[rebel-builders] SR/Moose: Factory (manual) weight & balance
Posted: Sun Feb 19, 2012 5:16 pm
Hi Ted !
I suspect that '30 gallons' was meant to be '30 gallons per side',
for a total of 60 gallons - the original standard fuel capacity....
As for the 49" - I dunno ..... of course, it could be 49" from
SOME point - you CAN choose ANYWHERE as a datum, even somewhere
1 mile in front of the aircraft ! You would expect that all measurements
would relate to the SAME datum point, though ... ;-)
It would be very unusual to measure from an 'operational C of G' ....
a moveable point !
Maybe there will be an explanation forthcoming.
bobp@prosumers.ca
http://www.prosumers.ca/Ramble09
On Monday 02 March 2009 15:15, Ted Waltman wrote:
a moveable point !
bobp@prosumers.ca
In the Chapter 26 SR-2500 weight and balance section, page 2, they show a
sample weight table. In this table, the factory has a sample fuel load of
30 gallons weighing in at 360 lbs! What kind of fuel weighs 12
lbs/gallon? Maybe I'm missing something here-someone please let me know if
I've overlooked something.
They also show the baggage arm at 49" in that same sample weight table.
I'm assuming the 49" figure is based off the "Operational center of
gravity" which is calculated at 12.4" on the previous page (49 + 12.4 =
61.4"). The baggage area moment is listed as 65.0" in a previous figure.
As this 65 is close to the 61.4" maybe this is what they are doing in the
table?
Perhaps someone at the factory will see this and issue a corrected page /
table with better explanations in the technical support section of the
website.
Ted Waltman
