Airframe clean up
Posted: Fri Feb 17, 2012 11:27 pm
Hi Bob
I want to thank you and the other builders for there input on the increase in
speed with the reflex position at 6 degrees. I just completed my first annual
inspection and incorporated a detent into my flap handle for the reflex
position and installed a new handle on the mixer arm with a zero position and
six degree position for the ailerons. ( seperate flaps and ailerons ) I was
very pleased with the 4.5 mph increase in speed and for the comments the
group made as to control feel and pitch changes.
One addtiional question, has anyone stalled the rebel with the controls in
the reflex position, if so are there any abnormal effects. I just like to
test everything.
On a closing note, you cruise at 118 mph @ 2450 rpm with a 74 by 56 prop and
no stream line fairings. It would also be helpfull if you know the engine
manifold pressure and or full flow is at this setting. For a comparison my
rebel with all the clean up work that i have done turning a 72 by 56 prop on
my IO240 will cruise at 118 mph at 2000 ft @ 19.5" mp @2290 rpm on a fuel
flow of 4.7 gph. (approx 55% power )
It is amazing to me how much additional cruise performance we can get from
the rebel using simple fairings. Another performance increase we get and we
don't talk much about it is R/C. I did not see much change in the max R/C at
70 mph during the airframe clean up but did see a large increase in the
cruise climb R/C .
We all spend a lot of time building our airplanes. Spend a little more on
cleaning up the airframe. The performance increase is well worth it and it's
fun!
Best Regards
Steve Sloan 536R
test everything.
cruise climb R/C .
fun!
Best Regards
Steve Sloan 536R
