Aussie Humour
Aussie Humour
Post by Bob Patterson » Mon Feb 20, 2012 8:46 am
Thought I'd pass this along - good for a chuckle or 2 !! ;-)
Some Aussie Bush Flying
A Pilot's Submission to the Civil Aviation Safety Authority (CASA).
On the phone Ron seemed a reasonable sort of bloke. He reminded me of the
need to do a flight review every two years. He even offered to drive out,
look over my property and let me operate from my own ALA (authorised landing
area). Naturally I agreed to that.
Anyway, Ron turned up last Wednesday. He said he was a bit surprised to see
the plane outside my homestead because the ALA is about a mile away.
I explained that being close, this strip was more convenient, but there are
power lines crossing it at about midway but it's really no problem to land
and take-off because at the half-way point you are always on the ground.
For some reason Ron seemed nervous. So, although I had done the pre-flight
inspection only four days earlier, I decided to do it again. Because he was
watching me carefully, I walked around the plane three times instead of my
usual two. My effort was rewarded because the colour returned to Ron's
cheeks - in fact they went to a bright red.
In view of Ron's obviously better mood, I told him I was going to combine
the test flight with my requirement to deliver three poddy calves from the
home paddock to the main herd. After a bit of a chase I caught the calves
and threw them in the back. We climbed aboard but Ron started nagging about
weight and balance calculation. Of course I knew that sort of thing was a
waste of time because stock likes to move around a bit. However, I did
assure Ron that I keep the trim wheel Araldited to neutral so we would
always remain stable.
Anyway, I started the engine and cleverly minimised the warm-up time by
tramping hard on the brakes and gunning her to 2,500 rpm. I then discovered
that Ron has very acute hearing. Through all that noise he detected a
metallic rattle and demanded I account for it. Actually it began last month
and was caused by a screwdriver that fell down a hole in the floor and
lodged in the fuel selector mechanism. The selector can't be moved but
because it was on 'All tanks' I figured it didn't matter.
However, as Ron was obviously a nit picker, I blamed the noise on vibration
from a stainless steel thermos I keep in a beaut little possie between the
windshield and the magnetic compass. My explanation seemed to relax Ron
because he slumped back in the seat and looked at the cockpit roof.
I released the brakes to taxi out but unfortunately the plane gave a leap
and spun to the right, "Hell" I thought, not the starboard wheel chock
again. The bump jolted Ron back to full alertness. He looked wildly just in
time to see a rock thrown by the propwash disappear through the windscreen
of his new Commodore.
While Ron was busy ranting about his car, I ignored his requirement that we
taxi to the ALA and instead took off under the power lines. Ron didn't say a
word, at least not until the engine coughed at lift off, then he screamed,
"Oh God!" "Now take it easy," I told him firmly, "That often happens on
take-off and there is a good reason for it." I explained patiently that I
usually run the plane on standard MOGAS but one day I accidentally put in a
gallon or two of kerosene. To compensate for the low octane of the kerosene
I siphoned in a few gallons of super MOGAS and shook the wings up and down a
few times to mix it up. Since then the engine has been coughing a bit but in
general it works just fine.
At this stage Ron seemed to lose all interest in the flight test. He pulled
out some rosary beads, closed his eyes and became lost in prayer. I selected
some nice music on the HF to help him relax. Meanwhile I climbed to my
normal NOSAR NODETAILS cruising altitude of 10,500 feet.
On levelling out I noticed some wild camels heading into my improved
pasture. I hate camels and always carry a loaded .303 carbine clipped inside
the door. We were too high to hit them, but as a matter of principle, I
decided to have a go through the open window.
The effect on Ron was electric. As I fired the first shot his neck
lengthened by about six inches and his eyes bulged like a rabbit with myxo.
In fact, Ron's reaction was so distracting that I lost concentration and the
next shot went through the port tyre. Ron was a bit upset about the
shooting, probably one of those pinko animal lovers - I thought, so I
decided not to tell him about our little problem. Shortly afterwards I
located the main herd and decided to do my fighter pilot trick. Ron had gone
back to praying when, in one smooth sequence, I pulled on full flap,cut the
power and started a sideslip down to 500feet.
About half way through the descent I looked back to see the calves
gracefully suspended in mid air. I was going to comment on this unusual
sight but Ron had rolled himself into the fetal position and was emitting
high pitched squeals.
At about 500 feet I leveled out, but for some reason we continued sinking.
When we reached 50 feet I applied power and that helped quite a lot. As luck
would have it, at that height we flew into a dust cloud caused by the cattle
and went IFR. I made a mental note to consider an instrument rating as soon
as the gyros are repaired.
Suddenly Ron's elongated neck and bulging eyes reappeared. His mouth opened
wide, very wide, but no sound emerged. "Take it easy," I told him. "we'll be
out of this in a minute."
Sure enough, about a minute later we emerged; still straight and level and
still at 50 feet. Admittedly I was surprised to notice that we were upside
down. This minor tribulation forced me to fly to a nearby valley in which I
did a half roll to get upright again.
By now the main herd had divided into two groups leaving a narrow strip
between them. "Ah!," I thought, "there's an omen. We'll land there."
Knowing that the tyre problem demanded a slow approach, I flew a couple of
steep turns with full flap. Soon the stall warning horn came on and so I
knew we were slow enough. I turned steeply onto a 75 foot final and put her
down. Strangely enough, I had always thought you could only ground loop in a
tail dragger.
Halfway through our third loop Ron at last recovered his sense of humour.
Talk about laugh.... I've never seen the likes of it; he couldn't stop.
We finally rolled to a halt and I released the calves.
I then began picking clumps of dry grass. Between gut wrenching fits of
laughter Ron asked what I was doing. I explained that we had to stuff the
port tyre with grass so we could fly home.
It was then that Ron started running.
The last time I saw him he was off into the distance, arms flailing in the
air and still shrieking with laughter.
I later heard that he had been confined to a psychiatric institution.
Anyhow that's enough about Ron; I just got a letter from CASA withdrawing,
as they put it, the privilege of holding a license to fly.
Now I admit that I made a mistake in taxiing over the wheel chock but I
can't see what else I did that was so terrible.
Can you?
