Wayne:
I had to bend my tailspring 14 1/2* in order to make the bolt vertical.I
took it to Alberta Aircraft Overhaul. They said that because the original
radius was a slow bend being no where near the bend radius for this
thickness of aluminum that we could cold bend it. We proceded to put it in a
hydraulic press and bend it.This worked fine. I reviewed this with MAM also
beforehand and they thought that this would be fine. Cold bending because of
the slow bend.
Just a thought
Murray
Sent: Wednesday, November 19, 2003 3:03 PM
Subject: Rebel - Tail Spring
Inspect your aluminum tailsprings closely before installation guys and make
sure they are not cracked anywhere.
I stripped the paint off the one I am working on, before a planned
reinstallation. I noticed that there are small cracks on each edge of the
TOP surface, at the bend where it clamps to the fuselage. I put it in my
press to put a little pressure on it and these opened right up and extended
towards the center of the spring on an angle, and extend down in to the
spring about 3/32 and then go in the same direction as the spring length
like delaminated plywood.
Note that these cracks could not be caused by landing loads. These are
tension cracks in the top outside radius of the bend from manufacturing!
Landing load cracks would be in the lower surface.
I discussed bending of aluminum this thick with Chris Heinz this summer, as
to how they fabricated their landing gear leafs for the CH2000/CH601/701/801
etc. He told me if done "cold", at room temperature of the facility, they
would crack immediately with small outer radius cracks. "The alum needs to
be heated and they bend just fine", he said.. Heating for him is laying the
flat raw material out in the sun, on a hot summer day, for a few hours. Says
you can't pick them up bare handed they get so hot and they bring them in
and immediately bend them without any problems. They try to do their full
years spring leaf run this way, but if they have to do it any other time of
year they have to heat the blanks (and I forget the temp he stated). I don't
know how Murphy does it, but I suspect COLD. Does anyone here know...
GRANT!?!
Rebel - Tail Spring
Rebel - Tail Spring
GRANT!?!
GRANT!?!
Rebel - Tail Spring
Well this ones cracked in a weird way, exactly as Chris Heinz described 7075
would cracked if you try to cold bend it (There's no sharp radius' on his
Zenair landing gear either). I put the spring in my press to bend it some
more, to get the rake angle right on the tailwheel before reinstallation,
and the little hair line marks at the edges of the outer bend radius opened
right up like delaminated plywood. Instead of installing, it's now going in
the trash and I'll be installing one of my 3 leaf trailer springs to replace
it.
Sent: Wednesday, November 19, 2003 8:43 PM
Subject: RE: Rebel - Tail Spring
it.
aWayne:
alsohydraulic press and bend it.This worked fine. I reviewed this with MAM
ofbeforehand and they thought that this would be fine. Cold bending because
makethe slow bend.
Just a thought
Murray
extendedsure they are not cracked anywhere.
astowards the center of the spring on an angle, and extend down in to the
CH2000/CH601/701/801to how they fabricated their landing gear leafs for the
theetc. He told me if done "cold", at room temperature of the facility, they
Saysflat raw material out in the sun, on a hot summer day, for a few hours.
ofyou can't pick them up bare handed they get so hot and they bring them in
don'tyear they have to heat the blanks (and I forget the temp he stated). I
*-------------------------------------------------------------------------*know how Murphy does it, but I suspect COLD. Does anyone here know...
GRANT!?!
Rebel - Tail Spring
Wayne and group Hello
The springs are cut out of plate cold and sized then sent to Vancouver for
DE-tempering to neutral. They are then shipped back in coolers to prevent fast
temperature changes and bent immediately on the press to the correct angle.
They are then sent back to Vancouver and re-tempered to the correct hardness. The
same procedure is followed with the nose gear forks on the SR and Elite. This
is the first time I have heard of this problem but I believe the plane Wayne
is working on may have had a few bumps in it's day and possibly bent the
spring. If this did indeed occur and someone attempted to rebend it the cracks
would be the natural result. In any event it was a good catch on your part Wayne
to take the extra time and test the part. I know if the springs were ever over
bent they were rejected and not reshaped I have a bunch of them in my shop
that I use for material in pet projects but not as springs again.
Grant
Grant
Rebel - Tail Spring
THANKS GRANT!
That's what we needed to hear!
(you say "may have had" with such stealth'ness ) !! )
Cheers, Wayne
Sent: Thursday, November 20, 2003 3:15 PM
Subject: Re: Rebel - Tail Spring
Cheers, Wayne
fastWayne and group Hello
angle.temperature changes and bent immediately on the press to the correct
hardness. TheThey are then sent back to Vancouver and re-tempered to the correct
Thissame procedure is followed with the nose gear forks on the SR and Elite.
Wayneis the first time I have heard of this problem but I believe the plane
cracksis working on may have had a few bumps in it's day and possibly bent the
Waynewould be the natural result. In any event it was a good catch on your part
overto take the extra time and test the part. I know if the springs were ever
*-------------------------------------------------------------------------*bent they were rejected and not reshaped I have a bunch of them in my shop
Grant
