FUS-12 Witches Hat
Posted: Mon Nov 05, 2012 12:33 pm
by randrews
Is Murphy the best source for FUS-12 Witches Hat ?? ... just need a 4' stick, anyone have extra they can part with or know a good source ??
Re: FUS-12 Witches Hat
Posted: Mon Nov 05, 2012 7:40 pm
by tjhickey
I am too would like to get some of that material. Any local source in the US?
Posted: Mon Nov 05, 2012 9:59 pm
by irishfield
Two ways to get it.. order from Murphy or bend it up yourself from sheet stock. It's not a common part that anyone else is making/using, it's a part Murphy bends up specifically for it's fleet of a/c and floats.
Posted: Mon Nov 05, 2012 10:49 pm
by snowyriver
Wayne's right. It's easy to bend up a section. Spruce also sells some if I recall.
Posted: Tue Nov 06, 2012 7:53 am
by tjhickey
ACS material is 20K, and forming such without a press-brake not so easy. But I'll be glad to take a lesson as to how it can be done with a folding apron brake.
Posted: Tue Nov 06, 2012 10:54 am
by randrews
Agree on the need for a press break ... just remembered MFC has a huge press brake that could make this stuff ... maybe Keith has some. If not, I'll go direct via email to Murphy. Regardless, think a close reproduction of the actual FUS-12 could be done on an apron brake ... with a lot of part flipping and sequential partial bends ... but getting the correct on-center bends would be tough. Appreciate the feedback ... thanks. Bob A.
Posted: Tue Nov 06, 2012 12:18 pm
by randrews
Aside from the entertainment value my ignorance may have provided ... while a press brake can certainly make them, its not required. They can be made fairly easily on a pan or box brake. With the material thickness in hand, its a matter choosing the right fingers, looking up the correct finger offset based on the desired bend radius and material thickness ... and then bending. Now I just need to find a brake ... :) Cheers, Bob A.
Posted: Tue Nov 06, 2012 7:53 pm
by tjhickey
I have a homemade brake, built from plans provided by Zenair when I built my CH-300 25 years (ouch) ago. I can, and have, formed the edge bends, and tomorrow I will trot down to the local fab shop and see if they can form the center bend. Please ignore the fancy handle on the brake. Some things just never seem to get finished.
Tim Hickey.
Posted: Tue Nov 06, 2012 9:53 pm
by snowyriver
You can make these with a regular brake. Bend the center section first. Look at this photo: The stiffeners under my floor are nothing but small W hat.
