[rebel-builders] Amphib nose bearing
Posted: Sun Feb 19, 2012 5:21 pm
You sure they aren't NSK ??? If so SKF and FAG would be the same number.
Or measure with vernier OD / ID and width... Probably just a common 6201 or
6202 bearing. If you don't get any answers I'll go pull a wheel off the ones
I just finished rebuilding and check the bearings.
Sent: Friday, April 03, 2009 5:08 PM
Subject: [rebel-builders] Amphib nose bearing
Hi all,
Has anyone found a good place to buy the KSK bearing that MAM used in the
nose wheel on the amphibs?
Better yet, how about a cross reference. The P/N is KSK 1628.
I just haven't found the right site yet I guess.
I found one during inspection that growls.
As always, thanks all for the help.
Curt Martin
N97MR
**************Hurry! April 15th is almost here. File your Federal taxes
FREE
with TaxACT.
(http://pr.atwola.com/promoclk/100126575 ... 1%26p%3D82)
