elevator end plug rivets
I realized today, well confirmed what I already suspected actually, that
some of the SS rivets mushroomed heads inside the end plug will interfere
with each other. Specifically, the two at the corners of the skin that go
through the spar into the end plug side wall at the horn end will interfere
with the adjacent ones that attach the horn to the end plug. I thought about
this possibility with regards to the AN-3 bolt threads interfering with the
3/16 rivet that goes through the end ribs small flange and lines up exactly
with the bolt coming through the end. I avoided that conflict by locating
those rivets as far away from the ends of the spar as possible. With the
skin corner rivets though, I figured the holes are located already, so I
just drilled them. Bad plan. I haven't riveted anything yet. Any
suggestions? It seems like the manual leads you right into this one. I was
thinking about just riveting the horn to the end plug and then trying to
drill off the mushroomed head enough to get clearance for the other rivet,
but with stainless I don't know if this is possible. I don't see another
option except to leave two rivets out of the horn/end plug connection. Five
S.S. rivets and a 3/16 bolt should be strong enough, but we're talking about
ELEVATORS here!
Get ready for school! Find articles, homework help and more in the Back to
School Guide! http://special.msn.com/network/04backtoschool.armx
ELEVATORS here!
Been a long time since I built an elevator...but a plastic hammer "knocking"
on the riveter, while slowly pulling the rivet, comes to mind to get them
in!
Sent: Saturday, September 18, 2004 11:07 PM
Subject: elevator end plug rivets
in!
interfereI realized today, well confirmed what I already suspected actually, that
aboutwith the adjacent ones that attach the horn to the end plug. I thought
thethis possibility with regards to the AN-3 bolt threads interfering with
exactly3/16 rivet that goes through the end ribs small flange and lines up
Fivewith the bolt coming through the end. I avoided that conflict by locating
aboutS.S. rivets and a 3/16 bolt should be strong enough, but we're talking
ELEVATORS here!
Yeah after it is done you wish the manual had suggested that you rotate
the rivet pattern in the horn 22 degrees to provide clearance. What
Wayne said worked for me in a couple of places on the airframe. Since
the stainless rivets provided by MAM don't expand radially like the Avex
you can usually pull them by hand just a little, remove the puller, then
tap them in a bit farther with a hammer (and perhaps a hollow tube or
piece of wood with a hole slipped over the manual). And repeat a couple
of times.
There's a couple of other non-critical places that have a similar
problem. This technique doesn't work well with the avex rivet but does
work somewhat with cheap aluminum pop rivets if you simply can't get an
avex rivet in.
of times.
avex rivet in.
ELEVATORS here!
Jesse, you've probably heard this before, but it bears repeating.
And that is, read ahead (and I mean way ahead) in the manual and
delay riveting a piece for as long as possible. It also helps to
have a lot of clecos, probably 3 times as many as you think. This
becomes even more important with the wings and fuselage. It may
seem like you are not making progress with all your unfinished
pieces lying around, but you'll soon learn that riveting is
actually the easiest and fastest part of the whole build process.
And of course, research these archives. There are a lot of tips
and mods that can really help you out. If you get to a spot where
you're scratching your head, chances are you are not the first.
Good luck.
Good luck.
[mailto:mike.davis@dcsol.com]On Behalf Of Ken
Sent: Sunday, September 19, 2004 5:04 AM
Subject: Re: elevator end plug rivets
clearance. What
airframe. Since
hollow tube or
And repeat a couple
of times.
have a similar
avex rivet but does
simply can't get an
avex rivet in.
Jesse Jenks wrote:
suspected actually, thatI realized today, well confirmed what I alreadyplug will interferesome of the SS rivets mushroomed heads inside the endof the skin that gowith each other. Specifically, the two at the cornershorn end will interferethrough the spar into the end plug side wall at theend plug. I thought aboutwith the adjacent ones that attach the horn to thethreads interfering with thethis possibility with regards to the AN-3 boltflange and lines up exactly3/16 rivet that goes through the end ribs smallconflict by locatingwith the bolt coming through the end. I avoided thatpossible. With thethose rivets as far away from the ends of the spar aslocated already, so Iskin corner rivets though, I figured the holes areanything yet. Anyjust drilled them. Bad plan. I haven't rivetedinto this one. I wassuggestions? It seems like the manual leads you rightand then trying tothinking about just riveting the horn to the end plugfor the other rivet,drill off the mushroomed head enough to get clearanceI don't see anotherbut with stainless I don't know if this is possible.plug connection. Fiveoption except to leave two rivets out of the horn/endbut we're talking aboutS.S. rivets and a 3/16 bolt should be strong enough,ELEVATORS here!
Do you think I can partially remove the mushroomed head by drilling it off
or grinding?
Is your PC infected? Get a FREE online computer virus scan from McAfee
or grinding?
_________________________________________________________________From: Ken <klehman@albedo.net>
Date: Sun, 19 Sep 2004 08:03:45 -0400
of times.
avex rivet in.
through the spar into the end plug side wall at the horn end willaboutwith the adjacent ones that attach the horn to the end plug. I thoughtthethis possibility with regards to the AN-3 bolt threads interfering withexactly3/16 rivet that goes through the end ribs small flange and lines upwaswith the bolt coming through the end. I avoided that conflict by locating
suggestions? It seems like the manual leads you right into this one. Irivet,thinking about just riveting the horn to the end plug and then trying to
drill off the mushroomed head enough to get clearance for the otherFivebut with stainless I don't know if this is possible. I don't see another
option except to leave two rivets out of the horn/end plug connection.aboutS.S. rivets and a 3/16 bolt should be strong enough, but we're talkingELEVATORS here!
I just looked at it again, and I think I can work something out if I use
5604 (shorter) rivets in the two holes through the horn and end plug. Does
the mandrel have to stay in the SS rivets for shear strength? If not I think
I can knock it out and with the 3/16 long rivet it just might clear.
Alternatively, I could countersink the hole slightly inside the end plug for
the mushroomed head, and file the end of the mandrel down before setting the
rivet.
rivet.
_________________________________________________________________From: "Jesse Jenks" <jessejenks@hotmail.com>
Date: Sun, 19 Sep 2004 08:05:40 -0700
or grinding?
thatFrom: Ken <klehman@albedo.net>
of times.
avex rivet in.
Jesse Jenks wrote:
I realized today, well confirmed what I already suspected actually,interferesome of the SS rivets mushroomed heads inside the end plug willgowith each other. Specifically, the two at the corners of the skin thatlocatinginterferethrough the spar into the end plug side wall at the horn end willaboutwith the adjacent ones that attach the horn to the end plug. I thoughtthethis possibility with regards to the AN-3 bolt threads interfering withexactly3/16 rivet that goes through the end ribs small flange and lines upwith the bolt coming through the end. I avoided that conflict bythethose rivets as far away from the ends of the spar as possible. WithIskin corner rivets though, I figured the holes are located already, sotowasjust drilled them. Bad plan. I haven't riveted anything yet. Any
suggestions? It seems like the manual leads you right into this one. Ithinking about just riveting the horn to the end plug and then tryinganotherrivet,drill off the mushroomed head enough to get clearance for the otherbut with stainless I don't know if this is possible. I don't seeFiveoption except to leave two rivets out of the horn/end plug connection.aboutS.S. rivets and a 3/16 bolt should be strong enough, but we're talkingELEVATORS here!
_________________________________________________________________I just looked at it again, and I think I can work something out if I use
think
for
rivet.
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/o ... direct/01/
Jesse,
I had a few places in the Elite controls with this type of opposing
rivet interference. Wayne is right to suggest tapping the rivet in as
it is slowly pulled. They idea is to have the factory head tight to the
surface when the rivet finally pulls up and breaks. I was often
successful just putting a lot of pressure (leaning) on the riveter.
Another tack is to knock the mandrel out of the rivet, grind the rivet
body slightly shorter, reinsert the mandrel and pull it. Of course,
enough rivet for a proper shop head has to remain! It is always a good
idea to pull rivets at as low an air pressure as works to allow pieces
to seat together and allow primer or Proseal to oooze out of the joint.
Someone else may correct me, but I don't think the mandrel is ever
considered in the strength calculations for Avex rivets as they do not
positively retain the mandrel like a Cherry or Huck.
I could be wrong but it seems clear to me from the specs that the
mandrel is not part of the rivet strength in any of the MAM supplied
rivets. Rivets that do allow for mandrel increased strength are usually
referred to as structural rivets and specify two shear strengths - one
for through the retained mandrel and another for any area that does not
have a mandrel retained in it. In other words my opinion is that I think
that it would be fine to grind off some of the excess length past where
the mandrel head has expanded the rivet. As I recall, in most of my
stainless rivets, that would not necessarilly remove the mandrel as the
mandrel head pulls down inside the length of the rivet.
There was a bulletin though about 06 and 04 length rivets in these end
caps. I could look it up but the gist of it was that there are some
places that are too thick for the grip length of 04 length rivets if you
measure or add up the thickness. Many years ago there was a mix up in
the manual or in the rivets that were supplied for these end caps and I
think the 04 are too short for the 8 rivets that go in from the end
through the horns. Last time I looked MAM had the grip length
(thickness) spec on their site for all the rivets. I think the 04 length
means they are good for 4/16 or 1/4" grip length max. which was OK for
the radial rivets through the tube and into the end cap but not good
enough for the rivets through the horn into the end cap.
rivet.
Ken,
I havn't seen the bulletin, but you are right about the grip length of 04
versus 06. The thickness of the end cap + horn is about 5/16, so right in
between. I was thinking of using an 04 and counterboring the inside of the
end cap for the mushroomed head about 1/16. This would provide clearance for
the opposing rivet, and get the correct grip length. I don't think that
would compromise the strength of the end cap, but I'm not sure. If I don't
do something, I'm pretty sure I won't be able to get the opposing rivet in,
no matter how hard I hit it.
Check out Election 2004 for up-to-date election news, plus voter tools and
more! http://special.msn.com/msn/election2004.armx
Date: Sun, 19 Sep 2004 19:21:01 -0400
Jesse Jenks wrote:
DoesI just looked at it again, and I think I can work something out if I use
5604 (shorter) rivets in the two holes through the horn and end plug.thinkthe mandrel have to stay in the SS rivets for shear strength? If not IforI can knock it out and with the 3/16 long rivet it just might clear.
Alternatively, I could countersink the hole slightly inside the end plugthethe mushroomed head, and file the end of the mandrel down before settingrivet.
I don't think anyone can tell you to counterbore and I doubt that MAM
will either without seeing it but you could always ask them. It sounds
like you have dismissed the idea of grinding off excess length or there
really isn't any excess.
Would it help to take out the existing rivets and put in the other
(radial) ones first? - I think I did that somewhere.
Can you squeeze the installed rivet a bit shorter - ie hammer it like
you are installing a solid rivet?
Jesse Jenks wrote:
Ken,
Ken,
I haven't dismissed any ideas, and I haven't installed any of the rivets
yet. I am just thinking that there is barely a 1/16 space if the end horn
rivet went under the radial one for instance. I don't have any experience
with the SS rivets yet, but it seems like they would need more than 1/16 to
form a good shop head. I like your idea of squeezing it down more. Have you
ever tried it with these rivets? I could experiment. I think the mandrel
would have to be removed after pulling or ground down first for it it to be
effective.
Thanks for the help.
effective.
Date: Sun, 19 Sep 2004 21:48:59 -0400
Jesse Jenks wrote:
theKen,
between. I was thinking of using an 04 and counterboring the inside offorend cap for the mushroomed head about 1/16. This would provide clearancedon'tthe opposing rivet, and get the correct grip length. I don't think that
would compromise the strength of the end cap, but I'm not sure. If Iin,do something, I'm pretty sure I won't be able to get the opposing rivetno matter how hard I hit it.
