N25SR is a Tax Paying Citizen
Post by Jerry Folkerts » Tue Dec 19, 2017 2:42 pm
Today, our DAR, Frank Baldwin came up and issued the Airworthiness Certificate to N25SR. Wow, almost 3900 hours and seven years. Still, I have two leaking rivets to deal with in the right wing fuel tank, figure out those constantly warping split rings on the seat rails, and wait for a new rpm sensor to replace the one not working. With Christmas and a full week of really cold weather coming up (thanks Canadians), it will likely be early January when it takes to the air for the first time.
Re: N25SR is a Tax Paying Citizen
Post by irishfield » Tue Dec 19, 2017 3:38 pm
CONGRATULATIONS Jerry!!!! What a milestone!
Rivets leaking out the stem hole or perimeter? Stem hole, I've fixed many by simply using a small spherical ball in the dremel to cut a ring into the ID of the rivet head and fill with PRC. Or just drill them out, coat a new rivet in PRC, insert and pull. Yes you'll have the shop ends inside the tank, but depending where they are you can get them with a flexible magnetic wand thanks to the steel in the mandrel head.
Mike Espinoza
Post by Mike Espinoza » Tue Dec 19, 2017 4:54 pm
Congratulations Jerry. Your Airworthiness Certificate is a great accomplishment. I have enjoyed watching your progress for years. I look forward to that day myself for my project.
Washington Rebel
Post by Washington Rebel » Tue Dec 19, 2017 5:10 pm
Congrats Jerry.
Tom
Rebel 831R
Flying as of May 2016
Elite583
Post by Elite583 » Tue Dec 19, 2017 6:07 pm
Congratulations Jerry! Big milestone, well done.
It's 3C (38F) and raining in my part of Canada, I could see about FedEx-ing some of that to you in place of the cold........ :P Actually, I'm looking forward to trying to get some air time Friday when it's finally supposed to be clear (& -7C)
Look at it this way, after 3900 hours, a few more days will give you a chance to think if there are of any other small details you need to consider for your first flight.
Please keep us up to date on your progress.
Dave 8)
Elite 583
Post by snowyriver » Tue Dec 19, 2017 6:16 pm
Great job, Jerry! Many on this site know what you’re feeling right now and it is sweet! I think you were just starting to build when Deb and I met you at the Murphy party at Osh. Wow, time goes by so fast. Craig
Post by Jerry Folkerts » Wed Dec 20, 2017 2:53 am
Wayne,
Coming from the center of the rivets. One is a tank rivet on the lower root access panel, the other a countersunk rivet in the lower root corner by the spar. I may try and fix without drilling the rivets out at first. It may buy me some time until the weather is warmer.
micreb
Post by micreb » Wed Dec 20, 2017 3:59 am
The finish line already eh Jerry?
You’re going to LOVE that plane!
Hope all goes well flying off phase 1. Did you get 25 or 40 hrs for your phase 1 time?
Paul in really foggy No. Florida
mikeh
Post by mikeh » Wed Dec 20, 2017 12:06 pm
Good one Jerry,
818 had a couple of leaky rivets initially, both were tank rivets leaking in the centre so they must have split when being installed. One was near the filler neck and was fixed with a dob of proseal inside the tank accessed through the filler. The other was treated like Wayne does and using the mixing cartridge like a syringe, placing the nozzle over the rivet head and forcing proseal into the rivet. Both repairs are fine after 3 years.
Your machine looks great. Thanks for keeping us in the loop.
Post by Jerry Folkerts » Wed Dec 20, 2017 3:00 pm
Paul,
40 hours. Although the engine is certified, 0 SMOH, most of the accessories are experimental.
Post by Jerry Folkerts » Sun Jan 07, 2018 2:40 am
Well, the cards are lining up for a Tuesday afternoon first flight. 40-45 degrees, wind 8 mph straight down the runway. Stay tuned!
Post by Jerry Folkerts » Tue Jan 09, 2018 2:01 pm
Due to poor weather and a faulty rpm indication, we've delayed the first flight. The good news is we figure out the rpm problem and I'll fix tomorrow and do a quick test run. No good weather in the near future. Stay tuned.
Jenki
Post by Jenki » Wed Jan 10, 2018 12:26 am
I am keeping fingers Jerry.
We have bad weather here as well, but different sort of. Nearly no winter, unusually warm 5-9 Celsius during day, rainy, low clouds and fog, low visibility, permanent IMC. Maybe two days ready for flying since end of November 2017
Have a nice day
Zrinko
Post by Zrinko » Sun Jan 14, 2018 9:26 am
Congrac Jerry! Nice looking bird, you have!
Jenki
Post by Jenki » Sun Jan 14, 2018 1:28 pm
Btw. do you have exact color numbers?
I am, step by step, preparing all necessary information for future.
My color livery will be exactly the same.
