Cured Chromate Epoxy on Parts Before Assembly?
Posted: Fri Jun 21, 2013 1:31 pm
Hello All:
Several years ago I got carried away, painting chromate epoxy on several Torque Tube Arm parts. Now that I am tackling "that darned flaperon torque tube" installation, I question whether pre-painting epoxy on the control arms was a good idea.
Will cured epoxy on a part affect the gripping power and structural integrity of the rivets and mating surfaces after assembly? Should I remove the cured epoxy from the arms where the rivet heads and mating surfaces (arm and cap) meet, then upon final rivet installation, paint fresh (wet) epoxy on the part, then rivet? Or is it okay to just scuff the cured epoxy mating areas including where the rivet heads sit and continue on? What is the preferred method here?
Note: In my past assembly of parts, I have always scuffed the bare aluminum parts, dipped the rivets assembling everything wet. The above was just one of my "outsmarting myself again" ideas.
Thank you in advance for thoughts.
Over-and-out . . .
Terry R662
Over-and-out . . .
Terry R662
