Received: from ibm.net (slip129-37-162-71.on.ca.ibm.net [129.37.162.71]) by
out2.ibm.net (8.8.5/8.6.9) with ESMTP id UAA99300 for
<murphy-rebel@dcsol.com>; Thu, 14 May 1998 20:32:12 GMT
Message-ID: <355B7EDE.29DF62F1@ibm.net>
Date: Thu, 14 May 1998 16:31:42 -0700
Reply-To: wrayt@ibm.net
X-Mailer: Mozilla 4.04 [en] (Win95; U)
MIME-Version: 1.0
To: rebelmail <murphy-rebel@dcsol.com>
Subject: Rebel home page
Just a quick note to let you know I've put up a Rebel page with a few
pictures of various rebels and my rewritten manual up to the wing (which
has been inspected and I am about to close). Comments and suggestions
are welcome and I will continue to update the manual online as I
progress (slowly). The page is on a buddies home page space that comes
with his ISP that he wasn't using. Try here
http://www.globalserve.net/~cobbg/
Wray Thompson R306
Rebel home page
Rebel home page
Received: from bucky.win.bright.net (dal-usr1-cs-26.win.bright.net
[208.140.11.44])
by bucky.win.bright.net (8.9.0.Beta3/8.9.0.FNG_Build) with ESMTP id
QAA14378
for <murphy-rebel@dcsol.com>; Sun, 24 May 1998 16:42:14 -0500 (CDT)
Message-ID: <356896C9.CBAA62C6@bucky.win.bright.net>
Date: Sun, 24 May 1998 16:53:21 -0500
X-Mailer: Mozilla 4.04 [en] (Win95; I)
MIME-Version: 1.0
Subject: Re: Rebel home page
References: <355B7EDE.29DF62F1@ibm.net>
Wray Thompson wrote:
I tried to print your manual, on my HP Inkjet, when my system would blow. I
narrowed the problem to a little box with a question mark in it. I found it
in two places. between inst. 44 and 45 in the stabilizer section and in the
fin section between inst. 31 and 32. Are you aware of this?
Jerry Eadler R325
[208.140.11.44])
QAA14378
MIME-Version: 1.0
Wray--Just a quick note to let you know I've put up a Rebel page with a few
Wray Thompson R306
Jerry Eadler R325
Rebel home page
Received: from ibm.net (slip129-37-151-196.on.ca.ibm.net [129.37.151.196])
by out2.ibm.net (8.8.5/8.6.9) with ESMTP id OAA86244 for
<murphy-rebel@dcsol.com>; Thu, 28 May 1998 14:34:36 GMT
Message-ID: <356DA003.A9F9FB1C@ibm.net>
Date: Thu, 28 May 1998 10:33:56 -0700
MIME-Version: 1.0
Hi Jerry
Sorry I didn't respond earlier ...just to nice out these days to spend
much
time on the computer. What caused your problem is an AutoCad drawing I made
my spring clamp, but lost when I moved to a new system. I was hoping to find
copy and put it in but as you dicovered I haven't as yet. The ? sysmbol you
see
just means it couldn't find the requested image ..not sure why your system
is
blowing on that but I removed the pointers and just put in a comment (not
available) for now so you should be able to print. Never thought anyone
would
try to print it from the web page. how does it look? You may also find in
wing section that I split it in 2 to let it download quicker and as a result
numbering starting at the wet tank install part started over at 1. the
indexing
still looks like its all part of the same section but when your in the
manual it
just seems to stop. Look at the last diagram number at that point, add a
couple
to it then go back to the index on the left and this selection should take
you
into the wet tank. I'll try and fix it when I get time. Good luck ...Wray
MIME-Version: 1.0
Hi Jerry
much
see
is
would
indexing
manual it
couple
you
Wray Thompson R306
itnarrowed the problem to a little box with a question mark in it. I found
thein two places. between inst. 44 and 45 in the stabilizer section and in
Jerry Eadler R325
