[rebel-builders] Die Spring Gear Struts - 100th and 101st sets shipped toda
Posted: Sun Feb 19, 2012 5:21 pm
I'm a new kid here Guys & gals... I am restoring a 20 year old Renegade
here in New Jersey.. What is this Die Spring Gear Struts ??? What I see
on my Project is not the strongest thing I've ever seen or high tech either.
Can I get some Information from Wayne ??? will what he has work on a
Renegade
Joe diamond@easyliving.com
G. O'Shea
Sent: Friday, April 03, 2009 11:20 PM
Subject: Re: [rebel-builders] Die Spring Gear Struts - 100th and 101st sets
shipped today
1/2" wrench will give the slider bolt a spin if that's what you wanna do.
Would have called but was scrambling with wife in Emerg during my
pre-arranged dash there and back by truck....Saw a lot of "interesting"
stuff.....
Sent: Friday, April 03, 2009 11:12 PM
shipped today
Checked by AVG - www.avg.com
Version: 8.0.238 / Virus Database: 270.11.41/2040 - Release Date: 04/03/09
17:54:00
Renegade
G. O'Shea
shipped today
stuff.....
shipped today
Hi Wayne !
You should have called if you were down - I'd buy coffee,
or a beer, if you drove ! :-)
(See anything you liked ??)
Congratulations on reaching 100 !!
I usually oil my gear struts every 2nd or 3rd flight .... been a
looonnnnggggg while !! :-( What size are those bolts, again ??
Hope to get out from behind this keyboard & go flying
again soon - after giving it a bath, lube, and gear leg fairing ....
Likely will be after Sun 'n Fun ...
bobp@prosumers.ca
http://www.prosumers.ca/Ramble09
On Saturday 04 April 2009 01:40, Wayne G. O'Shea wrote:Just some self serving spam !
Shipped the 100th and 101st pair of die spring struts today, that I've
been mfg'g since 1994 for the Rebel, some Renegades, a couple of Mirandas
and a few others.
I haven't had one customer contact me, after shipping, in regards to the
struts... so in the consumer market place that speaks volumes itself !
For those that have them... remember.. you should lubricate at least once
a year. Possibly a little more often if stored outside. A bit of oil down
the tube so it lubes the slider area between inner and outer tubes and a
quick spray of high pressure grease in the bolt slot behind the spring to
keep it lubed and moisture out.
Have a set here in the hangar on a customers airplane that were seized so
tight it took 4 tons force to pull them apart. Built in 1995 or 1996 and
had never been re-lubed on a stored outside aircraft
Bobp...when'd you do yours last... looked pretty dry yesterday! lol
Wayne O'Shea
17:54:00
