Squeezer dimpling
Jesse Jenks
Squeezer dimpling
Post by Jesse Jenks » Sat Feb 18, 2012 9:13 am
I am still trying to decide what to buy for dimpling. Is it worth getting a
hand squeezer for $160+? Would I use it for anything else besides dimpling?
I have heard mention of solid rivets in the spar. I can't find a vise grip
type dimpler in 120 degrees, but I can find dimple die sets in 120 degree,
but 1/8 inch only. Do I need 3/16 dimplers too, or only 1/8? I was looking
at Wrays Rebel manual online, and at least for the tail section, I don't see
any reference to 3/16 CS rivets. I have found several listings for 120 deg
countersink cutters now, but dimplers are still a problem.
Mother
Alan Hepburn
Squeezer dimpling
Post by Alan Hepburn » Sat Feb 18, 2012 9:13 am
I used captive Tinnerman nuts for all the inspection plate screws. They
take a 3/32" flush rivet. You can get 3/32" blind rivets, or use solid ones
and squeeze them. On dimples that small, 120 vs 110 degress isn't critical.
I just couldn't see using sheet metal screws into that thin aluminum on the
skin. I used dimple dies mostly (got them from ATS), though I also have a
squeezer (needed it for my floats). If I'd been thinking far enough ahead,
I'd have mounted these Tinnerman nuts on the skin before I applied it to the
wing/stab. That way, I could have back riveted them on a steel anvil. As
it is, I've found I either have to open up the access holes 1/8" or trim the
back of my squeezer 1/8" to get it through the holes.
Sent: Sunday, May 09, 2004 8:23 PM
Subject: Squeezer dimpling
dimpling?
see
Mother's Day is May 9. Make it special with great ideas from the Mother's
Day Guide! http://special.msn.com/network/04mothersday.armx
Archives located at http://www.dcsol.com:81/default.htm
squeezer dimpling
Post by Ralph Baker » Sat Feb 18, 2012 9:13 am
Personally, I can't ever have too many tools. That said, the squeezer
has been used many times on my plane . Wherever you can get to the
rivet and it doesn't look out of place. The solid rivets are stronger
and cheaper as well. The latest use was to squeeze about 80 3/32 flush
rivets to hold the top and bottom hinge halves for the cowl.
For access covers the nutplate rivets can be pulled or squeezed
according to access as there is little force on them.
Just don't rivet them on. In fact, try to think ahead and many
modification as necessary to ease future maintenance.
You should be able to find a squeezer for about US$125 new and a search
on Ebay may prove worthwhile.
bransom
Squeezer dimpling
Post by bransom » Sat Feb 18, 2012 9:13 am
One thing to keep in mind wrt dimpling, is that the squeeze or hit force
required is very small. I've not admitted it yet (here goes), but I set out
to solid flush rivet my leading edge skin to stringers, and got off on making
some little tools to help this go smoothly (no pun intended). For dimpling
the stringers (.030), I'm using a piece of mild steel with the pilot hole and
100 degree countersink for the female die side, and use the store bought
hardened male dimple die in the rivet gun. For the skins I use the male die
on the end of a mild steel dowel that rides in a "donut" that keeps the die
from hitting crooked (has to be perpendicular to avoid marks from the outside
of the die) -- I hit the steel dowel a couple soft taps with a hammer. So
far, all is going well. Some have told me this flush riveting thing is
completely unnecessary. My answer: so is the whole airplane. That doesn't
seem to stop me. :)
-Ben Ransom
-> I am still trying to decide what to buy for dimpling. Is it worth getting
-> hand squeezer for $160+? Would I use it for anything else besides
dimpling?
-> I have heard mention of solid rivets in the spar. I can't find a vise grip
-> type dimpler in 120 degrees, but I can find dimple die sets in 120 degree,
-> but 1/8 inch only. Do I need 3/16 dimplers too, or only 1/8? I was looking
-> at Wrays Rebel manual online, and at least for the tail section, I don't
see
-> any reference to 3/16 CS rivets. I have found several listings for 120 deg
-> countersink cutters now, but dimplers are still a problem.
-> Thanks
-> Jesse
-> _________________________________________________________________
-> Mother
Al Paxhia
Squeezer dimpling
Post by Al Paxhia » Sat Feb 18, 2012 9:13 am
Ben,
Its good to know that there are others who are compulsive, but I must tell
you it took me a long time to convince my wife that it was necessary to
build an airplane.
Al
Moose, N526AP
Sent: Monday, May 10, 2004 4:11 PM
Subject: RE: Squeezer dimpling
out
making
dimpling
die
die
outside
seem to stop me. :)
-Ben Ransom
getting
dimpling?
grip
degree,
looking
don't
see
deg
-> Thanks
-> Jesse
-> Mother
Squeezer dimpling
Al,
I bet it would take even longer now! :):)
Sent: Monday, May 10, 2004 9:47 PM
Subject: Re: Squeezer dimpling
Ben,
st tell
y to
build an airplane.
Al
Moose, N526AP
t force
t I set
out
ff on
making
r
dimpling
lot
hole
bought
he male
die
ps the
die
outside
mmer.
So
ing is
t
doesn't
seem to stop me. :)
-Ben Ransom
rth
getting
des
dimpling?
a vise
grip
120
degree,
was
looking
n, I
don't
see
for
120
deg
-> Thanks
-> Jesse
___
-> Mother
bransom
Squeezer dimpling
Al,
I guess I would not use the words "unnecessary" and "airplane" in the same
sentence to my wife either! :-)
BTW, I finally got organized enf to put some pictures up at
http://mae.ucdavis.edu/ransom/Murphy -- for starters, this shows
some pics of the dimpling blocks I was referring to.
-Ben
On 5/10/2004 5:47 PM, PAXHIA2@COMCAST.NET wrote to MURPHY-REBEL:
-> Ben,
-> Its good to know that there are others who are compulsive, but I must tell
-> you it took me a long time to convince my wife that it was necessary to
-> build an airplane.
-> Al
-> Moose, N526AP
-> From: <bransom@dcsol.com>
-> Sent: Monday, May 10, 2004 4:11 PM
-> Subject: RE: Squeezer dimpling
-> > One thing to keep in mind wrt dimpling, is that the squeeze or hit force
-> > required is very small. I've not admitted it yet (here goes), but I set
-> out
-> > to solid flush rivet my leading edge skin to stringers, and got off on
-> making
-> > some little tools to help this go smoothly (no pun intended). For
-> dimpling
-> > the stringers (.030), I'm using a piece of mild steel with the pilot hole
-> and
-> > 100 degree countersink for the female die side, and use the store bought
-> > hardened male dimple die in the rivet gun. For the skins I use the male
-> die
-> > on the end of a mild steel dowel that rides in a "donut" that keeps the
-> die
-> > from hitting crooked (has to be perpendicular to avoid marks from the
-> outside
-> > of the die) -- I hit the steel dowel a couple soft taps with a hammer.
So
-> > far, all is going well. Some have told me this flush riveting thing is
-> > completely unnecessary. My answer: so is the whole airplane. That
doesn't
-> > seem to stop me. :)
-> > -Ben Ransom
-> > -> I am still trying to decide what to buy for dimpling. Is it worth
-> getting
-> > a
-> > -> hand squeezer for $160+? Would I use it for anything else besides
-> > dimpling?
-> > -> I have heard mention of solid rivets in the spar. I can't find a vise
-> grip
-> > -> type dimpler in 120 degrees, but I can find dimple die sets in 120
-> degree,
-> > -> but 1/8 inch only. Do I need 3/16 dimplers too, or only 1/8? I was
-> looking
-> > -> at Wrays Rebel manual online, and at least for the tail section, I
-> don't
-> > see
-> > -> any reference to 3/16 CS rivets. I have found several listings for 120
-> deg
-> > -> countersink cutters now, but dimplers are still a problem.
-> > -> Thanks
-> > -> Jesse
-> > -> _________________________________________________________________
-> > -> Mother
Warren & Marg Montgomery
Squeezer dimpling
Post by Warren & Marg Montgomery » Sat Feb 18, 2012 9:13 am
Hi Ben,
My name is Warren and I'm a dimpleoholic too.
I use the normal pneumatic rivet gun for dimpling.
Having tried to machine a head for the gun in the shape of the male I
found an easier way.
Using the large head/nut on the gun wrap with a thin strip of tape to
build up to same dia as the male dimple
then wrap both the dimple and head so as to attach to gun.
after using it'll be easy to remove dimpler with built up area still
attached so next time it's held on by friction and the little bit of
stick still left on tape.
I've gone through a couple of boxes of cheap nails as I toss out when
they get too chewed up.
For tight areas where the nail won't go such as the tailing edge of
flaps and elevator I used a cut off bolt and inserted into a nut on
other side of female and pulled
Here's my fill recipe.
Having scotch brited outside of skin before dimple.
fill mandrel hole with primer injecting with 21 gauge needle (common
size)
this to give the next step a binder to any fine particulate matter
using airbrush spray each dimpled area plus a bit with 1/2" paint bla
st
this to tell you when you've sanded too far in the next steps
let mandrel fill settle overnight
inject mandrel hole with lightweight epoxy polyfill available AS&S us
ing
16 gauge needle (IV type)
Using fiber wheel clean off rivet head burrs and excess fill flush
fill dimpled area and cover rivet with polyfil leveling with spreader
sand lightly w 220 wet, repeat.
final top coat of auto glaze, sand lightly with 220 or 320 wet
I also used a rivet shaver on all the countersunk areas such as the f
uel
cell top skin.
About the only area I don't have flush rivets is the bottom fuel tank
skin.
Of course we'll probably have to add VGs later on.
Would I do it again, ya.
I've now completed the wings, ail, flaps, elev this way
rudder fin and fuss rivets ready for filling
Warren
Smooth Moose 029
Al Paxhia wrote:
Ben,
t tell
build an airplane.
Al
Moose, N526AP
force
I set
out
on
making
dimpling
t hole
ought
male
die
die
he
outside
er. So
g is
doesn't
seem to stop me. :)
-Ben Ransom
h
getting
s
dimpling?
vise
grip
20
degree,
as
looking
don't
see
or 120
deg
-> Thanks
-> Jesse
_
-> Mother
klehman
Squeezer dimpling
Post by klehman » Sat Feb 18, 2012 9:13 am
I don't think there were any 3/16" dimples. THere are a few countersunk
ones.
The $4.95 5102D-3/32 from www.aircraft-tool.com works fine. It is 100
degree but both the small head solid rivets and the cherry nutplate
rivets are 100 degree. www.averytools.com has the 1022 part for $12.50
which is the same thing but probably slightly higher quality.
I found having both a vice-grip type of dimpler and also the pop-rivet
type of pulled dimpler mentioned above to be quite sufficient. The vice
grip one is fast and more versatile than a table mounted squeezer. The
pop rivet style one will get the places that the other types won't.
ng a
ing?
rip
ee,
ing
t see
deg
Mother
Jesse Jenks
Squeezer dimpling
Post by Jesse Jenks » Sat Feb 18, 2012 9:15 am
Thanks Ken,
I was considering getting a hand-held squeezer like a Tatco or similar, and
using dimple die sets in it for dimples near the edges, and the pull-typ
dimpler in unreachable areas, as you say. You like the vise grip dimplers
though eh? I was wondering how they can make a good dimple if the vise grip
jaws don't stay parallel? Do you think it's unnecessary to get a squeezer?
Date: Thu, 13 May 2004 08:14:37 -0400
ones.
ng a
ing?
rip
ee,
ing
t see
deg
Mother
Jesse Jenks
Squeezer dimpling
Thanks guys,
Ok, I will spend my money on something else instead. I guess I should just
get enough tools to get started, then I can see for myself what I'm really
dealing with.
Those skis sound pretty cool Wayne. Don't get much snow on the California
coast though. Do they work in sand?
Date: Thu, 13 May 2004 22:11:12 -0400
Jesse....11 years of this.... almost full time for most of it...... and I
just bought a squeezer this past month...and it was for all the solid
rivets
in the new ski beams, not the airplanes!
Sent: Thursday, May 13, 2004 10:05 PM
Thanks Ken,
dimplers
grip
squeezer?
ones.
Jesse Jenks wrote:
getti
ng a
dimpl
ing?
vise
g
rip
degr
ee,
look
ing
don'
t see
120
deg
Moth
er's
Is your PC infected? Get a FREE online computer virus scan from McAfee
Squeezer dimpling
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:15 am
just bought a squeezer this past month...and it was for all the solid rivets
Thanks Ken,
grip
ones.
getti
ng a
dimpl
ing?
g
rip
degr
ee,
look
ing
don'
t see
deg
er's
Squeezer dimpling
Not sure how long the UHMW bottoms would hold up... grinding through the
desert....but sure would keep you from nosing over! I think you should buy a
set and give them a whirl!
:o)
Sent: Thursday, May 13, 2004 10:48 PM
Thanks guys,
dealing with.
rivets
Thanks Ken,
similar,
pull-typ
dimplers
grip
squeezer?
countersunk
$12.50
pop-rivet
vice
The
getti
dimpl
vise
g
degr
look
don'
120
Moth
McAfee
klehman
Squeezer dimpling
Post by klehman » Sat Feb 18, 2012 9:15 am
I made my own vise grip dimple die holder and the dies are free to move
a bit (really just a loose fit) so that they do stay parallel to the
aluminum sheet even though the vice grip jaws rotate closed. Don't know
if commercial ones do the same but they probably do.
Jesse Jenks wrote:
Thanks Ken,
