hydraulic pumps
Bob Fisher
hydraulic pumps
Post by Bob Fisher » Sat Feb 18, 2012 9:13 am
hi gang does anyone know of a real small lightweight low pressure
hydraulic pump 12volt that could be used in tandem with the hand
pump as a pass through i`m not sure if i want to pump 19 times for
every landing!
any ideas or pumps in use? thanks much bob fisher rebel 342
Archives located at http://www.dcsol.com:81/default.htm
hydraulic pumps
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:13 am
Keeps you in shape for the next medical Bob!! :o)
Also allows you to know that everything is okay.... as you know the stroke
count and pressure spikes to go with each gear locking into place. An
electric pump will immediately dump that entire reservior into the lake....
when something pops apart...where'as you'd know right away that something is
wrong using the hand pump.
Sent: Wednesday, May 05, 2004 9:52 PM
Subject: hydraulic pumps
every landing!
hydraulic pumps
Post by Bob Patterson » Sat Feb 18, 2012 9:13 am
Also, Bob, you may find that it only takes 15 or 16 pumps if you
pump a little slower .... I recall taking about 100 pumps on
short final into Pearson International a few years ago, when I didn't
do a downwind check (because they steered us around and there WAS no
downwind !) !! ;-) :-)
Add my vote to the "no electric pumps" side ! :-)
----------------------------orig.-------------------
every landing!
Alan Hepburn
hydraulic pumps
Post by Alan Hepburn » Sat Feb 18, 2012 9:13 am
You could try ordering Montana's hydraulic retract system. Talk to keith
@montanafloat.com It uses a Parker pump marked "642368" - not sure if that's
the model number or the serial number. But it runs at rather higher pressure
than the Murphy system, I believ.. I'm pretty sure these Murphy plastic
lines wouldn't be suitable.
every landing!
Bob Fisher
hydraulic pumps
true! fish
Sent: Wednesday, May 05, 2004 9:53 PM
Subject: Re: hydraulic pumps
lake....
is
every landing!
Bob Fisher
hydraulic pumps
thanks bob that may be the best? fish
Sent: Wednesday, May 05, 2004 10:04 PM
stroke
lake....
something is
every landing!
Legeorgen
hydraulic pumps
Post by Legeorgen » Sat Feb 18, 2012 9:13 am
Bob,
Make sure you retighten those plastic hydraulic lines after a few weeks, they
tend to loosen up or stretch, I know, as I had one pop off.
Bruce
Bob Fisher
hydraulic pumps
hi bruce thanks for the advise i`ll do it! bob fisher
Sent: Thursday, May 06, 2004 10:09 AM
Bob,
they
Bruce
Jean Poirier
hydraulic pumps
Post by Jean Poirier » Sat Feb 18, 2012 9:13 am
Hello Bob...
I have no expereince with electric hydraulic pump, I have no idea if it a
good things to put it on your aircraft or not, but I thing there is small
hydraulic pump for boat engine to raise the "screw"(I am not sure how to say
it in english!).
Jean
Rebel 747R
Sent: Thursday, May 06, 2004 6:18 PM
Bob,
they
Bruce
hydraulic pumps
Hi Jean!!
What I believe you are trying to say is "trim pump" for the "trim" tabs on a
boat. Yes I have seen a nice little compact trim unit used to power the
cylinders on an amphib set up... on full lotus floats.
Sent: Friday, May 07, 2004 12:48 PM
Hello Bob...
small
say
it in english!).
Jean
Rebel 747R
Bob,
weeks,
they
Bruce
