swing up doors
Mike Davis
swing up doors
Post by Mike Davis » Fri Feb 17, 2012 5:18 pm
Received: from [137.186.224.124] (helo=ms01-124.tor.istar.ca)
for murphy-rebel@dcsol.com
id 10AEZ4-0006z3-00; Tue, 9 Feb 1999 09:55:03 -0500
Mime-Version: 1.0
Subject: swing up doors
Message-Id: <E10AEZ4-0006z3-00@mail2.toronto.istar.net>
Date: Tue, 9 Feb 1999 09:55:03 -0500
On the swing-up doors -
If you get some extra square door frame tubing, it can be fitted
inside the original frame (don't cut the top of the door), and this will
give you swing-up windows. A few builders figured that was too much work -
believe me, you'll want those windows !!
It's then just a case of move the hinges to the top of the window,
and the top of the door, and add an air shock strut from a car rear
window.....
You may have to change the shape of the bottom front of the
door slightly, to clear the strut - this usually only means bringing
it back an inch or so, and sharpening the curve a bit ....
Curt can give you more details ...
----------------------------orig.---------------------------------
At 09:45 PM 2/8/99 EST, you wrote:
I'd have to concur with Bob P's comments on Met-All. We used to polish
DC-3's, 6's and Convairs in the Marines with the stuff. Lasted the longest
any of the stuff we tried. That's why everything on our Rebel will be
painted.
Lonnie: The "gear fix" is where I'm at right now...along with doing
something
along the line of Curt & Bill's mod for the swing-up doors. Are most of
folks putting the larger engines, i.e., 0-320's & Subaru's doing the .032
corner wraps? Any other mods on the front?
Brian: We got a 'profile' to work on the paint scheme from Murphy. I can
send
it.
Those folks on floats...are the Murphy recommended positions of the fuel
sumps
adequate? Not being a float pilot yet is there a better position on the
fuselage for the Transponder antenna then under the cabin belly...outside
of a
top mounted antenna?
Paul & Peg
S/N 374
Mike Davis
Swing up doors
Received: from dialup.voyager.co.nz (ts1p10.net.ashburton.voyager.co.nz
[203.21.25.174])
by callisto.net.voyager.co.nz (8.9.0/8.9.0) with ESMTP id RAA03326
for <murphy-rebel@dcsol.com>; Sat, 27 Mar 1999 17:40:09 +1200 (NZST)
Message-Id: <199903270540.RAA03326@callisto.net.voyager.co.nz>
Subject: Re: Swing up doors
Date: Sat, 27 Mar 1999 17:39:45 +1200
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Hi Curt,
Thanks for the instant feedback on that, I'll pass that on to my man and if
he has any queries I'll get back to you.
Sounds like a good system.
Alister
Date: Saturday, March 27, 1999 2:10 PM
Hi Alister,
We decided to put swing ups on our aircraft and have been very happy
with
that decision. The improvements they seem to give, seeing how I never
had the
standard style, are these. They don't swing forward and ding up the door
or
the strut. Access is improved. I can pull the seat foward and load the
back
and still get in easily. When the door is open it stays open. I tried
open one in flight one time. It opened easily, but to push it up to the
bottom
of the wing required me to lean out and at eighty mph I knew I would
loose my
glasses. I still am going to try with just taking off with them in the
up and
latched position. We installed them to the top hinge with rivenuts in
from the
bottom and screws from the top so we could remove them totally in a
minute or
so. Our main goal was to have seaplane style doors for the floats. I
wanted
to know the doors would stay open for me. I also had this mental picture
of me
doing preflight on floats, and as I got near the long standard type door,
would begin to fall. Being the basic clumsy type I know this is going to
happen. Well, I could also picture me grabbing for something, getting
back of the door, and then me and the door ending up getting wet.
Our configuration is something like this. We added a 2 1/2 inch
high by
11 1/2 inch long wedge to the forward door frame. That's all that's
needed to
clear the strut. We then used the frame stock sent by MAM and filling it
with
sand, rolling the outer area with a small piece of rolled steel, formed
it to
the door opening. The latch system is a three pin bellcrank in the
center/
front of the door that drives one pin to the front, one to the back, and
one
to the bottom. The bottom one also goes into a latch attached to the
bottom of
the wing, just forward of the main spar and gas tank area. We thought
about a
gas strut, but opted not for now. We also increased the size of the
window
somewhat. I have started to make a print acouple of times, but I guess I
get
more involved in flying it or working on the floats. I really am going to
try
to do that this year. If I can answer any other questions, drop me a
line and
I'll do my best. Curt, Rebel N97MR
Mike Davis
Swing up doors
Received: from [137.186.225.154] (helo=ms02-244.tor.istar.ca)
by mail4.toronto.istar.net with smtp (Exim 1.92 #2)
id 10Qwuz-0004dY-00; Sat, 27 Mar 1999 12:30:46 -0500
Mime-Version: 1.0
Message-Id: <E10Qwuz-0004dY-00@mail4.toronto.istar.net>
Date: Sat, 27 Mar 1999 12:30:46 -0500
Hi Alister !
Have seen at least 4 different variations on swing-up doors. Most have
gas struts, which means you can't latch them to the bottom of the wing.
Don't know of anyone who has flown with them open without being latched.
One consideration is making the windows hinge upward, as well, as
this makes them easier to manage - if the window is open, & latched to
the wing, you can then just swing the door up, as well....
Most folks have had to carve out about a 4" chunk at the bottom front
of the door, to clear the strut, although others have just raised the
whole door sill.
Swing-up doors do make it a little easier for seaplane use, but NONE
of the guys here on floats or amphibs have swing up doors ! I haven't
really had any problem with mine, either way, and it IS a LOT of work
to change the doors, as well as adding weight.
I don't want to take anything away from some of the excellent work
that has gone into some of the door mechanisms, or other improvements
that have been done, but they DO involve a LOT of extra planning & effort.
My suggestion is to go with the standard doors, get it flying (!!) -
then change it later, IF it needs it !!
Too many builders get caught up in "improving" the Rebel for imagined
reasons, then complain that it's taking too long to build and weighs too
much !! Things like electric flaps are neat, and I have seen several very
nice installations - I have also seen some that were downright dangerous !!
If you LIKE to tinker, and don't care how long it takes to build your
Rebel, by all means, indulge yourself - that's the advantage of a
home-built, but please, be careful !!
The standard flaps work fine IF you change the handle to a more-ergonomic
"L" shape, and add an extra hole for negative, if you have a large enough
engine ! (If it ain't broke, don't fix it !)
Hopefully, as builders get more feedback from flying Rebels, especially
folks like you who are really USING the airplane, they will realize that
most of their fears were unnecessary - it really IS ok, the basic
engineering IS sound, and the Rebel flies great !!
There ARE things that we have learned (recently) that DO help maintenance
and durability, and these are relatively easy to do while building - just
ask the other builders - folks like yourself !! Some other things I see
people doing to correct imagined problems are actually going to CAUSE
real problems later !
Every 'little' "improvement" usually results in several more changes
being needed down the road - more weight, more complications, more time,
and possibly much more difficult to repair later, as standard parts will
no longer fit . These things can also effect resale value, insurance
costs, and cause difficulties in checking other people out to fly your
Rebel....
Sorry - better get off my soap box !! It's just that the Rebel is
SUCH a good flying airplane, right out-of-the-box !!!! (Of course,
ANYTHING can be made BETTER ....) :-)
--------------------------------orig.----------------------------------
At 10:21 AM 3/27/99 +1200, you wrote:
Hi there,
I have been asked by another Rebel builder to enquire about the swing up
doors that appear to be around.
Are they any good? are they easier to operate? can they be opened in
flight? any feedback on this would be appreciated.
thanks
Alister
email: yeoman@voyager.co.nz
Mike Davis
Swing up doors
Received: from tim-toshiba - 206.40.8.15 by email.msn.com with Microsoft
SMTPSVC;
Mon, 5 Apr 1999 11:21:14 -0700
Reply-To: <tlcarter@email.msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: Swing up doors
Date: Mon, 5 Apr 1999 10:09:31 -0700
Message-ID: <000901be7f92$1c884d00$14640a0a@tim-toshiba>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Importance: Normal
In-Reply-To: <199903270540.RAA03326@callisto.net.voyager.co.nz>
Return-Path: tlcarter@email.msn.com
Curt:
Do you have a picture?
Tim
#438
Sent: Friday, March 26, 1999 9:40 PM
To: Murphy Rebel
Hi Curt,
Alister
Hi Alister,
with
had the
or
back
bottom
loose my
up and
from the
minute or
wanted
of me
high by
needed to
with
it to
center/
one
bottom of
about a
window
get
try
line and
