I am a new owner of an Elite purchased installed on Clamar amphib floats with tricycle gear included in purchase. I am looking for a recommendation on a prop to replace current 81" McCauley installed by previous owner which provides plenty of thrust for operation on floats but leaves only 4" of ground clearance when on factory tricycle gear. One prop for year round use on floats or tricycle gear would be preferred but willing to remount 81" McCauley prop each season when on floats. Prince p-tip? Senenich? Hartzell? Ground adjustable??
Flyfisher
Propeller Recommendations
Re: Propeller Recommendations
One vote for the prince
Doing great on my rebel so far
Tom
Rebel 831R
Flying as of May 2016
Rebel 831R
Thanks Tom. Are you on floats or ground gear (if ground gear I assume tail dragger Rebel?) What is your engine and which Prince prop did you install? Wood? Carbon fiber? Size?
Karl
Karl
Hi Karl
I'm on 29" tires. Taildragger with a 200hp
I used a carbon fiber p tip it's a 74x 56
Tom
Rebel 831R
Rebel 831R
