pulleys & engine mounts
Posted: Fri Feb 17, 2012 11:27 pm
Hi All
Can any one tell me what pulleys and brackets come with the rebel kit as i
have none. I need all part numbers and quantities ???
also the engine mounts in mine are fus 17 while new manual shows a two part
assembly of fus 86 & 87, should i upgrade, has anyone seen this situation as
of yet??
next problem the floor in my rebel has 4 sets of stringers running the
length of the fuselage instead of 3 as shown in my manual, no big deal
except for all the extra st-40 angles i have been installing, what a pain.
However not all the stringers have been trimmed back to the edged of the
angles that are perpendicular to them, instead they extend inside the angle,
can i leave these or should i try to trim them out, not easy to do
however???
Mike#007
EOM
of yet??
however???
Mike#007
EOM
