Moose: Ray Allen Servo
by Ted Waltman
Fred,
AFAIK, every Moose owner uses this combination servo/actuator arm. Put the
sleeve on as per the service bulletin (get a sleeve at your local hardware
store if you don't have one already).
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Fred
Messinger (fredm)
Sent: Friday, August 21, 2009 3:45 PM
Subject: Re: [rebel-builders] Firewell caulk
Hi Guys,
I'm currently installing the elevator trim tab servo motor on my moose quick
build.. The one MAM shipped is manufactured by The Ray Allen Company.
Everything (motor casing, clevis forks) is made out of a hard plastic
material. The push rod itself is a threaded metal rod, though.
My questions: Is anyone else using this set up? If not, which system are
you using?
I confess, I'm a little concerned about those flimsy little clevis forks and
the plastic drive pin....especially in cold weather.
Fred
