Rivet Education
Ljm
Rivet Education
Post by Ljm » Tue Jun 02, 2020 2:51 pm
Are the Murphy rivet numbers like RV 1410, etc manufactures number as well as part number?
I have not been able to find the 1400 series, nor any that start with RV. Is there a cross reference listing ? Where do you buy your rivets in the US?
Sorry if discussed before, I can't get into the archives.
larry
larry
Elite project
C77 Il
Flygirl
Re: Rivet Education
Post by Flygirl » Tue Jun 02, 2020 3:33 pm
mikefairbanks
Site Admin
Re: Rivet Education
Post by mikefairbanks » Tue Jun 02, 2020 3:44 pm
larry
Larry can you elaborate? If somethings not working I'd like to know.
Mike Davis
Fairbanks, Alaska
"I'd rather be flying!"
Tim Graham
Re: Rivet Education
Post by Tim Graham » Tue Jun 02, 2020 4:24 pm
G-Day Larry , I have just ordered some .
Avex 1661 series Aluminiun/steel Pan heads Part no 01661-00410 will do 0.8 to 4.3 mm 1/8 in
Avex 1604 series Aluminium/steel Countersunk heads Part no 01604-00412 2.4 to 6.3 mm
Tim
Rebel 449
Re: Rivet Education
Post by Rebel 449 » Tue Jun 02, 2020 4:25 pm
The Aircraft Spruce 1601-1410 rivet has a smaller diameter head. Should do just fine on inside such as floor. 1601-1414 same but longer grip length.
Do a search for avex rivets and then narrow down to head diameter your looking for. Do you have a supplier named Fastenall? The correct rivets can be obtained from Mattic Industries in Vancouver British Columbier. They supply Murphy I'm told.
Ahewko
Re: Rivet Education
Post by Ahewko » Tue Jun 02, 2020 5:04 pm
Rivet prices from Fastenal are quite a bit less than Aircraft Spruce in Canada
Ljm
Re: Rivet Education
Post by Ljm » Tue Jun 02, 2020 5:12 pm
Thank you!
Should I have been able to find this out in the plans? This meaning 1601 series is the 1410? I haven't been too successful googleing.. :( I did find this site https://www.rivetsonline.com/documents/ ... igrips.pdf which has different numbers.
Thanks again!
larry
Elite project
C77 Il
Ray Mason
Re: Rivet Education
Post by Ray Mason » Tue Jun 02, 2020 5:21 pm
order from Mattic, that where I got mine.
Flygirl
Re: Rivet Education
Post by Flygirl » Tue Jun 02, 2020 8:58 pm
Lawson Products bought Mattic, so you'll end up talking with them.
https://catalogs.lawsonproducts.com/law ... 2019/7-12/
Elite583
Re: Rivet Education
Post by Elite583 » Wed Jun 03, 2020 6:37 am
From the manufacturer's web site:
http://www.avdel-global.com/fileadmin/u ... 2_2015.pdf
Page 77 presents the 1661 series.
Elite583 8)
