Another V8 Super Rebel?
Post by Mike Kimball » Fri Feb 17, 2012 10:59 pm
Hey Rick, I lost track of the fact that you are going with a V8. I am
starting to put together an order for parts starting with a Rodeck aluminum
350 block. Where are you at engine wise?
SR #044
rickhm@mindspring.com
Sent: Thursday, May 01, 2003 6:25 PM
Subject: Re: RE: Tail Wheel Attach Point on SR
Scott,
Thanks for the reply. It is a little hard to describe what I did in words.
A picture is really worth a thousand words. I would be happy to provide if
interested. Although taking a picture of this might be a real challenge!
Imagine you are looking at the tail from the right side. There are 2 rivet
lines that hold the two flanges for the sub-assembly the tail spring
attaches two. Of course there are 2 other rivet lines on the left side as
well. As you look at these rivet lines there is a rivet line running for
and aft that holds the wrap around the bottom of the tail. If you have
X-ray vision you would see an angle running "away from you" along the bottom
of the sub-assembly forward of the side the tail spring attaches to. This
is the "standard" design.
In my addition I added a 4-6" piece of 2" angle (flange on the angle is 2"
long) that runs forward of the sub-assembly. It attaches to the
sub-assembly by 2 bolts. These bolts would appear to run up and down as
viewed from the right (or left side) and connect one flange of my addition
to the flange of the angle that runs along the bottom (away from you)
described above. The angle attaches to the skin. So with your xray vision
you would see one flange attached to the skin and running forward and the
other flange facing away from you. The skin now has an additional 2 rows of
rivets in it above the rivet line where the corner wrap attaches.
Clear as mud? I know what you mean about taking stuff apart and "enhancing
the design." Some of the time I do this as well. I am sure you have had
the experience of seeing something that your more comfortable enhancing.
One area where I did this is along the side of the fus up front. Recall the
door posts skins and the skin that goes forward from the door post to the
firewall. I put an additional .040 2024-T3 layer over these to strenghten
the entire front end. Since I'm using a V8 engine I felt the extra 10 lbs
was worth the peace of mind. I don't understand why they didn't make this
one piece in the first place?
Thanks for the feedback.
Rick Muller
SR70
-------Original Message-------
Sent: 05/01/03 05:29 PM
Subject: RE: Tail Wheel Attach Point on SR
Correction - The one piece tail stinger/stab bracket was welded aluminum
not
4130.
Scott & Leere' Aldrich
Sent: Thursday, May 01, 2003 2:00 PM
Rick, all the ones I have seen have been the second hole up.
I can't imagine the piece warping under just the load of the empty
fuselage?? However, we did add doublers with an L that picks up the
flanges
on both sides, both front and back. MAMs was cracking on the flanges. Did
they tell anybody?? No.
What does your 4 inch angle tie into? The flanges on the fuselage sides?
I have seen one that has made the entire assembly out of welded 4130. He
needed a wider bracket for the tail stinger as he is upping that also.
May
be the way to go. I am getting good at taking stuff apart that I have
already completed so may do that later...
Scott
Moose #174
Sent: Monday, April 28, 2003 3:53 PM
Subject: Tail Wheel Attach Point on SR
This weekend I was stringing cable for the rudder. I noticed that where
th
e tail wheel spring (the long pipe) attaches something was not right.
Upon
closer inspection I noticed that horizontal piece (Left side of Fus to
Rig
ht side) had bowed/warped under the minimal weight of the empty fus. This
was largly my mistake which I quickly corrected. But it got me looking
clo
sely and thinking. Under shock load, like that of the tail bouncing, the
f
orce is transfred into this horzontal member consisting of a buildup of
sev
eral pieces. My tail is attached to the second hole from the BOTTOM of
bracket. I must admit there has been lots of email on where this goes to
get the top of the tail "level" and mine is still not level (no engine
yet)
. I was not comfortable that the shock load wouldn't eventually crack the
flanges where the horizontal piece attaches to the side skin. I installed
4" of angle to transfer the load from the horizontal piece to the skin.
Th
e 4" angle runs parallel lengthwise toward the front of the fus.
Has anyone else looked at this and been concerned? Within general
reasonab
le tolerance, all the SR's should be about the same with respect to the
tai
l spring (pipe) and the levelness of the top of the tail wheel. Where is
e
veryone else seeing their tail attach, i.e. which hole?
Rick
Muller
SR70
<a target=_blank
href="http://www.dcsol.com:81/public/code/htm ... ://www.dcs
ol.com:81/public/code/html-subscribe.wcx</a>
Archives located at <a target=_blank
href="http://rebel:builder@www.dcsol.com:81/d ... bel:builde
r@www.dcsol.com:81/default.htm</a>
To contact the list admin, e-mail
<a target=_blank
<a target=_blank
Rickhm at home
Post by Rickhm at home » Fri Feb 17, 2012 10:59 pm
I am planning on using an LS1. It will likely be more expensive than
purchasing an aluminum block and building an engine up, but my knowledge
base is not overwhelming when it comes to engine internals and assembly. I
must also admit the years of building have got me in a mode where I would
like to fly before my 90th birthday. The LS1 also represents a 3rd
generation of engine development by GM. At the moment the one obstacle I
have not found a solution to is engine mount. I guess everyone that uses
an auto engine faces this. Any suggestions? I would be interested in
hearing about your approach!
Rick Muller
SR70
Sent: Thursday, May 01, 2003 11:05 PM
Subject: Another V8 Super Rebel?
SR #044
Scott,
bottom
vision
Rick Muller
SR70
not
4130.
flanges
May
Scott
Moose #174
th
Upon
Rig
clo
f
sev
yet)
Th
reasonab
tai
e
Rick
Muller
SR70
<a target=_blank
href="http://www.dcsol.com:81/public/code/htm ... http://www
.dcs
href="http://rebel:builder@www.dcsol.com:81/d ... //rebel:bu
ilde
<a target=_blank
.dcs
ilde
<a target=_blank
.dcs
ilde
There is a local EAA chapter member in town that also has an engineering
business. It's just he and his wife who has a Ph.D. in engineering.
Between the two of them they will do the analysis and he will create a jig
and weld up my engine mount. The good news is that I will then have a jig
for creating more engine mounts. They have done this before for their
WAGAERO 2+2. Cost should be between $1000 and $1500. I don't know if the
jig will help you with the LS1 since it's a completely new block design but
if it can be used maybe we can use it to build a mount for you. I was very
interested in the LS1 when Northwest Aero was selling a complete aircraft
conversion including their own PSRU. Then a couple of things changed my
mind. Northwest stopped selling engines and I didn't put in a fuel return.
I also became more and more convinced that I wanted the simplest system I
could design, with repair in the field at least a possibility. Once I'm on
floats I could be just about anywhere up here in Alaska where there won't be
a convenient parts department. Also, I want to be able to work on anything
on my airplane and I'm not knowledgeable about electronic fuel injection
systems. I mentioned this philosophy to Robin Dyck, MAM's pilot, and he
said, "Heck, why have a fuel pump at all. Just go with gravity feed and you
have nothing to fail with fuel delivery to a carburetor."
I'm meeting with a friend who's an expert engine builder on Monday to start
placing orders to build my engine. Once I know what I'm getting, I'll pass
it on along with the rationale for each component. I will tell you that the
engine I'm building will produce an honest 400-425 horsepower and will cost
a mere $12,000 or so including all accessories.
SR #044
Rickhm at home
Sent: Friday, May 02, 2003 5:26 AM
Subject: RE: Another V8 Super Rebel?
Rick Muller
SR70
SR #044
Scott,
bottom
vision
Rick Muller
SR70
not
4130.
flanges
May
Scott
Moose #174
th
Upon
Rig
clo
f
sev
yet)
Th
reasonab
tai
e
Rick
Muller
SR70
<a target=_blank
.dcs
ilde
<a target=_blank
.dcs
ilde
<a target=_blank
.dcs
ilde
Rickhm at home
You have some great support people up there. I have spent some time in
Alaske climbing Denali and down in the St. Elias range. I was always
impressed with the people I met, and there knowledge base. Please keep me
updated on your progress. I do understand the model you are using for
engine design and service. I must admit that I am not overwhelmed with how
MAM has done some things with respect to their serviceability. Riveting
inspection plates struck me as a all out dumb idea. It is true that an
auto fuel injection system does add a little complexity. I did have to do
some reading to gain an understanding. I also have a buddy that races
cars, mostly Honda civics'. I don't recall the class, but he has won the
national title several times. His average life before tear down is about
20 hours. He and I discussed at length buy Vs build. There are clear
advantages to both. I too was very interested in NW Aero's offering of a
full up engine. But that is now old news. I did find a place that sells
the full engine test run
(http://www.advanceadapters.com/acrobat/enginfo.pdf ). There cost is
$6400. THE GM "Kit Engine" is $5700 and does not come with the
accessories, so $6400 isn't a bad price given the include the accessories
and test run the engine. Regarding Engine mount. I have not done the hard
look and I need to regarding the mount points on a standard V8 small block
and the LS1. I am very interested in your progress here. After all, the
engine mount is a very key part of the system! Another site you should
check out regarding PSRU is
http://www.ec-securehost.com/Stumpjumpe ... gines.html It
is designed for an airboat. These guys put lots more load on a prop that
we will. Imagine doing a 360 on a dime! The cost is $2500. I know there
are others that are using this in aircraft. The down side is its weight is
69 lbs. I don't know what other PSRU's weigh. I have not talked to them,
something else on the list.
Thanks for the update!
Rick Muller
SR70
Sent: Saturday, May 03, 2003 12:47 AM
be
you
SR #044
Rickhm at home
Rick Muller
SR70
SR #044
Scott,
bottom
vision
Rick Muller
SR70
not
4130.
flanges
May
Scott
Moose #174
th
Upon
Rig
clo
f
sev
yet)
Th
reasonab
tai
e
Rick
Muller
SR70
<a target=_blank
.dcs
ilde
<a target=_blank
.dcs
ilde
<a target=_blank
.dcs
ilde
