Well this weeks wakes and funeral are out of the way, so I've had a bit of
time to add to this today.
Weighed a set of aluminum gear legs (main/drag brace/joiner gusset
etc-everything but axle and wheel assembly) and bungee struts/safety cable
and bungee loops with bracing and cover of .025 = 14lbs
Same gear legs but with my 6" die spring struts instead = 20lbs
Pair of leaf gear legs with outboard saddle brackets = 20lbs
Therefore there would be no net difference between the "piper style" gear
legs using my die spring struts and the "leaf" leg gear when it comes to
installing the floats, other than maybe the minimal weight of the bolt on
float brackets for strut pickup at the fuselage if you have the leaf gear.
The overall empty weight of the aircraft is another thing due to the plate
doublers in the fuselage construction, but even that isn't extreme since it
amounts to the weight of about a 2.5' x 4' piece of .063 6061 T6 and three
or four hundred RV1613/9 rivets....nothing else!
Legeorgen@aol.com>
To: <
murphy-rebel@dcsol.com>
Sent: Friday, February 27, 2004 2:26 AM
Subject: Re: Spring gear leg wieght
I Weighed the spring gear and the attached 8.00 tires, wheels/axle, brakes
and brake line today. They were 30 LB each and the Scott tail wheel was 8
LB for
a total of 68 LB.
I weighed the Rebel with different scales this time and it came in at 1145
LB. Much better! I weighed it on the wheels but could not get the plane
level
for flight because I didn't have enough blocks to block up the mains.
I had to return the scales today and I'm wondering, if MAM says the CG
doesn't change and that seems to be the experience I've heard from other
1800 amphib
drivers, I'm very tempted to plug in the new empty weight and go with the
same CG I had on wheels. Any comments on this?
Bruce
Archives located at
To contact the list admin, e-mail
mike.davis@dcsol.com
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
