RF interference
Posted: Sun Mar 20, 2016 9:17 am
I am having a problem with RF interference with the Ray Allen trim indicator. The trim servo and indicator work fine, but when I key the mic on the radio, the bright bar on the trim indicator changes to 2 or 3 very dim bars. I am using the Garmin GTR 200 radio that puts out 10 watts of power. I have tried relocating the antenna coax and antenna, but nothing changed. I called Ray Allen about this and was told that it is a common problem and they have tried to fix it over the years with different voltages and engineering changes but nothing worked. What I want to find out is if anyone else has experienced this, and if you were able to solve the problem. If nothing else, it is a good radio transmit indicator!
Lindall
Lindall
