking about.
retain like my
I got from a
have to put a 3
make it seal
for me. It's
brand, but
caps, with the
on the list
gear. They are
ones, but not
my f-n-laws 701
$9 cdn each from
them up.
on amphibs to the
tonight.
of a source. So far
large.
better price on pump out your recommendation shop....anybody found a pump Murphy made for the 'em you'd make them size that fits nothing with the check ball that you use the neck about this a year or piece of rad hose. I'm anyone has found a pump
that making those cup plugs
either bungee....but is and $200 worth of EDO
cups just buy off the
shelf labour/materials
savings each in quantity. the things I've
found, need of doing on the all really happy with prebuild factory. another full one yet struts....gotta get the axles torque plates to ease wheel -------------------------------------------------------
---------- https://www.dcsol.com/login?mode=HTML -------------------------------------------------------
I know the small bungee is for the water rudder (came preinstalled as
well)...I throw those away immediately and install a tension spring. Anyone
that is interested I can supply the CTC part # and how many coils I cut off
to make it work right. Guess I should add that to the "snag" list. Those
water rudder bungees don't make half a season before rotting off.
What came with these and Dennis's prebuilts was 11' of 1/2" bungee cord just
like you get for the main gear on the Rebel. Guess someone read cord and
threw in bungee instead of some small (rope) cord. I grabbed some mower
starter cord today that should do the trick. If you can get the make of the
pump I'll save myself some immediate work and give these cups a whirl for
this season.
Sent: Saturday, April 30, 2005 11:39 PM
are talking about.
retain like my
I got from a
have to put a 3
make it seal
for me. It's
brand, but
caps, with the
on the list
gear. They are
ones, but not
Yeah, I thought 3/8 sounded kind of big for the rudders... You
might as well let us know that CT part number when you get a
chance. I'm still using those bungees on the rudders, but they
are probably overdue to be changed.
BTW, shouldn't you be sleeping...
Sent: Saturday, April 30, 2005 8:48 PM
preinstalled as
"snag" list. Those
rotting off.
grabbed some mower
this season.
spring load the
thin rope/thread
have yet to lose
hopefully
are talking about.
retain like my
I got from a have to put a 3 make it seal for me. It's brand, but
don't forget.
caps, with the
yet to lose a
on the list gear. They are ones, but not -------------------------------------------------------
...sleeping? What is this thing you call sleeping?? LOL
Sent: Sunday, May 01, 2005 12:17 AM
preinstalled as
"snag" list. Those
rotting off.
grabbed some mower
this season.
spring load the
thin rope/thread
have yet to lose
hopefully
don't forget.
yet to lose a
Resend due to server oops!
Sent: Sunday, May 01, 2005 11:59 AM
preinstalled as
"snag" list. Those
rotting off.
grabbed some mower
this season.
spring load the thin rope/thread have yet to lose hopefully don't forget. yet to lose a -------------------------------------------------------
I think the diameter and thickness of my blue ones are the same
as the new yellow ones, but can't be sure. I think I have 6 per
slide. It's pretty greasy in there right now, so kind of hard to
get accurate measurements. But almost 300 hours on these ones,
over about 3 years or so, and still working good.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Fisher
Sent: Saturday, April 30, 2005 6:36 PM
how many did you
ones those ones
thanks fish
I got from a
have to put a 3
make it seal
for me. It's
brand, but
caps, with the
on the list
gear. They are
ones, but not
my f-n-laws 701
$9 cdn each from
them up.
on amphibs to the
tonight.
of a source. So far
large.
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 10:28 am
Wayne,
I bought a suction pump out of a Harbor Freight catalog that fits the cup
perfectly. It's smaller than the standard seaplane pump but I never really had
to pump much more than a few times.
Bruce
Thanks Bruce! Wayne
Sent: Monday, May 02, 2005 3:20 AM
Wayne,
had
Bruce
