rivet size question
rivet size question
I'm building Rebel 320R and have a manual dating to 1993. on page 302 it gives instructions for riveting the roof onto the frame. On step 276 subparagraphs 3) it reads - 1/4" x 3/16" avex rivet in top carrythrough gussets.
I can't find an avex rivet in this size (1/4 x 3/16") at any supplier.
Any info on this rivet would be appreciated
Re: rivet size question
Rivets are described by diameter and grip length.
Therefore the Rivet will be 3/16" diameter..... 1/4" (.250") will indicate grip length.
Here's a link for a 3/16th .250" avex rivet....
https://www.fastenal.com/web/products/details/11544444
Dale
British Columbia, BC
Mountain Flying at Its Best
You can also get smaller quantities from Aircraft Spruce and Specialty.
Jerry,
The link was just for Rivet Information reference.
You can buy is smaller quantities from this company also. I referenced this company because it is local to me.... No shipping costs.
Dale
It's a typo.... as there are NO 1/4" rivets in a Rebel.. unless you screwed up and make that happen... :shh:
It should read 3/16 x 1/4" rivet.... or to be real easy it should read RV1613 ! :thumbup:
Thanks for the reply. I thought the first number 1/4" was the diameter number and the 3/16" the grip.
If the numbers were 3/16 x 1/4 it would make sense.
That is why I am suspect of a typo
Again,thanks thanks for the reply
Thanks. Very helpful info.
RV 1613 (3/16 x 1/4)
RV 1619 (3/16 x 3/8)
Yes... you are correct...1613's up there. .not 1619's! I'm allowed one slip up a week, based on my salary! Was thinking "gusset plates" needed the longer one, but the top plates are thinner than the lower ones where 1619's are used.
Is there anywhere other then Mam to get the Rv1613 and Rv1619 rivets ?
There are quite a few rivet suppliers. Aircraft Spruce and Specialty has them. In the US, Hanson Rivet is a good source, but minimum orders apply.
Mattic Industries Ltd
17670 65A Avenue #101
Surrey, BC V3S 5N4
Surrey, BC V3S 5N4
