Wayne ....irishfield wrote:As I slowly work my way towards the inevitable here....
What spark plugs are you guys running with your P mags?
BR8ES is what they say to use .... (14mm NGK) .... (don't forget you'll need the step down adaptors - from the 18mm A/C ones ......... but you KNEW that already !
The "R" is for "Resistor" ................. which apparently helps with reducing the RF / radio interference
If the plug is a bit dark (darker colour) or "wet" - OR "oily" - go a step hotter (to BR7ES) .... and so on - until you get the right burn / colour on the plug ....
The great thing about using the 14mm auto plugs - is that you have an INFINITE range of plugs that can be tailored to suit the situation / cylinder condition etc etc etc
I run a .030" gap too ....... the bigger fatter spark has NO prob's jumping that gap - and is part of the reason WHY the flame front propagation is soooo much better !
