hand rivet squeezer
Dale Fultz
hand rivet squeezer
Post by Dale Fultz » Sat Feb 18, 2012 9:50 am
I am in need of a squeezer that I can dimple around firewall and some
other use. Can any of you guys with experience tell which one you prefer
to buy ??? Is one better than another??? Any help would be appreciated
before I buy one that is not right for the job at hand. Thanks Dale
Al Paxhia
hand rivet squeezer
Post by Al Paxhia » Sat Feb 18, 2012 9:50 am
I have two that I really like. The least expensive is the one that has a
male and female die with a nail through it, and pull it with your hand rivet
puller, the other is a pair of vice grips with dimple dies. Both are
inexpensive. Check www.aircraft-tool.com they have other options also.
Al
Sent: Sunday, December 12, 2004 4:33 PM
Subject: hand rivet squeezer
Joel Jacobs
hand rivet squeezer
Post by Joel Jacobs » Sat Feb 18, 2012 9:50 am
I have the two dies and a nail one and it's been working great. You may
already know this but be sure to dimple BEFORE you drill out the holes to
#30. They get bigger when you dimple them..
Joel
Sent: Sunday, December 12, 2004 7:33 PM
Warren & Marg Montgomery
hand rivet squeezer
Post by Warren & Marg Montgomery » Sat Feb 18, 2012 9:50 am
Why hand? Build up the 1/8" holed nut of the pheumatic riveter with tape
to same dia as die, then tape die to nut.
Joel
hand rivet squeezer
Drilling to 1/8" then dimpling gives close to #30
Joel
