PSRU Adapter
PSRU Adapter
I received my PSRU to engine adapter yesterday. I am disappointed in the
quality of the casting. On one side there is a large void, like a little
cave in the casting. And there are pinholes everywhere which may be
permeated throughout the casting internally where I can't see it. Indeed,
there could be large voids similar to the one I can see. Another sharp
angled void is present on one of the edges that would certainly be a stress
riser. I was also surprised it was cast. I expected a machined part. The
website says that the gear case is machined from 6061-T6 billet stock. I
assumed the adapter would be too. Is it possible it was and the voids were
present in the billet? I don't know anything about how billet stock is
created.
SR #044
created.
SR #044
PSRU Adapter
Well Mike,
Not being an engineer or metalurgist, I'll give you my opinion, as
developed from too many years of dealing with welding of aluminum. Billets
are the result of rolled or forged ingots. The material is dense and clear
as a result of the mechanical working that makes it a billet. Voids or
pinholes would be extraordinarily rare. Castings are produced by pouring
the molten metal into molds and then final machined from the result. Not
only are castings inherently porous, as a result of trapped gases during the
cooling process (pinholes) but the alloys used for casting are not quite the
same as those from which the billets are produced. In welding, you'd be
amazed how porous aluminum castings are, even really good ones. Aircraft
cylinder heads, for example, are castings. They're good ones, but have more
porosity than you'd imagine. Doesn't seem to be a problem. If it's
machined from billet aluminum, you won't see any voids or pinholes. If it's
a casting, what you've described is not surprising, to me. There's a lot
more differences between castings and billet items, as I'm certain will be
described by those more knowledgable than me, but bottom line is your
confidence in the manufacturer. As stated, cylinder heads are castings and
work just fine. Properly designed, nothing at all wrong with a good
casting.
Bill Delcambre
casting.
Bill Delcambre
stressI received my PSRU to engine adapter yesterday. I am disappointed in the
Theriser. I was also surprised it was cast. I expected a machined part.
werewebsite says that the gear case is machined from 6061-T6 billet stock. I
*-------------------------------------------------------------------------*present in the billet? I don't know anything about how billet stock is
created.
SR #044
PSRU Adapter
Mike,
I design medical equipment for a living. As such we rarely run into the
forces that an engine go through, but if we need a strong part we cut it
out of a billet. With casted parts there is a "grain" that is formed by
the flow of the aluminum. BIllet stock typically is viewed as not having a
grain. I'm sure it does, but there isn't a sense of grain due to the
issues that Bill mentioned, i.e. rolling etc. I would make a phone call
and ask them how many of the cast parts are operational in the field and
what their history is! As I have looked for my PSRU I have tried to avoid
both welding and castings. Bill does make a good point that many parts are
made from castings and I have seen good strong castings made. But given
the forces involved I think you need to ask more quesitons, to be sure!
Hope it works out, surprises are never fun!
Rick
From: Bill Delcambre [SMTP:bdelcambre@cox-internet.com]
Sent: Thursday, August 21, 2003 3:32 PM
Subject: Re: PSRU Adapter
Well Mike,
more
it's
casting.
Bill Delcambre
Rick
Well Mike,
more
it's
casting.
Bill Delcambre
Indeed,I received my PSRU to engine adapter yesterday. I am disappointed in the
stressthere could be large voids similar to the one I can see. Another sharp
created.
SR #044
PSRU Adapter
Where did you get the PSRU and what are you putting it on.
Sent: Thursday, August 21, 2003 4:54 PM
Subject: PSRU Adapter
created.
SR #044
PSRU Adapter
Mike,
I checked this AM with one of our Mechanical Engineers. He is also a car racer and rebuilds his engine about every 20 hours because they are run so hard.
I was close. There is actually very strong grain in billets. The process of rolling and forging creates a very dense strong structure. At times the grain in the billet will be use to the advantage of the part design for strength. Castings can be just as strong, but require more metal. When they make a crankcase they first cast it and then forge it by heating and applying extensive pressure. In the case of an engine block they will get it red hot and then somehow pound on it to "forge" the metal. I shared your observations about your PSRU casting. He agreed that the pockets and bubbles are cause for concern. The key question is does the casting have the same or more metal as its predecessor part that was cut from a billet.
Hope this helps.
Rick
-------Original Message-------
Sent: 08/21/03 06:31 PM
Subject: RE: PSRU Adapter
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
message.
Hope this helps.
Rick
I design medical equipment for a living. As such we rarely run into theMike,
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
theI received my PSRU to engine adapter yesterday. I am disappointed in
littlequality of the casting. On one side there is a large void, like a
Indeed,cave in the casting. And there are pinholes everywhere which may be
Iwebsite says that the gear case is machined from 6061-T6 billet stock.
wereassumed the adapter would be too. Is it possible it was and the voids
#044present in the billet? I don't know anything about how billet stock is
created.
SR
mike.davis@dcsol.comTo unsubscribe from this list go to:
message.
PSRU Adapter
I thought one comment from Rick was interesting. Mike Davis and I both
thought that my block was cast due to the rough surface where it was pulled
out of a mold. Yet I was always under the impression that Rodec blocks were
forged. If what Rick says is true, apparently it is cast first, then
"forged" (pressure and heat) which would explain why my block and my heads
don't have pinholes or voids anywhere, yet they have rough casting mold
release areas that make it look like it was a casting.
SR #044
rickhm@mindspring.com
Sent: Friday, August 22, 2003 10:09 AM
Subject: Re: RE: PSRU Adapter
Mike,
hard.
Hope this helps.
Rick
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
message.
SR #044
Mike,
hard.
Hope this helps.
Rick
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
created.
SR
message.
PSRU Adapter
Who manufactured this adapter and what engine / PSRU is it for? Thanks.
Dave Stroud, Ottawa, Canada
Christavia Mk 1 C-FDWS
Fairchild FC-2 early construction
Sent: Friday, August 22, 2003 2:08 PM
billet.
hours because they are run so hard.Mike,
strong structure. At times the grain in the billet will be use to the advantage of the part design for strength. CastingsI was close. There is actually very strong grain in billets. The process of rolling and forging creates a very dense
billet.
Hope this helps.
Rick
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
theI received my PSRU to engine adapter yesterday. I am disappointed inlittlequality of the casting. On one side there is a large void, like aIndeed,cave in the casting. And there are pinholes everywhere which may be
permeated throughout the casting internally where I can't see it.stressthere could be large voids similar to the one I can see. Another sharp
angled void is present on one of the edges that would certainly be aTheriser. I was also surprised it was cast. I expected a machined part.Iwebsite says that the gear case is machined from 6061-T6 billet stock.wereassumed the adapter would be too. Is it possible it was and the voids#044present in the billet? I don't know anything about how billet stock is
created.
SR
*-------------------------------------------------------------------------*mike.davis@dcsol.comTo unsubscribe from this list go to:
message.
PSRU Adapter
Hey, who let this guy on the list??
JUST KIDDING DAVE!
Sent: Friday, August 22, 2003 12:47 PM
JUST KIDDING DAVE!
car racer and rebuilds his engine about every 20Who manufactured this adapter and what engine / PSRU is it for? Thanks.
Mike,
process of rolling and forging creates a very densehours because they are run so hard.I was close. There is actually very strong grain in billets. The
advantage of the part design for strength. Castingsstrong structure. At times the grain in the billet will be use to the
they first cast it and then forge it by heatingcan be just as strong, but require more metal. When they make a crankcase
get it red hot and then somehow pound on it toand applying extensive pressure. In the case of an engine block they will
He agreed that the pockets and bubbles are cause for"forge" the metal. I shared your observations about your PSRU casting.
as its predecessor part that was cut from aconcern. The key question is does the casting have the same or more metal
havingbillet.Hope this helps.
Rick
avoida
pouringboth welding and castings. Bill does make a good point that many parts
are
Rick
Well Mike,
Billets
clear
Notthe molten metal into molds and then final machined from the result.
Aircraftonly are castings inherently porous, as a result of trapped gases during
lotcylinder heads, for example, are castings. They're good ones, but have
more
it's
bemore differences between castings and billet items, as I'm certain will
sharpdescribed by those more knowledgable than me, but bottom line is your
casting.
Bill Delcambre
permeated throughout the casting internally where I can't see it.there could be large voids similar to the one I can see. Another
isstressangled void is present on one of the edges that would certainly be aTheriser. I was also surprised it was cast. I expected a machined part.Iwebsite says that the gear case is machined from 6061-T6 billet stock.wereassumed the adapter would be too. Is it possible it was and the voidspresent in the billet? I don't know anything about how billet stock
*-------------------------------------------------------------------------*#044created.
SR
message.
PSRU Adapter
Giday, Wayne. I joined the list with the view to start a Moose for use with the 285 hp Housai engine.
I was going to call it a Moose Lite..
I emailed Murphy for info but they could not reply as they were at Arlington, then they got too busy with Oshkosh.
Still nothing so I started the Fairchild.
Sent: Saturday, August 23, 2003 7:18 PM
JUST KIDDING DAVE!
Mike,
I checked this AM with one of our Mechanical Engineers. He is also aprocess of rolling and forging creates a very densehours because they are run so hard.I was close. There is actually very strong grain in billets. Theadvantage of the part design for strength. Castingsstrong structure. At times the grain in the billet will be use to thethey first cast it and then forge it by heatingcan be just as strong, but require more metal. When they make a crankcaseget it red hot and then somehow pound on it toand applying extensive pressure. In the case of an engine block they willHe agreed that the pockets and bubbles are cause for"forge" the metal. I shared your observations about your PSRU casting.as its predecessor part that was cut from aconcern. The key question is does the casting have the same or more metalhavingbillet.Hope this helps.
Rick
the flow of the aluminum. BIllet stock typically is viewed as notavoida
what their history is! As I have looked for my PSRU I have tried topouringboth welding and castings. Bill does make a good point that many parts
are
Rick
Well Mike,
Billets
clear
pinholes would be extraordinarily rare. Castings are produced byNotthe molten metal into molds and then final machined from the result.Aircraftonly are castings inherently porous, as a result of trapped gases during
amazed how porous aluminum castings are, even really good ones.lotcylinder heads, for example, are castings. They're good ones, but have
more
it's
a casting, what you've described is not surprising, to me. There's abemore differences between castings and billet items, as I'm certain willsharpdescribed by those more knowledgable than me, but bottom line is your
casting.
Bill Delcambre
the little Indeed,isstress The I were*-------------------------------------------------------------------------*#044
*-------------------------------------------------------------------------**-------------------------------------------------------------------------*To unsubscribe from this list go to:
message.
PSRU Adapter
I hear your disappointment Dave!
We are all starting to wonder what's happening on the "West Coast" as even
the "old" dedicated bunch aren't getting responses (or parts) either!
:o(
Sent: Sunday, August 24, 2003 2:58 PM
:o(
with the 285 hp Housai engine.Giday, Wayne. I joined the list with the view to start a Moose for use
Arlington, then they got too busy with Oshkosh.I was going to call it a Moose Lite..
Thanks.Still nothing so I started the Fairchild.
JUST KIDDING DAVE!
aDave Stroud, Ottawa, Canada
crankcasecar racer and rebuilds his engine about every 20process of rolling and forging creates a very densehours because they are run so hard.advantage of the part design for strength. Castingsstrong structure. At times the grain in the billet will be use to thecan be just as strong, but require more metal. When they make a
willthey first cast it and then forge it by heatingand applying extensive pressure. In the case of an engine block they
casting.get it red hot and then somehow pound on it to"forge" the metal. I shared your observations about your PSRU
metalHe agreed that the pockets and bubbles are cause forconcern. The key question is does the casting have the same or more
theas its predecessor part that was cut from abillet.
cut it
formed by
thehaving
call
partsavoid
given
sure!
as
or
duringpouringNot
quite
you'd be
haveAircraft
If
willlot
yourbe
castings
in
be
asharp
part.
stock.
voids
stock
*-------------------------------------------------------------------------*is
