Control Cable Terminal
Posted: Tue Feb 17, 2015 8:41 pm
by Jerry Folkerts
Well, I was proud of myself today as I finished the last control cable. Then, as I went back through the manual to check everything off, I noticed I should have used an AN-111 Bushing on the elevator vs the regular nicopress thimble. Should I make them over? Does it make any difference?
Re: Control Cable Terminal
Posted: Sun Aug 11, 2019 10:02 am
by tjbalcom
Jerry, Did you ever replace with the AN-111 bushing? I am currently looking to run control cables and notice the AN-111 bushing has a 3/16" hole vs. the required 1/4" hole in the elevator/rudder control horns.
