[rebel-builders] continental o-300
Posted: Sun Feb 19, 2012 8:15 pm
Don't recall one and the issue is those extra 2 cylinders... further out...
= nose heavy and longer moment arm on firewall/door post fwd section of the
fuselage that could possibly = landing damage. Also consider 6 cylinders to
maintain for 145 HP. when you can get much more power (and lighter weight)
with 4 cylinders.
Sent: Saturday, February 14, 2009 9:12 PM
Subject: [rebel-builders] continental o-300
Hi Has anyone out there installed a continental o-300 (145 HP ) on a
rebel. Thanks Bob
by Bob Patterson
Right on, Wayne ! That longer, heavier engine will not be
a good choice, Bob !! Also, you'll be buying new cylinders
every 300 - 400 hours ..... :-(
(Speaking as a former owner of 2 OLD Continentals -
the 6 cylinder is smooth, and pretty good with fuel,
but not cheap to keep running !)
There IS one Rebel with a 6 cylinder Continental - a modern
IO-360, I think .... BUT - it was extensively modified, and the
builder had assistance from a very talented Rebel builder with
an engineering background ! .... and it is on amphibs only....
This is quite a different situation ....
Not to mention that you are completely on your own for
mounts, cowling, etc. ..... Just NOT the best way to get
flying quickly & safely !
bobp@prosumers.ca
http://www.prosumers.ca/Ramble09
out... = nose heavy and longer moment arm on firewall/door post fwd
section of the fuselage that could possibly = landing damage. Also
consider 6 cylinders to maintain for 145 HP. when you can get much more
power (and lighter weight) with 4 cylinders.
rebel. Thanks Bob
