Imagine how one of these engines would make a Moose climb! Of course with 120
gallon tanks you'd only get 90 seconds of running time.
Subject: Top Fuel Dragster Trivia
So you want more horsepower? This puts things into perspective...
One TF dragster's 500-inch Hemi makes more horsepower than the first 8 rows
at the Daytona 500.
Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per
second, the same rate of fuel consumption as a fully loaded 747 but with 4
times the energy volume.
A stock hemi will not produce enough power to drive the dragster's
supercharger.
Even with nearly 3000 CFM of air being rammed in by the supercharger on
overdrive, the fuel mixture is compressed into nearly-solid form before
ignition. Cylinders run on the verge of hydraulic lock.
Dual magnetos apply 44 amps to each spark plug. This is the output of an arc
welder in each cylinder.
At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame
front of nitromethane measures 7050 degrees F.
Nitromethane burns yellow. The spectacular white flame seen above the stacks
at night is raw burning hydrogen, dissociated from atmospheric water vapor by
the searing exhaust gases.
Spark plug electrodes are totally consumed during a pass. After ? way, the
engine is dieseling from compression - plus the glow of exhaust valves at 1400
degrees F. The engine can only be shut down by cutting the fuel flow. If spark
momentarily fails early in the run, unburned nitro builds up in those
cylinders and then explodes with a force that can blow cylinder heads off the
block in pieces or split the block in half.
To exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of
over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration
is closer to 8G's.
If all the equipment is paid off, the crew worked for free, and for once
NOTHING BLOWS UP, each run costs $1000.00 per second.
Dragsters reach over 300 miles per hour before you have completed reading
this sentence.
Top Fuel Engines turn ONLY 540 revolutions from light to light!
The redline is actually quite high at 9500rpm
The current TF dragster elapsed time record is 4.477 seconds for the quarter
mile (06/02/01 Kenny Bernstein)
Putting all of this in perspective:
You are driving an average Lingenfelter powered "twin-turbo" Corvette. Over
a mile up the road, a Top Fuel dragster is staged and ready to launch down a
quarter mile strip as you pass. You have the advantage of a flying start, but
you still run the 'Vette hard up through the gears and blast across the
starting line and past the dragster at an honest 200 mph. At this moment, the
dragster launches and starts after you. You keep your foot hard down, but you
hear an incredibly brutal whine that sears your eardrums and within seconds
the dragster catches and passes you. He beats you to the finish line, a
quarter mile away from where you passed him.
That, folks, is acceleration.
Think about it, from a standing start, this phenomenal machine has spotted
you 200mph and not only caught, but nearly blasted you off the road when he
passed you within a mere 1320 feet. Now, tell me about the time you spun the
wheels and laid rubber on dry concrete?!
Archives located at
https://rebel:builder@www.dcsol.com/default.htm
To contact the list admin, e-mail
mike.davis@dcsol.com
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
