rudder / elevator cables
Post by Ralph Baker » Fri Feb 17, 2012 11:02 pm
Harold,
We will be using pulleys for the rudder cables at the front and rear of
the doors where the angles are greatest. Also at the floor where the
upper elevator cable from the top of the control column turns parrallel
to the floor for its run to the rear.
Elite 624E
Harold Dick
Post by Harold Dick » Fri Feb 17, 2012 11:02 pm
Hello Ralph,
As well as the ones you mentioned, I think that I'll add a set of rudder
cable pulleys for the rear most angle change. This is the first set after
the cables enter the fuselage from the rudder horns. I'll attach a bracket
to bulkhead E at the midpoint of the curve joining the side of the bulkhead
to the bottom.
Harold Dick 633E
Sent: Monday, May 12, 2003 10:14 AM
Subject: rudder / elevator cables
Harold,
Elite 624E
