Just passing along technique I used on my Yukon to cut Window openings with little requirement for trimming.
The Window frames have a tooling hole that is at the center of radius for 2 opposing corners.
1) Tape window frame to desired location on inside of skin and transfer such the tooling holes to skin. Drill to #30.
2) Move Window frame to outside of skin.
3) Fabricate or buy small 1/8"ID x 3/16"OD x 3/16" long bushing and hold with Cleco to center window frame tooling hole onto 1/8" punched hole.
4) Locate frame rivet holes by extending lines from existing skin rivet holes nearby the windows. Locate 1/4" in from edge of frame. Drill #40 rivet holes in frame offline in drill press.
5) Reinstall with tooling hole and bushing and transfer drill to skin.
6) Drill Arc start and stop holes at tangent of arc using frame as template. Remove frame.
7) Use Dremel with Circle Cutting Guide and a RotoZip 1/8" bit. The pivot point on Circle cutter is 1/8" Set Pivot Point to radius and lock down. ( the pivot slide is a bit sloppy in the track so I used 0.032" shim to jam it tight so it would not move or twist. )
Use lubricate ( AlumTap or equivalent) the bit to avoid galling the bit which will cause ragged edges and uneven slot width.
9) Tape bottom of Cutting guide to avoid scratches and Cut arcs in clockwise directions.
10) Tape edge of straight lines and cut with hand nibbler.
11) File and sand edges and debur.
Cutting Window Openings
Re: Cutting Window Openings
Very nicely done. I had to cut out my side windows after the fuse was painted and was able to use an air nibbler with tape over the paint to avoid scratching. Worked great.
Great job...looks very professional...we like that!!
Ray
Ray
